methujeraya
Eddie checking route>disconnecting>retrying loop
Wondering if anyone has this figured out yet. Every few months/years, this exact issue happens. The logs doesn't help as to why it happens, it just does. Eddie will go on this endless loop retrying->checking IPV4 route>disconnecting>retrying. Without telling anyone why it's failing. Meanwhile, wireguard would just work instantly. This issue has existed for almost a decade now, and I must have changed my machine 4-5 different times by now. So it's not machine related.
Has anyone got the slightest clue as to why this is happening and if it will EVER get fixed?
Provide logs and we'll know. Or, because it's Eddie, the system report is best (connect once, then do this; don't additionally copy logs, they're in the report):I suspect it's Eddie trying to use a WinTun interface that is not Eddie's or the default one (like Windscribe, Radmin, ExpressVPN, etc.; they frequently cause this).
