laughingman23@gmail.com 0 Posted ... (edited) Hi, so my eddie client was working fine then today when i tried to connect it timed out when checking ipv4 then started to try to connect to different servers. I left it to do its thing but then it started to say that I had reached max connections. I checked my acct and it said that I was on 5 connections (the ones eddie had tried to connect to). I then tried to renew my vpn device, logged out and in again. Same problem. I deleted the device then tried logging out and in. same problem. I reset my PC and my router. same problem. i reinstalled the eddie client. same problem. I've tried changing my DNS and unchecking the "protocols" from "automatic. Nothing seems to work. Can anyone help? Heres my log: . 2025.04.17 17:09:59 - Eddie version: 2.24.6 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: 10.0.26100.0, Framework: v4.0.30319 . 2025.04.17 17:09:59 - Command line arguments (1): path="home" . 2025.04.17 17:10:00 - Collect network information . 2025.04.17 17:10:00 - Reading options from C:\Users\jayhu\AppData\Local\Eddie\default.profile . 2025.04.17 17:10:00 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.1 4 Jun 2024, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2025.04.17 17:10:00 - SSH - Version: OpenSSH_for_Windows_9.5p1, LibreSSL 3.8.2 (C:\WINDOWS\System32\OpenSSH\\ssh.exe) . 2025.04.17 17:10:00 - SSL - Version: 5.69 (C:\Program Files\AirVPN\stunnel.exe) I 2025.04.17 17:10:01 - Ready . 2025.04.17 17:10:01 - Collect information about AirVPN completed I 2025.04.17 17:10:22 - Checking login ... ! 2025.04.17 17:10:22 - Logged in. I 2025.04.17 17:10:59 - Session starting. . 2025.04.17 17:10:59 - Activation of Network Lock - Windows Filtering Platform I 2025.04.17 17:10:59 - Checking authorization ... I 2025.04.17 17:11:10 - Checking authorization ... ! 2025.04.17 17:11:10 - Connecting to Muhlifain (Netherlands, Alblasserdam) . 2025.04.17 17:11:10 - Routes, add 134.19.179.205/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller #2)". . 2025.04.17 17:11:10 - WireGuard > Setup start . 2025.04.17 17:11:11 - WireGuard > Setup complete . 2025.04.17 17:11:11 - WireGuard > Starting WireGuard/0.5.3 (Windows 10.0.26100; amd64) . 2025.04.17 17:11:11 - WireGuard > Watching network interfaces . 2025.04.17 17:11:11 - WireGuard > Resolving DNS names . 2025.04.17 17:11:11 - WireGuard > Creating network adapter . 2025.04.17 17:11:11 - WireGuard > Using existing driver 0.10 . 2025.04.17 17:11:11 - WireGuard > Creating adapter . 2025.04.17 17:11:11 - WireGuard > Using WireGuardNT/0.10 . 2025.04.17 17:11:11 - WireGuard > Dropping privileges . 2025.04.17 17:11:11 - WireGuard > Interface created . 2025.04.17 17:11:11 - WireGuard > Setup interface . 2025.04.17 17:11:11 - WireGuard > Setting interface configuration . 2025.04.17 17:11:11 - WireGuard > Peer 1 created . 2025.04.17 17:11:11 - WireGuard > Setting device v4 addresses . 2025.04.17 17:11:11 - WireGuard > Setting device v6 addresses . 2025.04.17 17:11:11 - WireGuard > Interface up . 2025.04.17 17:11:11 - WireGuard > Startup complete . 2025.04.17 17:11:11 - WireGuard > Received first handshake . 2025.04.17 17:11:11 - Interface Eddie metric changed from Automatic to 3, layer IPv4 . 2025.04.17 17:11:11 - Interface Eddie metric changed from Automatic to 3, layer IPv6 . 2025.04.17 17:11:11 - DNS leak protection with packet filtering enabled. . 2025.04.17 17:11:11 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1) . 2025.04.17 17:11:11 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1) . 2025.04.17 17:11:11 - DNS IPv4 of a network adapter forced (Ethernet 2, from manual (8.8.8.8,8.8.4.4) to 10.128.0.1) . 2025.04.17 17:11:11 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fd7d:76ee:e68f:a993::1) . 2025.04.17 17:11:11 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:11 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:11 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:12 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:12 - Routes, add 134.19.179.203/32 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:12 - Routes, add 2a00:1678:2470:1414:2239:edb4:3515:ee02/128 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:12 - Flushing DNS I 2025.04.17 17:11:12 - Checking route IPv4 . 2025.04.17 17:11:18 - Checking route (4° try) . 2025.04.17 17:11:22 - Checking route (5° try) E 2025.04.17 17:11:22 - Checking route IPv4 failed, last reason: Fetch url error:SSL peer certificate or SSH remote key was not OK ! 2025.04.17 17:11:22 - Disconnecting . 2025.04.17 17:11:22 - WireGuard > Stop request received . 2025.04.17 17:11:22 - WireGuard > Stopping . 2025.04.17 17:11:23 - WireGuard > Completed . 2025.04.17 17:11:23 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:23 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:23 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:23 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:24 - Routes, delete 134.19.179.205/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller #2)". . 2025.04.17 17:11:24 - Routes, delete 134.19.179.203/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:24 - Routes, delete 2a00:1678:2470:1414:2239:edb4:3515:ee02/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:24 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic) . 2025.04.17 17:11:24 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic) . 2025.04.17 17:11:24 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to 8.8.8.8,8.8.4.4) . 2025.04.17 17:11:24 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2025.04.17 17:11:24 - DNS leak protection with packet filtering disabled. . 2025.04.17 17:11:24 - Collect network information . 2025.04.17 17:11:24 - Connection terminated. I 2025.04.17 17:11:27 - Checking authorization ... ! 2025.04.17 17:11:27 - Connecting to Nash (Netherlands, Alblasserdam) . 2025.04.17 17:11:27 - Routes, add 213.152.161.27/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller #2)". . 2025.04.17 17:11:27 - WireGuard > Setup start . 2025.04.17 17:11:28 - WireGuard > Setup complete . 2025.04.17 17:11:28 - WireGuard > Starting WireGuard/0.5.3 (Windows 10.0.26100; amd64) . 2025.04.17 17:11:28 - WireGuard > Watching network interfaces . 2025.04.17 17:11:28 - WireGuard > Resolving DNS names . 2025.04.17 17:11:28 - WireGuard > Creating network adapter . 2025.04.17 17:11:28 - WireGuard > Using existing driver 0.10 . 2025.04.17 17:11:28 - WireGuard > Creating adapter . 2025.04.17 17:11:28 - WireGuard > Using WireGuardNT/0.10 . 2025.04.17 17:11:28 - WireGuard > Dropping privileges . 2025.04.17 17:11:28 - WireGuard > Interface created . 2025.04.17 17:11:28 - WireGuard > Setup interface . 2025.04.17 17:11:28 - WireGuard > Setting interface configuration . 2025.04.17 17:11:28 - WireGuard > Peer 1 created . 2025.04.17 17:11:28 - WireGuard > Setting device v4 addresses . 2025.04.17 17:11:28 - WireGuard > Interface up . 2025.04.17 17:11:28 - WireGuard > Setting device v6 addresses . 2025.04.17 17:11:28 - WireGuard > Received first handshake . 2025.04.17 17:11:28 - Interface Eddie metric changed from Automatic to 3, layer IPv4 . 2025.04.17 17:11:28 - Interface Eddie metric changed from Automatic to 3, layer IPv6 . 2025.04.17 17:11:28 - DNS leak protection with packet filtering enabled. . 2025.04.17 17:11:28 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1) . 2025.04.17 17:11:28 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1) . 2025.04.17 17:11:28 - DNS IPv4 of a network adapter forced (Ethernet 2, from manual (8.8.8.8,8.8.4.4) to 10.128.0.1) . 2025.04.17 17:11:28 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fd7d:76ee:e68f:a993::1) . 2025.04.17 17:11:28 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:28 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:28 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:29 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:29 - Routes, add 213.152.161.25/32 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:29 - Routes, add 2a00:1678:2470:41:56ef:1b83:3b7c:e518/128 for interface "Eddie (WireGuard Tunnel)". . 2025.04.17 17:11:29 - Flushing DNS I 2025.04.17 17:11:29 - Checking route IPv4 . 2025.04.17 17:11:35 - Checking route (4° try) . 2025.04.17 17:11:39 - Checking route (5° try) E 2025.04.17 17:11:39 - Checking route IPv4 failed, last reason: Fetch url error:SSL peer certificate or SSH remote key was not OK . 2025.04.17 17:11:39 - WireGuard > Startup complete ! 2025.04.17 17:11:39 - Disconnecting . 2025.04.17 17:11:40 - WireGuard > Stop request received . 2025.04.17 17:11:40 - WireGuard > Stopping . 2025.04.17 17:11:41 - WireGuard > Completed . 2025.04.17 17:11:41 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:41 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:41 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:41 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:41 - Routes, delete 213.152.161.27/32 for interface "Ethernet 2 (Realtek PCIe GbE Family Controller #2)". . 2025.04.17 17:11:41 - Routes, delete 213.152.161.25/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:41 - Routes, delete 2a00:1678:2470:41:56ef:1b83:3b7c:e518/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists. . 2025.04.17 17:11:41 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic) . 2025.04.17 17:11:41 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic) . 2025.04.17 17:11:41 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to 8.8.8.8,8.8.4.4) . 2025.04.17 17:11:41 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2025.04.17 17:11:41 - DNS leak protection with packet filtering disabled. . 2025.04.17 17:11:41 - Collect network information . 2025.04.17 17:11:41 - Connection terminated. I 2025.04.17 17:11:44 - Checking authorization ... I 2025.04.17 17:11:47 - Checking authorization ... I 2025.04.17 17:11:51 - Checking authorization ... . 2025.04.17 17:12:21 - Above log line repeated 8 times more I 2025.04.17 17:12:21 - Cancel requested. . 2025.04.17 17:12:21 - Deactivation of Network Lock ! 2025.04.17 17:12:21 - Session terminated. Thanks. Edited ... by OpenSourcerer Apply LOG format to logs Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... Close Eddie. Reopen. Try a connecton once. Then:Logs aren't enough sometimes with Eddie. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
laughingman23@gmail.com 0 Posted ... Hi, thanks for reply. I have a auto updater installed so didn't realise I had updated eddie just the night before. I ended up just uninstalling Eddie then reinstalling previous version and it worked fine. I think was just a bug, I reported it but will stick to this version for now. Cheers :) Quote Share this post Link to post
