Lys
Eddie constantly disconnecting and reconnecting, very slow speed
Hello everyone,
I wan't to preface this by saying that I am not tech savy, at all, so if possible please give me detailed instructions.
I have the problem that Eddie is constantly disconnecting and reconnecting. And I mean at least every thirty seconds. In addition when I am connected the speed is insanly slow, rarely more then 10kbite. I have tried everything I have seen suggested, from connecting to wireguard, over changing servers, even uninstalling and re-installing an older version (since this started when the update came), and I have had zero luck so far. As I said I don't know a lot of tech so I haven't tried anything that goes beyond changing a few settings. I tried to look for answers from past questions in the forum but didn't understand most of the things
My internet works fine if I turn Eddie of, so I don't think it has to do with that. I have Eddie connected to qBittorrent if that changes anything. If you need more information to help me solve this I'm happy to provide it. I just need help with this, the sound it makes every time it reconnects (I have tried turning notification sound off on my Laptop), is driving my actively insane.
Thank you in advance
There is too little information to suggest anything specific:
- Start Eddie,
- Connect and wait for the disconnection/re-connection issue to happen,
- Disconnect,
- Follow the linked guide to generate a system report,
- Post the report here
I hope I understood what you meant corrctly, I copied a log of today into this message (see below). Thank you for taking the time to respond!
. 2025.02.23 23:25:57 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)", already exists.
. 2025.02.23 23:26:03 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)", already exists.
. 2025.02.23 23:26:09 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)", already exists.
. 2025.02.23 23:26:15 - Routes, add 213.152.161.25/32 for interface "Eddie (Wintun Userspace Tunnel)", already exists.
. 2025.02.23 23:26:16 - Routes, add 2a00:1678:2470:41:56ef:1b83:3b7c:e518/128 for interface "Eddie (Wintun Userspace Tunnel)", already exists.
. 2025.02.23 23:26:16 - Flushing DNS
. 2025.02.23 23:26:16 - OpenVPN > Closing TUN/TAP interface
. 2025.02.23 23:26:16 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:14f2::/64)
. 2025.02.23 23:26:16 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:14f2::/64 40 fe80::8 store=active
. 2025.02.23 23:26:16 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 40 fde6:7a:7d20:14f2::1027 store=active
. 2025.02.23 23:26:16 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 40 10.24.242.41 store=active
. 2025.02.23 23:26:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2025.02.23 23:26:17 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:18 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:19 - Collect information about AirVPN completed
. 2025.02.23 23:26:19 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:20 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:21 - Routes, delete 213.152.161.27/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.23 23:26:21 - Routes, delete 213.152.161.25/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:22 - Routes, delete 2a00:1678:2470:41:56ef:1b83:3b7c:e518/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:23 - Routes, delete 213.152.161.27/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.23 23:26:23 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.23 23:26:23 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.23 23:26:23 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.23 23:26:24 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.23 23:26:24 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.23 23:26:24 - DNS leak protection with packet filtering disabled.
. 2025.02.23 23:26:24 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2025.02.23 23:26:24 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2025.02.23 23:26:24 - Connection terminated.
. 2025.02.23 23:26:28 - Waiting for latency tests (254 to go)
. 2025.02.23 23:26:29 - Waiting for latency tests (157 to go)
. 2025.02.23 23:26:30 - Waiting for latency tests (5 to go)
. 2025.02.23 23:26:32 - Collect information about AirVPN completed
I 2025.02.23 23:26:33 - Checking authorization ...
. 2025.02.23 23:26:34 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2025.02.23 23:26:34 - Connecting to Ophiuchus (Norway, Oslo)
. 2025.02.23 23:26:35 - Routes, add 185.206.225.61/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.23 23:26:36 - Routes, add 185.206.225.61/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.23 23:26:37 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2025.02.23 23:26:37 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2025.02.23 23:26:37 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2025.02.23 23:26:37 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.02.23 23:26:37 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.02.23 23:26:37 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.02.23 23:26:37 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.02.23 23:26:37 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.206.225.61:443
. 2025.02.23 23:26:37 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.02.23 23:26:37 - OpenVPN > UDP link local: (not bound)
. 2025.02.23 23:26:37 - OpenVPN > UDP link remote: [AF_INET]185.206.225.61:443
. 2025.02.23 23:26:37 - OpenVPN > TLS: Initial packet from [AF_INET]185.206.225.61:443, sid=9a7477f3 d1c2d21d
. 2025.02.23 23:26:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.02.23 23:26:37 - OpenVPN > VERIFY KU OK
. 2025.02.23 23:26:37 - OpenVPN > Validating certificate extended key usage
. 2025.02.23 23:26:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.02.23 23:26:37 - OpenVPN > VERIFY EKU OK
. 2025.02.23 23:26:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org
. 2025.02.23 23:26:37 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.02.23 23:26:37 - OpenVPN > [Ophiuchus] Peer Connection Initiated with [AF_INET]185.206.225.61:443
. 2025.02.23 23:26:37 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.25.210.1,dhcp-option DNS6 fde6:7a:7d20:15d2::1,tun-ipv6,route-gateway 10.25.210.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:15d2::104b/64 fde6:7a:7d20:15d2::1,ifconfig 10.25.210.77 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2025.02.23 23:26:37 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2025.02.23 23:26:37 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.25.210.1'
. 2025.02.23 23:26:37 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:15d2::1'
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2025.02.23 23:26:37 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2025.02.23 23:26:37 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2025.02.23 23:26:37 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.23 23:26:37 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.23 23:26:37 - OpenVPN > interactive service msg_channel=0
. 2025.02.23 23:26:37 - OpenVPN > open_tun
. 2025.02.23 23:26:37 - OpenVPN > wintun device [Eddie] opened
. 2025.02.23 23:26:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 40 static 10.25.210.77 255.255.255.0
. 2025.02.23 23:26:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 40 all
. 2025.02.23 23:26:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 40 all
. 2025.02.23 23:26:40 - OpenVPN > IPv4 MTU set to 1500 on interface 40 using SetIpInterfaceEntry()
. 2025.02.23 23:26:40 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 40 fde6:7a:7d20:15d2::104b/128 store=active
. 2025.02.23 23:26:40 - OpenVPN > add_route_ipv6(fde6:7a:7d20:15d2::/64 -> fde6:7a:7d20:15d2::104b metric 0) dev Eddie
. 2025.02.23 23:26:41 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:15d2::/64 40 fe80::8 store=active
. 2025.02.23 23:26:41 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2025.02.23 23:26:41 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 40 all
. 2025.02.23 23:26:41 - OpenVPN > IPv6 MTU set to 1500 on interface 40 using SetIpInterfaceEntry()
. 2025.02.23 23:26:41 - OpenVPN > Initialization Sequence Completed
. 2025.02.23 23:26:42 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.23 23:26:42 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.23 23:26:42 - DNS leak protection with packet filtering enabled.
. 2025.02.23 23:26:43 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.25.210.1)
. 2025.02.23 23:26:43 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:15d2::1)
. 2025.02.23 23:26:43 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.25.210.1)
. 2025.02.23 23:26:44 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:15d2::1)
. 2025.02.23 23:26:45 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:46 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:47 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:49 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:50 - Routes, add 185.206.225.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:53 - Routes, add 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.23 23:26:53 - Flushing DNS
I 2025.02.23 23:26:53 - Checking route IPv4
I 2025.02.23 23:26:54 - Checking route IPv6
I 2025.02.23 23:26:55 - Checking DNS
! 2025.02.23 23:26:56 - Connected.
. 2025.02.23 23:56:35 - Collect information about AirVPN completed
. 2025.02.24 00:26:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.02.24 00:26:26 - OpenVPN > VERIFY KU OK
. 2025.02.24 00:26:26 - OpenVPN > Validating certificate extended key usage
. 2025.02.24 00:26:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.02.24 00:26:26 - OpenVPN > VERIFY EKU OK
. 2025.02.24 00:26:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ophiuchus, emailAddress=info@airvpn.org
. 2025.02.24 00:26:26 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.24 00:26:26 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.24 00:26:26 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.02.24 00:26:37 - Collect information about AirVPN completed
. 2025.02.24 00:46:19 - OpenVPN > [Ophiuchus] Inactivity timeout (--ping-restart), restarting
. 2025.02.24 00:46:19 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2025.02.24 00:46:19 - OpenVPN > Restart pause, 5 second(s)
! 2025.02.24 00:46:20 - Disconnecting
. 2025.02.24 00:46:20 - Sending soft termination signal
. 2025.02.24 00:46:24 - OpenVPN > Closing TUN/TAP interface
. 2025.02.24 00:46:24 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:15d2::/64)
. 2025.02.24 00:46:24 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:15d2::/64 40 fe80::8 store=active
. 2025.02.24 00:46:25 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 40 fde6:7a:7d20:15d2::104b store=active
. 2025.02.24 00:46:25 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 40 10.25.210.77 store=active
. 2025.02.24 00:46:25 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2025.02.24 00:46:26 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 00:46:26 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 00:46:27 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 00:46:27 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 00:46:27 - Routes, delete 185.206.225.61/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.24 00:46:28 - Routes, delete 185.206.225.59/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 00:46:28 - Routes, delete 2001:ac8:38:4:7c0c:6c0f:4ea7:49b9/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 00:46:29 - Routes, delete 185.206.225.61/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.24 00:46:29 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.24 00:46:29 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.24 00:46:29 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.24 00:46:29 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.24 00:46:29 - DNS leak protection with packet filtering disabled.
. 2025.02.24 00:46:29 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2025.02.24 00:46:29 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2025.02.24 00:46:29 - Connection terminated.
. 2025.02.24 00:46:32 - Flushing DNS
! 2025.02.24 00:46:33 - Session terminated.
Edited ... by OpenSourcerer
Apply LOG format to logs
Here is another one, in case something was missing from the first one:
I 2025.02.24 01:20:09 - Session starting.
I 2025.02.24 01:20:10 - Checking authorization ...
. 2025.02.24 01:20:11 - Added new network interface "Eddie", Wintun version 0.12
. 2025.02.24 01:20:12 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2025.02.24 01:20:12 - Connecting to Gemini (Norway, Oslo)
. 2025.02.24 01:20:12 - Routes, add 82.102.27.165/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.24 01:20:12 - Routes, add 82.102.27.165/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.24 01:20:13 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2025.02.24 01:20:13 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2025.02.24 01:20:13 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2025.02.24 01:20:13 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.02.24 01:20:13 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.02.24 01:20:13 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.02.24 01:20:13 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.02.24 01:20:13 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]82.102.27.165:443
. 2025.02.24 01:20:13 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.02.24 01:20:13 - OpenVPN > UDP link local: (not bound)
. 2025.02.24 01:20:13 - OpenVPN > UDP link remote: [AF_INET]82.102.27.165:443
. 2025.02.24 01:20:13 - OpenVPN > TLS: Initial packet from [AF_INET]82.102.27.165:443, sid=d7c8c3c0 017ce41b
. 2025.02.24 01:20:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.02.24 01:20:13 - OpenVPN > VERIFY KU OK
. 2025.02.24 01:20:13 - OpenVPN > Validating certificate extended key usage
. 2025.02.24 01:20:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.02.24 01:20:13 - OpenVPN > VERIFY EKU OK
. 2025.02.24 01:20:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Gemini, emailAddress=info@airvpn.org
. 2025.02.24 01:20:13 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.02.24 01:20:13 - OpenVPN > [Gemini] Peer Connection Initiated with [AF_INET]82.102.27.165:443
. 2025.02.24 01:20:13 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.17.114.1,dhcp-option DNS6 fde6:7a:7d20:d72::1,tun-ipv6,route-gateway 10.17.114.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:d72::10f4/64 fde6:7a:7d20:d72::1,ifconfig 10.17.114.246 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2025.02.24 01:20:13 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2025.02.24 01:20:13 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.17.114.1'
. 2025.02.24 01:20:13 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:d72::1'
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2025.02.24 01:20:13 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2025.02.24 01:20:13 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2025.02.24 01:20:13 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.24 01:20:13 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.24 01:20:13 - OpenVPN > interactive service msg_channel=0
. 2025.02.24 01:20:13 - OpenVPN > open_tun
. 2025.02.24 01:20:13 - OpenVPN > wintun device [Eddie] opened
. 2025.02.24 01:20:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 40 static 10.17.114.246 255.255.255.0
. 2025.02.24 01:20:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 40 all
. 2025.02.24 01:20:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 40 all
. 2025.02.24 01:20:14 - OpenVPN > IPv4 MTU set to 1500 on interface 40 using SetIpInterfaceEntry()
. 2025.02.24 01:20:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 40 fde6:7a:7d20:d72::10f4/128 store=active
. 2025.02.24 01:20:14 - OpenVPN > add_route_ipv6(fde6:7a:7d20:d72::/64 -> fde6:7a:7d20:d72::10f4 metric 0) dev Eddie
. 2025.02.24 01:20:14 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:d72::/64 40 fe80::8 store=active
. 2025.02.24 01:20:14 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2025.02.24 01:20:14 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 40 all
. 2025.02.24 01:20:14 - OpenVPN > IPv6 MTU set to 1500 on interface 40 using SetIpInterfaceEntry()
. 2025.02.24 01:20:14 - OpenVPN > Initialization Sequence Completed
. 2025.02.24 01:20:15 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.24 01:20:15 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.24 01:20:15 - DNS leak protection with packet filtering enabled.
. 2025.02.24 01:20:15 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.17.114.1)
. 2025.02.24 01:20:15 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:d72::1)
. 2025.02.24 01:20:16 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.17.114.1)
. 2025.02.24 01:20:16 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:d72::1)
. 2025.02.24 01:20:16 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:20:17 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:20:17 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:20:18 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:20:19 - Routes, add 82.102.27.163/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:20:19 - Routes, add 2001:ac8:38:23:6072:cc7c:959d:9a8/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:20:19 - Flushing DNS
I 2025.02.24 01:20:20 - Checking route IPv4
I 2025.02.24 01:20:20 - Checking route IPv6
I 2025.02.24 01:20:21 - Checking DNS
! 2025.02.24 01:20:21 - Connected.
. 2025.02.24 01:25:15 - OpenVPN > [Gemini] Inactivity timeout (--ping-restart), restarting
. 2025.02.24 01:25:15 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2025.02.24 01:25:15 - OpenVPN > Restart pause, 5 second(s)
! 2025.02.24 01:25:15 - Disconnecting
. 2025.02.24 01:25:15 - Sending soft termination signal
. 2025.02.24 01:25:20 - OpenVPN > Closing TUN/TAP interface
. 2025.02.24 01:25:20 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:d72::/64)
. 2025.02.24 01:25:20 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:d72::/64 40 fe80::8 store=active
. 2025.02.24 01:25:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 40 fde6:7a:7d20:d72::10f4 store=active
. 2025.02.24 01:25:21 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv4 delete address 40 10.17.114.246 store=active
. 2025.02.24 01:25:21 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2025.02.24 01:25:22 - Routes, delete 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:22 - Routes, delete 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:23 - Routes, delete ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:23 - Routes, delete 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:24 - Routes, delete 82.102.27.165/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.24 01:25:24 - Routes, delete 82.102.27.163/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:25 - Routes, delete 2001:ac8:38:23:6072:cc7c:959d:9a8/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:25 - Routes, delete 82.102.27.165/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.24 01:25:25 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.24 01:25:25 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.24 01:25:26 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.24 01:25:26 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.24 01:25:26 - DNS leak protection with packet filtering disabled.
. 2025.02.24 01:25:26 - Interface Eddie metric restored from 3 to Automatic, layer IPv4
. 2025.02.24 01:25:26 - Interface Eddie metric restored from 3 to Automatic, layer IPv6
. 2025.02.24 01:25:26 - Connection terminated.
I 2025.02.24 01:25:29 - Checking authorization ...
. 2025.02.24 01:25:30 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2025.02.24 01:25:30 - Connecting to Hassaleh (Netherlands, Alblasserdam)
. 2025.02.24 01:25:31 - Routes, add 213.152.161.42/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.24 01:25:31 - Routes, add 213.152.161.42/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.24 01:25:31 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2025.02.24 01:25:31 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2025.02.24 01:25:31 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2025.02.24 01:25:31 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.02.24 01:25:31 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.02.24 01:25:31 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2025.02.24 01:25:31 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2025.02.24 01:25:31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.42:443
. 2025.02.24 01:25:31 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2025.02.24 01:25:31 - OpenVPN > UDP link local: (not bound)
. 2025.02.24 01:25:31 - OpenVPN > UDP link remote: [AF_INET]213.152.161.42:443
. 2025.02.24 01:25:31 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.42:443, sid=81de85c6 e95c6a9d
. 2025.02.24 01:25:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.02.24 01:25:31 - OpenVPN > VERIFY KU OK
. 2025.02.24 01:25:31 - OpenVPN > Validating certificate extended key usage
. 2025.02.24 01:25:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.02.24 01:25:31 - OpenVPN > VERIFY EKU OK
. 2025.02.24 01:25:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hassaleh, emailAddress=info@airvpn.org
. 2025.02.24 01:25:31 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA512
. 2025.02.24 01:25:31 - OpenVPN > [Hassaleh] Peer Connection Initiated with [AF_INET]213.152.161.42:443
. 2025.02.24 01:25:31 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.18.146.1,dhcp-option DNS6 fde6:7a:7d20:e92::1,tun-ipv6,route-gateway 10.18.146.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:e92::1099/64 fde6:7a:7d20:e92::1,ifconfig 10.18.146.155 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2025.02.24 01:25:31 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2025.02.24 01:25:31 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.18.146.1'
. 2025.02.24 01:25:31 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:e92::1'
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2025.02.24 01:25:31 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2025.02.24 01:25:31 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2025.02.24 01:25:31 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.24 01:25:31 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2025.02.24 01:25:31 - OpenVPN > interactive service msg_channel=0
. 2025.02.24 01:25:31 - OpenVPN > open_tun
. 2025.02.24 01:25:31 - OpenVPN > wintun device [Eddie] opened
. 2025.02.24 01:25:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip set address 40 static 10.18.146.155 255.255.255.0
. 2025.02.24 01:25:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete dns 40 all
. 2025.02.24 01:25:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ip delete wins 40 all
. 2025.02.24 01:25:32 - OpenVPN > IPv4 MTU set to 1500 on interface 40 using SetIpInterfaceEntry()
. 2025.02.24 01:25:32 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 40 fde6:7a:7d20:e92::1099/128 store=active
. 2025.02.24 01:25:33 - OpenVPN > add_route_ipv6(fde6:7a:7d20:e92::/64 -> fde6:7a:7d20:e92::1099 metric 0) dev Eddie
. 2025.02.24 01:25:33 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:e92::/64 40 fe80::8 store=active
. 2025.02.24 01:25:33 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2025.02.24 01:25:33 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 40 all
. 2025.02.24 01:25:33 - OpenVPN > IPv6 MTU set to 1500 on interface 40 using SetIpInterfaceEntry()
. 2025.02.24 01:25:33 - OpenVPN > Initialization Sequence Completed
. 2025.02.24 01:25:33 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.24 01:25:33 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.24 01:25:33 - DNS leak protection with packet filtering enabled.
. 2025.02.24 01:25:34 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.18.146.1)
. 2025.02.24 01:25:34 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fde6:7a:7d20:e92::1)
. 2025.02.24 01:25:34 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.18.146.1)
. 2025.02.24 01:25:34 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:e92::1)
. 2025.02.24 01:25:35 - Routes, add 0.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:36 - Routes, add 128.0.0.0/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:36 - Routes, add ::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:37 - Routes, add 8000::/1 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:37 - Routes, add 213.152.161.40/32 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:38 - Routes, add 2a00:1678:2470:44:6d41:b9ad:2395:49d9/128 for interface "Eddie (Wintun Userspace Tunnel)".
. 2025.02.24 01:25:38 - Flushing DNS
I 2025.02.24 01:25:38 - Checking route IPv4
I 2025.02.24 01:25:38 - Checking route IPv6
I 2025.02.24 01:25:39 - Checking DNS
! 2025.02.24 01:25:40 - Connected.
Please generate a system report like so:
You've only posted the application log. It shows the inactivity timeout happening but is not enough for troubleshooting.
Sorry, I didn't do it correctly the first time, this is the link I have now generated:
https://eddie.website/report/1bb2ba6a/
unfortunatelly most if it is in german, I tried to change the language but didn't find the option for doing so
Here is another view, where quote on quote a "fatal error occured" (which has also increasingly happened lately, see also attached screenshot)
Eddie System/Environment Report - 25.02.2025 - 21:28 UTC
Eddie version: 2.21.8
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Home
OS version: Microsoft Windows NT 10.0.26100.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
OpenVPN: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Users\flora\Downloads\AirVPN\openvpn.exe)
Hummingbird: Not available
WireGuard: 0.5.2
SSH: plink 0.73 (C:\Users\flora\Downloads\AirVPN\plink.exe)
SSL: stunnel 5.56 (C:\Users\flora\Downloads\AirVPN\stunnel.exe)
Profile path: C:\Users\flora\AppData\Local\Eddie\default.profile
Data path: C:\Users\flora\AppData\Local\Eddie
Application path: C:\Users\flora\Downloads\AirVPN
Executable path: C:\Users\flora\Downloads\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: Yes, Windows Filtering Platform
Connected to VPN: No
OS support IPv4: Yes
OS support IPv6: Yes
Detected DNS:
Test DNS IPv4: Failed
Test DNS IPv6: Failed
Test Ping IPv4: Failed
Test Ping IPv6: Failed
Test HTTP IPv4: Error: Fetch url error:Couldn't connect to server
Test HTTP IPv6: Error: Fetch url error:Couldn't connect to server
Test HTTPS: Error: Fetch url error:Couldn't resolve host name
login: (omissis)
password: (omissis)
remember: True
connect: True
netlock: True
servers.denylist: db34d07034f09d8832eb33595a9813167aee65dabdbfa9d67b439f937babc332
mode.type: wireguard
mode.protocol: UDP
mode.port: 1637
mode.alt: 2
proxy.mode: none
network.iface.name: Eddie
Logs:
. 2025.02.25 16:24:46 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.26100.0, Mono/.Net: v4.0.30319
. 2025.02.25 16:24:46 - Command line arguments (1): path="home"
. 2025.02.25 16:24:47 - Raise system privileges
. 2025.02.25 16:24:58 - Reading options from C:\Users\flora\AppData\Local\Eddie\default.profile
. 2025.02.25 16:25:06 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\Users\flora\Downloads\AirVPN\openvpn.exe)
. 2025.02.25 16:25:06 - SSH - Version: plink 0.73 (C:\Users\flora\Downloads\AirVPN\plink.exe)
. 2025.02.25 16:25:06 - SSL - Version: stunnel 5.56 (C:\Users\flora\Downloads\AirVPN\stunnel.exe)
! 2025.02.25 16:25:07 - Activation of Network Lock - Windows Filtering Platform
I 2025.02.25 16:25:09 - Ready
. 2025.02.25 16:25:10 - Collect information about AirVPN completed
I 2025.02.25 16:25:10 - Session starting.
. 2025.02.25 16:25:11 - Collect information about AirVPN completed
. 2025.02.25 16:25:11 - Waiting for latency tests (6 to go)
I 2025.02.25 16:25:14 - Checking authorization ...
F 2025.02.25 16:25:14 - Wrong login/password.
I 2025.02.25 16:25:19 - Cancel requested.
! 2025.02.25 16:25:19 - Session terminated.
I 2025.02.25 16:25:26 - Session starting.
I 2025.02.25 16:25:27 - Checking authorization ...
F 2025.02.25 16:25:28 - Wrong login/password.
I 2025.02.25 16:25:29 - Cancel requested.
! 2025.02.25 16:25:29 - Session terminated.
! 2025.02.25 16:25:31 - Logged out.
I 2025.02.25 16:25:41 - Checking login ...
! 2025.02.25 16:25:41 - Logged in.
I 2025.02.25 16:25:46 - Session starting.
I 2025.02.25 16:25:47 - Checking authorization ...
! 2025.02.25 16:25:48 - Connecting to Nash (Netherlands, Alblasserdam)
. 2025.02.25 16:25:48 - Routes, add 213.152.161.27/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 16:25:48 - Routes, add 213.152.161.27/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 16:25:49 - WireGuard > Setup start
. 2025.02.25 16:25:50 - WireGuard > Setup complete
. 2025.02.25 16:25:50 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 16:25:50 - WireGuard > Watching network interfaces
. 2025.02.25 16:25:50 - WireGuard > Resolving DNS names
. 2025.02.25 16:25:50 - WireGuard > Creating network adapter
. 2025.02.25 16:25:50 - WireGuard > Using existing driver 0.10
. 2025.02.25 16:25:50 - WireGuard > Creating adapter
. 2025.02.25 16:25:50 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 16:25:50 - WireGuard > Eddie build 2
. 2025.02.25 16:25:50 - WireGuard > Dropping privileges
. 2025.02.25 16:25:50 - WireGuard > Interface created
. 2025.02.25 16:25:50 - WireGuard > Setup interface
. 2025.02.25 16:25:50 - WireGuard > Setting interface configuration
. 2025.02.25 16:25:50 - WireGuard > Peer 1 created
. 2025.02.25 16:25:50 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 16:25:50 - WireGuard > Interface up
. 2025.02.25 16:25:50 - WireGuard > Received first handshake
. 2025.02.25 16:25:51 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 16:25:51 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 16:25:51 - DNS leak protection with packet filtering enabled.
. 2025.02.25 16:25:51 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 16:25:51 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 16:25:52 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 16:25:52 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 16:25:52 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 16:25:53 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 16:25:54 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 16:25:54 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 16:25:55 - Routes, add 213.152.161.25/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 16:25:55 - Routes, add 2a00:1678:2470:41:56ef:1b83:3b7c:e518/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 16:25:55 - Flushing DNS
I 2025.02.25 16:25:56 - Checking route IPv4
I 2025.02.25 16:25:56 - Checking route IPv6
I 2025.02.25 16:25:57 - Checking DNS
! 2025.02.25 16:25:57 - Connected.
. 2025.02.25 16:25:57 - WireGuard > Setting device v4 addresses
. 2025.02.25 16:25:57 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 16:25:57 - WireGuard > Setting device v6 addresses
. 2025.02.25 16:25:57 - WireGuard > Startup complete
. 2025.02.25 16:55:12 - Collect information about AirVPN completed
. 2025.02.25 17:16:08 - WireGuard > Handshake for peer 1 (213.152.161.27:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 17:22:01 - WireGuard > Receiving handshake initiation from peer 1 (213.152.161.27:1637)
. 2025.02.25 17:22:01 - WireGuard > Sending handshake response to peer 1 (213.152.161.27:1637)
W 2025.02.25 17:23:40 - WireGuard > Handshake timeout
! 2025.02.25 17:23:40 - Disconnecting
. 2025.02.25 17:23:40 - WireGuard > Stop request received
. 2025.02.25 17:23:40 - WireGuard > Stopping
. 2025.02.25 17:23:43 - WireGuard > Completed
. 2025.02.25 17:23:43 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:23:43 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:23:44 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:23:44 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:23:44 - Routes, delete 213.152.161.27/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 17:23:44 - Routes, delete 213.152.161.25/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:23:45 - Routes, delete 2a00:1678:2470:41:56ef:1b83:3b7c:e518/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:23:45 - Routes, delete 213.152.161.27/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 17:23:46 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 17:23:46 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 17:23:47 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 17:23:47 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 17:23:47 - DNS leak protection with packet filtering disabled.
. 2025.02.25 17:23:47 - Connection terminated.
. 2025.02.25 17:23:51 - Waiting for latency tests (253 to go)
. 2025.02.25 17:23:52 - Waiting for latency tests (232 to go)
. 2025.02.25 17:23:53 - Waiting for latency tests (4 to go)
I 2025.02.25 17:23:56 - Checking authorization ...
! 2025.02.25 17:23:57 - Connecting to Gienah (Netherlands, Alblasserdam)
. 2025.02.25 17:23:58 - Routes, add 213.152.162.96/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 17:23:58 - Routes, add 213.152.162.96/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 17:23:58 - WireGuard > Setup start
. 2025.02.25 17:24:04 - WireGuard > Setup complete
. 2025.02.25 17:24:04 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 17:24:04 - WireGuard > Watching network interfaces
. 2025.02.25 17:24:04 - WireGuard > Resolving DNS names
. 2025.02.25 17:24:04 - WireGuard > Creating network adapter
. 2025.02.25 17:24:04 - WireGuard > Using existing driver 0.10
. 2025.02.25 17:24:04 - WireGuard > Creating adapter
. 2025.02.25 17:24:04 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 17:24:04 - WireGuard > Eddie build 2
. 2025.02.25 17:24:04 - WireGuard > Dropping privileges
. 2025.02.25 17:24:04 - WireGuard > Interface created
. 2025.02.25 17:24:04 - WireGuard > Setup interface
. 2025.02.25 17:24:05 - WireGuard > Setting interface configuration
. 2025.02.25 17:24:05 - WireGuard > Peer 1 created
. 2025.02.25 17:24:05 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 17:24:05 - WireGuard > Interface up
. 2025.02.25 17:24:05 - WireGuard > Received first handshake
. 2025.02.25 17:24:06 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 17:24:06 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 17:24:08 - DNS leak protection with packet filtering enabled.
. 2025.02.25 17:24:11 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 17:24:11 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 17:24:12 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 17:24:12 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 17:24:14 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:24:16 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:24:18 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:24:20 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:24:21 - Routes, add 213.152.162.94/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:24:22 - Routes, add 2a00:1678:2470:32:a6d0:3939:bb6b:a0e4/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:24:22 - Flushing DNS
I 2025.02.25 17:24:23 - Checking route IPv4
I 2025.02.25 17:24:24 - Checking route IPv6
I 2025.02.25 17:24:25 - Checking DNS
! 2025.02.25 17:24:25 - Connected.
. 2025.02.25 17:24:26 - WireGuard > Setting device v4 addresses
. 2025.02.25 17:24:26 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 17:24:26 - WireGuard > Setting device v6 addresses
. 2025.02.25 17:24:26 - WireGuard > Startup complete
. 2025.02.25 17:25:18 - Collect information about AirVPN completed
. 2025.02.25 17:36:24 - WireGuard > Handshake for peer 1 (213.152.162.96:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 17:40:49 - WireGuard > Handshake for peer 1 (213.152.162.96:1637) did not complete after 5 seconds, retrying (try 2)
! 2025.02.25 17:52:04 - Disconnecting
. 2025.02.25 17:52:04 - WireGuard > Stop request received
. 2025.02.25 17:52:04 - WireGuard > Stopping
. 2025.02.25 17:52:05 - WireGuard > Completed
. 2025.02.25 17:52:06 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:52:06 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:52:06 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:52:06 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:52:06 - Routes, delete 213.152.162.96/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 17:52:07 - Routes, delete 213.152.162.94/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:52:07 - Routes, delete 2a00:1678:2470:32:a6d0:3939:bb6b:a0e4/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 17:52:07 - Routes, delete 213.152.162.96/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 17:52:08 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 17:52:08 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 17:52:08 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 17:52:08 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 17:52:08 - DNS leak protection with packet filtering disabled.
. 2025.02.25 17:52:08 - Connection terminated.
. 2025.02.25 17:52:08 - Flushing DNS
! 2025.02.25 17:52:08 - Session terminated.
I 2025.02.25 17:52:24 - Session starting.
I 2025.02.25 17:52:25 - Checking authorization ...
! 2025.02.25 17:52:26 - Connecting to Caph (Netherlands, Alblasserdam)
. 2025.02.25 17:52:26 - Routes, add 213.152.162.172/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 17:52:26 - Routes, add 213.152.162.172/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 17:52:26 - WireGuard > Setup start
. 2025.02.25 17:52:28 - WireGuard > Setup complete
. 2025.02.25 17:52:28 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 17:52:28 - WireGuard > Watching network interfaces
. 2025.02.25 17:52:28 - WireGuard > Resolving DNS names
. 2025.02.25 17:52:28 - WireGuard > Creating network adapter
. 2025.02.25 17:52:28 - WireGuard > Using existing driver 0.10
. 2025.02.25 17:52:28 - WireGuard > Creating adapter
. 2025.02.25 17:52:28 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 17:52:28 - WireGuard > Eddie build 2
. 2025.02.25 17:52:28 - WireGuard > Dropping privileges
. 2025.02.25 17:52:28 - WireGuard > Interface created
. 2025.02.25 17:52:28 - WireGuard > Setup interface
. 2025.02.25 17:52:28 - WireGuard > Setting interface configuration
. 2025.02.25 17:52:28 - WireGuard > Peer 1 created
. 2025.02.25 17:52:28 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 17:52:28 - WireGuard > Interface up
. 2025.02.25 17:52:28 - WireGuard > Setting device v6 addresses
. 2025.02.25 17:52:28 - WireGuard > Received first handshake
. 2025.02.25 17:52:28 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 17:52:28 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 17:52:28 - DNS leak protection with packet filtering enabled.
. 2025.02.25 17:52:28 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 17:52:29 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 17:52:29 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 17:52:29 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 17:52:29 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:52:30 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:52:30 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:52:31 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:52:32 - Routes, add 213.152.162.170/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:52:32 - Routes, add 2a00:1678:2470:18:c954:55da:f018:70ff/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 17:52:32 - Flushing DNS
I 2025.02.25 17:52:32 - Checking route IPv4
I 2025.02.25 17:52:33 - Checking route IPv6
I 2025.02.25 17:52:34 - Checking DNS
! 2025.02.25 17:52:34 - Connected.
. 2025.02.25 17:52:34 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 17:52:34 - WireGuard > Setting device v4 addresses
. 2025.02.25 17:52:34 - WireGuard > Startup complete
. 2025.02.25 17:55:22 - Collect information about AirVPN completed
. 2025.02.25 18:00:33 - WireGuard > Handshake for peer 1 (213.152.162.172:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 18:03:58 - WireGuard > Receiving handshake initiation from peer 1 (213.152.162.172:1637)
. 2025.02.25 18:03:58 - WireGuard > Sending handshake response to peer 1 (213.152.162.172:1637)
. 2025.02.25 18:05:46 - WireGuard > Receiving handshake initiation from peer 1 (213.152.162.172:1637)
. 2025.02.25 18:05:46 - WireGuard > Sending handshake response to peer 1 (213.152.162.172:1637)
W 2025.02.25 18:06:04 - WireGuard > Handshake timeout
! 2025.02.25 18:06:04 - Disconnecting
. 2025.02.25 18:06:04 - WireGuard > Stop request received
. 2025.02.25 18:06:04 - WireGuard > Stopping
. 2025.02.25 18:06:06 - WireGuard > Completed
. 2025.02.25 18:06:07 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:06:07 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:06:07 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:06:08 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:06:08 - Routes, delete 213.152.162.172/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 18:06:08 - Routes, delete 213.152.162.170/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:06:09 - Routes, delete 2a00:1678:2470:18:c954:55da:f018:70ff/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:06:09 - Routes, delete 213.152.162.172/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 18:06:09 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 18:06:09 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 18:06:09 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 18:06:10 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 18:06:10 - DNS leak protection with packet filtering disabled.
. 2025.02.25 18:06:10 - Connection terminated.
I 2025.02.25 18:06:13 - Checking authorization ...
! 2025.02.25 18:06:14 - Connecting to Chara (Netherlands, Alblasserdam)
. 2025.02.25 18:06:14 - Routes, add 213.152.187.222/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 18:06:15 - Routes, add 213.152.187.222/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 18:06:15 - WireGuard > Setup start
. 2025.02.25 18:06:17 - WireGuard > Setup complete
. 2025.02.25 18:06:17 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 18:06:17 - WireGuard > Watching network interfaces
. 2025.02.25 18:06:17 - WireGuard > Resolving DNS names
. 2025.02.25 18:06:17 - WireGuard > Creating network adapter
. 2025.02.25 18:06:17 - WireGuard > Using existing driver 0.10
. 2025.02.25 18:06:17 - WireGuard > Creating adapter
. 2025.02.25 18:06:17 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 18:06:17 - WireGuard > Eddie build 2
. 2025.02.25 18:06:17 - WireGuard > Dropping privileges
. 2025.02.25 18:06:17 - WireGuard > Interface created
. 2025.02.25 18:06:17 - WireGuard > Setup interface
. 2025.02.25 18:06:17 - WireGuard > Setting interface configuration
. 2025.02.25 18:06:17 - WireGuard > Peer 1 created
. 2025.02.25 18:06:17 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 18:06:17 - WireGuard > Interface up
. 2025.02.25 18:06:17 - WireGuard > Setting device v6 addresses
. 2025.02.25 18:06:17 - WireGuard > Received first handshake
. 2025.02.25 18:06:18 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 18:06:18 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 18:06:18 - DNS leak protection with packet filtering enabled.
. 2025.02.25 18:06:19 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 18:06:19 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 18:06:19 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 18:06:20 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 18:06:22 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:06:23 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:06:23 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:06:24 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:06:25 - Routes, add 213.152.187.220/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:06:26 - Routes, add 2a00:1678:1337:7a23:1a11:385:cef5:8d8d/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:06:26 - Flushing DNS
I 2025.02.25 18:06:26 - Checking route IPv4
I 2025.02.25 18:06:27 - Checking route IPv6
I 2025.02.25 18:06:28 - Checking DNS
! 2025.02.25 18:06:29 - Connected.
. 2025.02.25 18:06:29 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 18:06:29 - WireGuard > Setting device v4 addresses
. 2025.02.25 18:06:29 - WireGuard > Startup complete
. 2025.02.25 18:11:09 - WireGuard > Receiving handshake initiation from peer 1 (213.152.187.222:1637)
. 2025.02.25 18:11:09 - WireGuard > Sending handshake response to peer 1 (213.152.187.222:1637)
. 2025.02.25 18:13:09 - WireGuard > Receiving handshake initiation from peer 1 (213.152.187.222:1637)
. 2025.02.25 18:13:09 - WireGuard > Sending handshake response to peer 1 (213.152.187.222:1637)
W 2025.02.25 18:13:47 - WireGuard > Handshake timeout
! 2025.02.25 18:13:47 - Disconnecting
. 2025.02.25 18:13:47 - WireGuard > Stop request received
. 2025.02.25 18:13:47 - WireGuard > Stopping
. 2025.02.25 18:13:48 - WireGuard > Completed
. 2025.02.25 18:13:49 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:13:50 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:13:50 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:13:50 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:13:50 - Routes, delete 213.152.187.222/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 18:13:51 - Routes, delete 213.152.187.220/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:13:51 - Routes, delete 2a00:1678:1337:7a23:1a11:385:cef5:8d8d/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:13:51 - Routes, delete 213.152.187.222/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 18:13:51 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 18:13:51 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 18:13:52 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 18:13:52 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 18:13:52 - DNS leak protection with packet filtering disabled.
. 2025.02.25 18:13:52 - Connection terminated.
. 2025.02.25 18:13:55 - Waiting for latency tests (252 to go)
. 2025.02.25 18:13:57 - Waiting for latency tests (6 to go)
I 2025.02.25 18:13:59 - Checking authorization ...
! 2025.02.25 18:14:00 - Connecting to Piscium (Netherlands, Alblasserdam)
. 2025.02.25 18:14:00 - Routes, add 134.19.179.133/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 18:14:01 - Routes, add 134.19.179.133/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 18:14:01 - WireGuard > Setup start
. 2025.02.25 18:14:02 - WireGuard > Setup complete
. 2025.02.25 18:14:02 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 18:14:02 - WireGuard > Watching network interfaces
. 2025.02.25 18:14:03 - WireGuard > Resolving DNS names
. 2025.02.25 18:14:03 - WireGuard > Creating network adapter
. 2025.02.25 18:14:03 - WireGuard > Using existing driver 0.10
. 2025.02.25 18:14:03 - WireGuard > Creating adapter
. 2025.02.25 18:14:03 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 18:14:03 - WireGuard > Eddie build 2
. 2025.02.25 18:14:03 - WireGuard > Dropping privileges
. 2025.02.25 18:14:03 - WireGuard > Interface created
. 2025.02.25 18:14:03 - WireGuard > Setup interface
. 2025.02.25 18:14:04 - WireGuard > Setting interface configuration
. 2025.02.25 18:14:04 - WireGuard > Peer 1 created
. 2025.02.25 18:14:04 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 18:14:04 - WireGuard > Interface up
. 2025.02.25 18:14:04 - WireGuard > Setting device v6 addresses
. 2025.02.25 18:14:04 - WireGuard > Received first handshake
. 2025.02.25 18:14:04 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 18:14:04 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 18:14:04 - DNS leak protection with packet filtering enabled.
. 2025.02.25 18:14:05 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 18:14:06 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 18:14:06 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 18:14:06 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 18:14:07 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:14:08 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:14:10 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:14:11 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:14:12 - Routes, add 134.19.179.131/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:14:13 - Routes, add 2a00:1678:2470:aaaa:dd14:325d:9d13:57fa/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:14:13 - Flushing DNS
I 2025.02.25 18:14:13 - Checking route IPv4
I 2025.02.25 18:14:14 - Checking route IPv6
I 2025.02.25 18:14:15 - Checking DNS
! 2025.02.25 18:14:16 - Connected.
. 2025.02.25 18:14:16 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 18:14:16 - WireGuard > Setting device v4 addresses
. 2025.02.25 18:14:16 - WireGuard > Startup complete
. 2025.02.25 18:25:31 - Collect information about AirVPN completed
. 2025.02.25 18:39:30 - WireGuard > Receiving handshake initiation from peer 1 (134.19.179.133:1637)
. 2025.02.25 18:39:30 - WireGuard > Sending handshake response to peer 1 (134.19.179.133:1637)
W 2025.02.25 18:41:23 - WireGuard > Handshake timeout
! 2025.02.25 18:41:23 - Disconnecting
. 2025.02.25 18:41:23 - WireGuard > Stop request received
. 2025.02.25 18:41:23 - WireGuard > Stopping
. 2025.02.25 18:41:24 - WireGuard > Completed
. 2025.02.25 18:41:24 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:41:25 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:41:25 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:41:25 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:41:25 - Routes, delete 134.19.179.133/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 18:41:26 - Routes, delete 134.19.179.131/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:41:26 - Routes, delete 2a00:1678:2470:aaaa:dd14:325d:9d13:57fa/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 18:41:26 - Routes, delete 134.19.179.133/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 18:41:26 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 18:41:26 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 18:41:27 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 18:41:27 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 18:41:27 - DNS leak protection with packet filtering disabled.
. 2025.02.25 18:41:27 - Connection terminated.
. 2025.02.25 18:41:30 - Waiting for latency tests (253 to go)
. 2025.02.25 18:41:31 - Waiting for latency tests (63 to go)
. 2025.02.25 18:41:32 - Waiting for latency tests (3 to go)
I 2025.02.25 18:41:35 - Checking authorization ...
! 2025.02.25 18:41:35 - Connecting to Sadr (Netherlands, Alblasserdam)
. 2025.02.25 18:41:36 - Routes, add 213.152.187.237/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 18:41:36 - Routes, add 213.152.187.237/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 18:41:36 - WireGuard > Setup start
. 2025.02.25 18:41:37 - WireGuard > Setup complete
. 2025.02.25 18:41:37 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 18:41:37 - WireGuard > Watching network interfaces
. 2025.02.25 18:41:37 - WireGuard > Resolving DNS names
. 2025.02.25 18:41:37 - WireGuard > Creating network adapter
. 2025.02.25 18:41:37 - WireGuard > Using existing driver 0.10
. 2025.02.25 18:41:37 - WireGuard > Creating adapter
. 2025.02.25 18:41:37 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 18:41:37 - WireGuard > Eddie build 2
. 2025.02.25 18:41:37 - WireGuard > Dropping privileges
. 2025.02.25 18:41:37 - WireGuard > Interface created
. 2025.02.25 18:41:37 - WireGuard > Setup interface
. 2025.02.25 18:41:38 - WireGuard > Setting interface configuration
. 2025.02.25 18:41:38 - WireGuard > Peer 1 created
. 2025.02.25 18:41:38 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 18:41:38 - WireGuard > Interface up
. 2025.02.25 18:41:38 - WireGuard > Setting device v6 addresses
. 2025.02.25 18:41:38 - WireGuard > Received first handshake
. 2025.02.25 18:41:38 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 18:41:38 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 18:41:38 - DNS leak protection with packet filtering enabled.
. 2025.02.25 18:41:39 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 18:41:39 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 18:41:39 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 18:41:39 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 18:41:40 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:41:40 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:41:41 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:41:41 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:41:42 - Routes, add 213.152.187.235/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:41:43 - Routes, add 2a00:1678:1337:7a26:b322:10c2:a77d:dee8/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 18:41:43 - Flushing DNS
I 2025.02.25 18:41:43 - Checking route IPv4
I 2025.02.25 18:41:43 - Checking route IPv6
I 2025.02.25 18:41:44 - Checking DNS
! 2025.02.25 18:41:45 - Connected.
. 2025.02.25 18:41:45 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 18:41:45 - WireGuard > Setting device v4 addresses
. 2025.02.25 18:41:45 - WireGuard > Startup complete
. 2025.02.25 18:55:35 - Collect information about AirVPN completed
. 2025.02.25 19:05:47 - WireGuard > Receiving handshake initiation from peer 1 (213.152.187.237:1637)
. 2025.02.25 19:05:47 - WireGuard > Sending handshake response to peer 1 (213.152.187.237:1637)
. 2025.02.25 19:10:38 - WireGuard > Receiving handshake initiation from peer 1 (213.152.187.237:1637)
. 2025.02.25 19:10:38 - WireGuard > Sending handshake response to peer 1 (213.152.187.237:1637)
W 2025.02.25 19:11:39 - WireGuard > Handshake timeout
! 2025.02.25 19:11:39 - Disconnecting
. 2025.02.25 19:11:39 - WireGuard > Stop request received
. 2025.02.25 19:11:39 - WireGuard > Stopping
. 2025.02.25 19:11:40 - WireGuard > Completed
. 2025.02.25 19:11:40 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:11:41 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:11:41 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:11:41 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:11:41 - Routes, delete 213.152.187.237/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 19:11:42 - Routes, delete 213.152.187.235/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:11:42 - Routes, delete 2a00:1678:1337:7a26:b322:10c2:a77d:dee8/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:11:42 - Routes, delete 213.152.187.237/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 19:11:42 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 19:11:42 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 19:11:42 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 19:11:43 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 19:11:43 - DNS leak protection with packet filtering disabled.
. 2025.02.25 19:11:43 - Connection terminated.
. 2025.02.25 19:11:46 - Waiting for latency tests (253 to go)
. 2025.02.25 19:11:47 - Waiting for latency tests (5 to go)
I 2025.02.25 19:11:50 - Checking authorization ...
! 2025.02.25 19:11:50 - Connecting to Alshat (Netherlands, Alblasserdam)
. 2025.02.25 19:11:50 - Routes, add 213.152.161.7/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 19:11:51 - Routes, add 213.152.161.7/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 19:11:51 - WireGuard > Setup start
. 2025.02.25 19:11:53 - WireGuard > Setup complete
. 2025.02.25 19:11:53 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 19:11:53 - WireGuard > Watching network interfaces
. 2025.02.25 19:11:53 - WireGuard > Resolving DNS names
. 2025.02.25 19:11:53 - WireGuard > Creating network adapter
. 2025.02.25 19:11:53 - WireGuard > Using existing driver 0.10
. 2025.02.25 19:11:53 - WireGuard > Creating adapter
. 2025.02.25 19:11:53 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 19:11:53 - WireGuard > Eddie build 2
. 2025.02.25 19:11:53 - WireGuard > Dropping privileges
. 2025.02.25 19:11:53 - WireGuard > Interface created
. 2025.02.25 19:11:53 - WireGuard > Setup interface
. 2025.02.25 19:11:54 - WireGuard > Setting interface configuration
. 2025.02.25 19:11:54 - WireGuard > Peer 1 created
. 2025.02.25 19:11:54 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 19:11:54 - WireGuard > Interface up
. 2025.02.25 19:11:54 - WireGuard > Setting device v6 addresses
. 2025.02.25 19:11:54 - WireGuard > Received first handshake
. 2025.02.25 19:11:54 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 19:11:54 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 19:11:54 - DNS leak protection with packet filtering enabled.
. 2025.02.25 19:11:54 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 19:11:55 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 19:11:55 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 19:11:55 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 19:11:55 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:11:56 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:11:57 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:11:58 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:11:58 - Routes, add 213.152.161.5/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:11:59 - Routes, add 2a00:1678:2470:37:60d6:c17:8e33:94b0/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:11:59 - Flushing DNS
I 2025.02.25 19:11:59 - Checking route IPv4
I 2025.02.25 19:11:59 - Checking route IPv6
I 2025.02.25 19:12:00 - Checking DNS
! 2025.02.25 19:12:01 - Connected.
. 2025.02.25 19:12:01 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 19:12:01 - WireGuard > Setting device v4 addresses
. 2025.02.25 19:12:01 - WireGuard > Startup complete
. 2025.02.25 19:25:42 - Collect information about AirVPN completed
. 2025.02.25 19:40:18 - WireGuard > Receiving handshake initiation from peer 1 (213.152.161.7:1637)
. 2025.02.25 19:40:18 - WireGuard > Sending handshake response to peer 1 (213.152.161.7:1637)
W 2025.02.25 19:41:54 - WireGuard > Handshake timeout
! 2025.02.25 19:41:54 - Disconnecting
. 2025.02.25 19:41:54 - WireGuard > Stop request received
. 2025.02.25 19:41:54 - WireGuard > Stopping
. 2025.02.25 19:41:55 - WireGuard > Completed
. 2025.02.25 19:41:55 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:41:56 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:41:56 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:41:56 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:41:56 - Routes, delete 213.152.161.7/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 19:41:56 - Routes, delete 213.152.161.5/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:41:57 - Routes, delete 2a00:1678:2470:37:60d6:c17:8e33:94b0/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 19:41:57 - Routes, delete 213.152.161.7/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 19:41:57 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 19:41:57 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 19:41:57 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 19:41:57 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 19:41:57 - DNS leak protection with packet filtering disabled.
. 2025.02.25 19:41:58 - Connection terminated.
. 2025.02.25 19:42:01 - Waiting for latency tests (253 to go)
. 2025.02.25 19:42:03 - Waiting for latency tests (3 to go)
I 2025.02.25 19:42:05 - Checking authorization ...
! 2025.02.25 19:42:06 - Connecting to Alpheratz (Netherlands, Alblasserdam)
. 2025.02.25 19:42:06 - Routes, add 134.19.179.245/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 19:42:07 - Routes, add 134.19.179.245/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 19:42:07 - WireGuard > Setup start
. 2025.02.25 19:42:08 - WireGuard > Setup complete
. 2025.02.25 19:42:08 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 19:42:08 - WireGuard > Watching network interfaces
. 2025.02.25 19:42:08 - WireGuard > Resolving DNS names
. 2025.02.25 19:42:08 - WireGuard > Creating network adapter
. 2025.02.25 19:42:08 - WireGuard > Using existing driver 0.10
. 2025.02.25 19:42:08 - WireGuard > Creating adapter
. 2025.02.25 19:42:08 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 19:42:08 - WireGuard > Eddie build 2
. 2025.02.25 19:42:08 - WireGuard > Dropping privileges
. 2025.02.25 19:42:08 - WireGuard > Interface created
. 2025.02.25 19:42:08 - WireGuard > Setup interface
. 2025.02.25 19:42:08 - WireGuard > Setting interface configuration
. 2025.02.25 19:42:08 - WireGuard > Peer 1 created
. 2025.02.25 19:42:08 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 19:42:08 - WireGuard > Setting device v6 addresses
. 2025.02.25 19:42:08 - WireGuard > Interface up
. 2025.02.25 19:42:08 - WireGuard > Received first handshake
. 2025.02.25 19:42:08 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 19:42:08 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 19:42:09 - DNS leak protection with packet filtering enabled.
. 2025.02.25 19:42:09 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 19:42:09 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 19:42:09 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 19:42:09 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 19:42:10 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:42:11 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:42:14 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:42:14 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:42:16 - Routes, add 134.19.179.243/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:42:17 - Routes, add 2a00:1678:2470:1212:990e:c823:fcac:44b9/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 19:42:17 - Flushing DNS
I 2025.02.25 19:42:17 - Checking route IPv4
I 2025.02.25 19:42:18 - Checking route IPv6
I 2025.02.25 19:42:27 - Checking DNS
! 2025.02.25 19:42:36 - Connected.
. 2025.02.25 19:42:36 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 19:42:36 - WireGuard > Setting device v4 addresses
. 2025.02.25 19:42:36 - WireGuard > Startup complete
. 2025.02.25 19:54:28 - WireGuard > Handshake for peer 1 (134.19.179.245:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 19:55:48 - Collect information about AirVPN completed
. 2025.02.25 20:10:49 - WireGuard > Handshake for peer 1 (134.19.179.245:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 20:25:50 - Collect information about AirVPN completed
. 2025.02.25 20:42:20 - WireGuard > Receiving handshake initiation from peer 1 (134.19.179.245:1637)
. 2025.02.25 20:42:20 - WireGuard > Sending handshake response to peer 1 (134.19.179.245:1637)
. 2025.02.25 20:43:29 - WireGuard > Receiving handshake initiation from peer 1 (134.19.179.245:1637)
. 2025.02.25 20:43:29 - WireGuard > Sending handshake response to peer 1 (134.19.179.245:1637)
W 2025.02.25 20:44:30 - WireGuard > Handshake timeout
! 2025.02.25 20:44:30 - Disconnecting
. 2025.02.25 20:44:30 - WireGuard > Stop request received
. 2025.02.25 20:44:30 - WireGuard > Stopping
. 2025.02.25 20:44:33 - WireGuard > Completed
. 2025.02.25 20:44:34 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 20:44:34 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 20:44:34 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 20:44:34 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 20:44:34 - Routes, delete 134.19.179.245/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 20:44:35 - Routes, delete 134.19.179.243/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 20:44:35 - Routes, delete 2a00:1678:2470:1212:990e:c823:fcac:44b9/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 20:44:35 - Routes, delete 134.19.179.245/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 20:44:35 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 20:44:35 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 20:44:36 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 20:44:36 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 20:44:36 - DNS leak protection with packet filtering disabled.
. 2025.02.25 20:44:36 - Connection terminated.
. 2025.02.25 20:44:39 - Waiting for latency tests (253 to go)
. 2025.02.25 20:44:40 - Waiting for latency tests (191 to go)
. 2025.02.25 20:44:41 - Waiting for latency tests (4 to go)
I 2025.02.25 20:44:44 - Checking authorization ...
! 2025.02.25 20:44:44 - Connecting to Suhail (Netherlands, Alblasserdam)
. 2025.02.25 20:44:45 - Routes, add 134.19.179.189/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 20:44:45 - Routes, add 134.19.179.189/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 20:44:45 - WireGuard > Setup start
. 2025.02.25 20:44:46 - WireGuard > Setup complete
. 2025.02.25 20:44:46 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 20:44:46 - WireGuard > Watching network interfaces
. 2025.02.25 20:44:46 - WireGuard > Resolving DNS names
. 2025.02.25 20:44:46 - WireGuard > Creating network adapter
. 2025.02.25 20:44:46 - WireGuard > Using existing driver 0.10
. 2025.02.25 20:44:46 - WireGuard > Creating adapter
. 2025.02.25 20:44:46 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 20:44:46 - WireGuard > Eddie build 2
. 2025.02.25 20:44:46 - WireGuard > Dropping privileges
. 2025.02.25 20:44:46 - WireGuard > Interface created
. 2025.02.25 20:44:46 - WireGuard > Setup interface
. 2025.02.25 20:44:46 - WireGuard > Setting interface configuration
. 2025.02.25 20:44:46 - WireGuard > Peer 1 created
. 2025.02.25 20:44:46 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 20:44:46 - WireGuard > Setting device v6 addresses
. 2025.02.25 20:44:46 - WireGuard > Interface up
. 2025.02.25 20:44:46 - WireGuard > Received first handshake
. 2025.02.25 20:44:47 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 20:44:47 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 20:44:47 - DNS leak protection with packet filtering enabled.
. 2025.02.25 20:44:47 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 20:44:47 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 20:44:47 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 20:44:48 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 20:44:48 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 20:44:49 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 20:44:49 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 20:44:50 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 20:44:51 - Routes, add 134.19.179.187/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 20:44:51 - Routes, add 2a00:1678:2470:1001:63f4:41:52a6:8a00/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 20:44:51 - Flushing DNS
I 2025.02.25 20:44:51 - Checking route IPv4
I 2025.02.25 20:44:52 - Checking route IPv6
I 2025.02.25 20:44:53 - Checking DNS
! 2025.02.25 20:44:53 - Connected.
. 2025.02.25 20:44:53 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 20:44:53 - WireGuard > Setting device v4 addresses
. 2025.02.25 20:44:53 - WireGuard > Startup complete
. 2025.02.25 20:55:59 - Collect information about AirVPN completed
. 2025.02.25 21:07:17 - WireGuard > Handshake for peer 1 (134.19.179.189:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 21:26:11 - Collect information about AirVPN completed
. 2025.02.25 21:55:39 - WireGuard > Retrying handshake with peer 1 (134.19.179.189:1637) because we stopped hearing back after 15 seconds
. 2025.02.25 21:55:44 - WireGuard > Handshake for peer 1 (134.19.179.189:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 21:56:18 - Collect information about AirVPN completed
. 2025.02.25 22:26:23 - Collect information about AirVPN completed
. 2025.02.25 22:51:23 - WireGuard > Receiving handshake initiation from peer 1 (134.19.179.189:1637)
. 2025.02.25 22:51:23 - WireGuard > Sending handshake response to peer 1 (134.19.179.189:1637)
. 2025.02.25 22:53:23 - WireGuard > Receiving handshake initiation from peer 1 (134.19.179.189:1637)
. 2025.02.25 22:53:23 - WireGuard > Sending handshake response to peer 1 (134.19.179.189:1637)
W 2025.02.25 22:53:41 - WireGuard > Handshake timeout
! 2025.02.25 22:53:41 - Disconnecting
. 2025.02.25 22:53:41 - WireGuard > Stop request received
. 2025.02.25 22:53:41 - WireGuard > Stopping
. 2025.02.25 22:53:42 - WireGuard > Completed
. 2025.02.25 22:53:43 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 22:53:43 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 22:53:43 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 22:53:43 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 22:53:44 - Routes, delete 134.19.179.189/32 for interface "Ethernet (Realtek USB GbE Family Controller)", not exists.
. 2025.02.25 22:53:44 - Routes, delete 134.19.179.187/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 22:53:44 - Routes, delete 2a00:1678:2470:1001:63f4:41:52a6:8a00/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 22:53:45 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 22:53:45 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 22:53:45 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 22:53:45 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 22:53:45 - DNS leak protection with packet filtering disabled.
. 2025.02.25 22:53:45 - Connection terminated.
. 2025.02.25 22:53:48 - Waiting for latency tests (253 to go)
. 2025.02.25 22:53:51 - Waiting for latency tests (5 to go)
I 2025.02.25 22:53:53 - Checking authorization ...
! 2025.02.25 22:53:53 - Connecting to Orion (Netherlands, Alblasserdam)
. 2025.02.25 22:53:54 - Routes, add 213.152.161.241/32 for interface "Ethernet (Realtek USB GbE Family Controller)".
. 2025.02.25 22:53:54 - Routes, add 213.152.161.241/32 for interface "Ethernet (Realtek USB GbE Family Controller)", already exists.
. 2025.02.25 22:53:54 - WireGuard > Setup start
. 2025.02.25 22:53:55 - WireGuard > Setup complete
. 2025.02.25 22:53:55 - WireGuard > Starting WireGuard/0.5.2 (Windows 10.0.26100; amd64)
. 2025.02.25 22:53:55 - WireGuard > Watching network interfaces
. 2025.02.25 22:53:55 - WireGuard > Resolving DNS names
. 2025.02.25 22:53:55 - WireGuard > Creating network adapter
. 2025.02.25 22:53:55 - WireGuard > Using existing driver 0.10
. 2025.02.25 22:53:55 - WireGuard > Creating adapter
. 2025.02.25 22:53:55 - WireGuard > Using WireGuardNT/0.10
. 2025.02.25 22:53:55 - WireGuard > Eddie build 2
. 2025.02.25 22:53:55 - WireGuard > Dropping privileges
. 2025.02.25 22:53:55 - WireGuard > Interface created
. 2025.02.25 22:53:55 - WireGuard > Setup interface
. 2025.02.25 22:53:56 - WireGuard > Setting interface configuration
. 2025.02.25 22:53:56 - WireGuard > Peer 1 created
. 2025.02.25 22:53:56 - WireGuard > Monitoring MTU of default v6 routes
. 2025.02.25 22:53:56 - WireGuard > Interface up
. 2025.02.25 22:53:56 - WireGuard > Setting device v6 addresses
. 2025.02.25 22:53:56 - WireGuard > Received first handshake
. 2025.02.25 22:53:56 - Interface Eddie metric changed from Automatic to 3, layer IPv4
. 2025.02.25 22:53:56 - Interface Eddie metric changed from Automatic to 3, layer IPv6
. 2025.02.25 22:53:56 - DNS leak protection with packet filtering enabled.
. 2025.02.25 22:53:57 - DNS IPv4 of a network adapter forced (Eddie, from automatic to 10.128.0.1)
. 2025.02.25 22:53:57 - DNS IPv6 of a network adapter forced (Eddie, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 22:53:57 - DNS IPv4 of a network adapter forced (Ethernet, from automatic to 10.128.0.1)
. 2025.02.25 22:53:57 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fd7d:76ee:e68f:a993::1)
. 2025.02.25 22:53:58 - Routes, add 0.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 22:53:59 - Routes, add 128.0.0.0/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 22:53:59 - Routes, add ::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 22:54:00 - Routes, add 8000::/1 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 22:54:01 - Routes, add 213.152.161.240/32 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 22:54:01 - Routes, add 2a00:1678:2470:48:f42c:a766:986e:eab1/128 for interface "Eddie (WireGuard Tunnel)".
. 2025.02.25 22:54:01 - Flushing DNS
I 2025.02.25 22:54:01 - Checking route IPv4
I 2025.02.25 22:54:02 - Checking route IPv6
I 2025.02.25 22:54:03 - Checking DNS
! 2025.02.25 22:54:03 - Connected.
. 2025.02.25 22:54:03 - WireGuard > Monitoring MTU of default v4 routes
. 2025.02.25 22:54:03 - WireGuard > Setting device v4 addresses
. 2025.02.25 22:54:03 - WireGuard > Startup complete
. 2025.02.25 22:56:27 - Collect information about AirVPN completed
. 2025.02.25 23:23:50 - WireGuard > Retrying handshake with peer 1 (213.152.161.241:1637) because we stopped hearing back after 15 seconds
. 2025.02.25 23:23:55 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 23:24:00 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 3)
. 2025.02.25 23:24:05 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 4)
. 2025.02.25 23:24:10 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 5)
. 2025.02.25 23:24:36 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 23:24:51 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 23:24:56 - WireGuard > Handshake for peer 1 (213.152.161.241:1637) did not complete after 5 seconds, retrying (try 2)
. 2025.02.25 23:25:32 - Above log line repeated 1 times more
W 2025.02.25 23:25:32 - WireGuard > Handshake timeout
! 2025.02.25 23:25:32 - Disconnecting
. 2025.02.25 23:25:32 - WireGuard > Stop request received
. 2025.02.25 23:25:32 - WireGuard > Stopping
. 2025.02.25 23:25:33 - WireGuard > Completed
. 2025.02.25 23:25:34 - Routes, delete 0.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 23:25:34 - Routes, delete 128.0.0.0/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 23:25:34 - Routes, delete ::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 23:25:34 - Routes, delete 8000::/1 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 23:25:34 - Routes, delete 213.152.161.241/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}", not exists.
. 2025.02.25 23:25:34 - Routes, delete 213.152.161.240/32 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 23:25:34 - Routes, delete 2a00:1678:2470:48:f42c:a766:986e:eab1/128 for interface "{7CB6D269-0786-7E57-C13F-6CDFFF02FB02}", not exists.
. 2025.02.25 23:25:35 - Routes, delete 213.152.161.241/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}", not exists.
. 2025.02.25 23:25:35 - DNS IPv4 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 23:25:35 - DNS IPv6 of a network adapter restored to original settings (Eddie, to automatic)
. 2025.02.25 23:25:35 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 23:25:35 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic)
. 2025.02.25 23:25:35 - DNS leak protection with packet filtering disabled.
. 2025.02.25 23:25:35 - Connection terminated.
. 2025.02.25 23:25:38 - Waiting for latency tests (253 to go)
I 2025.02.25 23:25:40 - Checking authorization ...
W 2025.02.25 23:25:40 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:25:40 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:25:44 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:25:44 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:25:44 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:25:47 - Checking authorization ...
W 2025.02.25 23:25:48 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:25:48 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:25:48 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:25:48 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:25:48 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:25:51 - Checking authorization ...
W 2025.02.25 23:25:52 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:25:52 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:25:52 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:25:52 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:25:52 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:25:55 - Checking authorization ...
W 2025.02.25 23:25:56 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:25:56 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:25:56 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:25:56 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:25:56 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:25:59 - Checking authorization ...
W 2025.02.25 23:26:00 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:26:00 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:26:00 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:26:00 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:26:00 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:26:03 - Checking authorization ...
W 2025.02.25 23:26:04 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:26:04 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:26:04 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:26:04 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:26:04 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:26:07 - Checking authorization ...
W 2025.02.25 23:26:08 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:26:08 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:26:08 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:26:08 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:26:08 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:26:11 - Checking authorization ...
W 2025.02.25 23:26:11 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:26:11 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:26:12 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:26:12 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:26:12 -     bei Eddie.Core.Session.OnRun()
I 2025.02.25 23:26:15 - Checking authorization ...
W 2025.02.25 23:26:15 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:26:15 - Connecting to Canis (Netherlands, Alblasserdam)
E 2025.02.25 23:26:16 - Fatal error occured, please contact Eddie support: Routes, add 213.152.161.221/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:26:16 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:26:16 -     bei Eddie.Core.Session.OnRun()
. 2025.02.25 23:26:19 - Flushing DNS
! 2025.02.25 23:26:19 - Session terminated.
. 2025.02.25 23:26:34 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
. 2025.02.25 23:26:47 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
. 2025.02.25 23:26:49 - Cannot retrieve information about AirVPN: Fetch url error:Couldn't connect to server
I 2025.02.25 23:27:48 - Session starting.
I 2025.02.25 23:27:49 - Checking authorization ...
W 2025.02.25 23:27:49 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:27:49 - Connecting to Achernar (Switzerland, Zurich)
E 2025.02.25 23:27:49 - Fatal error occured, please contact Eddie support: Routes, add 185.156.175.173/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:27:49 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:27:49 -     bei Eddie.Core.Session.OnRun()
E 2025.02.25 23:27:49 - Failed to start.
! 2025.02.25 23:27:50 - Session terminated.
I 2025.02.25 23:27:53 - Session starting.
I 2025.02.25 23:27:54 - Checking authorization ...
W 2025.02.25 23:27:55 - Authorization check failed, continue anyway (Fetch url error:Couldn't connect to server)
! 2025.02.25 23:27:55 - Connecting to Achernar (Switzerland, Zurich)
E 2025.02.25 23:27:55 - Fatal error occured, please contact Eddie support: Routes, add 185.156.175.173/32 for interface "{99D8C5CF-9B54-4527-9249-110A4D4AD829}" failed: Network interface no more available. -    bei Eddie.Core.Platform.Route(Json jRoute, String action)
E 2025.02.25 23:27:55 -     bei Eddie.Core.Session.RoutesApply(String phase)
E 2025.02.25 23:27:55 -     bei Eddie.Core.Session.OnRun()
E 2025.02.25 23:27:55 - Failed to start.
! 2025.02.25 23:27:55 - Session terminated.
Network Interfaces and Routes:
    "routes": [
            "destination": "127.0.0.0\/8",
            "gateway": "0.0.0.0",
            "interface_index": 1,
            "metric": 256,
            "interface": "{BF4FD158-008D-11EB-AA39-806E6F6E6963}"
            "destination": "127.0.0.1\/32",
            "metric": 256,
            "destination": "127.255.255.255\/32",
            "metric": 256,
            "destination": "224.0.0.0\/4",
            "metric": 256,
            "interface_index": 3,
            "metric": 256,
            "interface": "{17E2E4BE-3288-4268-BA9B-0D89910D28F1}"
            "interface_index": 15,
            "metric": 256,
            "interface": "{B8EE5E50-6B16-4F74-94F2-BE47BDAFC238}"
            "interface_index": 4,
            "metric": 256,
            "interface": "{18CC6170-82F2-4F10-B789-3510BE07F030}"
            "destination": "255.255.255.255\/32",
            "metric": 256,
            "metric": 256,
            "metric": 256,
            "metric": 256,
            "destination": "::1\/128",
            "gateway": "::",
            "metric": 256,
            "destination": "fe80::\/64",
            "gateway": "::",
            "metric": 256,
            "gateway": "::",
            "metric": 256,
            "gateway": "::",
            "metric": 256,
            "destination": "fe80::5196:8d4b:a80b:1662\/128",
            "gateway": "::",
            "metric": 256,
            "destination": "fe80::a72d:8750:b8e7:9055\/128",
            "gateway": "::",
            "metric": 256,
            "destination": "fe80::c97d:ad08:753c:a503\/128",
            "gateway": "::",
            "metric": 256,
            "destination": "ff00::\/8",
            "gateway": "::",
            "metric": 256,
            "gateway": "::",
            "metric": 256,
            "gateway": "::",
            "metric": 256,
            "gateway": "::",
            "metric": 256,
    "interfaces": [
            "friendly": "WLAN",
            "id": "{17E2E4BE-3288-4268-BA9B-0D89910D28F1}",
            "name": "WLAN",
            "description": "Intel(R) Wireless-AC 9560 160MHz",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "support_ipv4": true,
            "support_ipv6": true,
            "ips": [
                "fe80::a72d:8750:b8e7:9055",
                "169.254.31.96"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "LAN-Verbindung* 1",
            "id": "{B8EE5E50-6B16-4F74-94F2-BE47BDAFC238}",
            "name": "LAN-Verbindung* 1",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::5196:8d4b:a80b:1662",
                "169.254.25.90"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "LAN-Verbindung* 2",
            "id": "{18CC6170-82F2-4F10-B789-3510BE07F030}",
            "name": "LAN-Verbindung* 2",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter #2",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::c97d:ad08:753c:a503",
                "169.254.242.149"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{BF4FD158-008D-11EB-AA39-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "bind": true,
            "dns4": "",
            "dns6": null
ipconfig /all:
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : DESKTOP-CSASFGO
   Prim„res DNS-Suffix . . . . . . . :
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
Drahtlos-LAN-Adapter WLAN:
   Medienstatus. . . . . . . . . . . : Medium getrennt
   Verbindungsspezifisches DNS-Suffix: eduroam.helsinki.fi
   Beschreibung. . . . . . . . . . . : Intel(R) Wireless-AC 9560 160MHz
   Physische Adresse . . . . . . . . : 64-5D-86-B8-E6-42
   DHCP aktiviert. . . . . . . . . . : Ja
   Autokonfiguration aktiviert . . . : Ja
Drahtlos-LAN-Adapter LAN-Verbindung* 1:
   Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physische Adresse . . . . . . . . : 64-5D-86-B8-E6-43
Drahtlos-LAN-Adapter LAN-Verbindung* 2:
   Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physische Adresse . . . . . . . . : 66-5D-86-B8-E6-42
   DHCP aktiviert. . . . . . . . . . : Nein
Edited ... by OpenSourcerer
Apply LOG format to system report
Have you tried temporarily disabling 'Network lock' and connecting to see if it makes any difference?
Then also temporarily - try OpenVPN TCP (it is typically slower than UDP but may actually give better results if the internet connection isn't stable):
Next, the report shows you're on the old Eddie version 2.21.8. There is a new stable 2.24.6 (https://airvpn.org/windows/)
If you decide to upgrade please consider factory resetting Eddie (this will log you out and reset all the preferences):
- Disconnect and close Eddie (fully, not to system tray).
- Click on start (Windows icon) and paste %localappdata%\Eddie
- In that folder you'll find a file named:
  Remove it or cut-paste to some different location.
- Eddie will start with default settings
Lastly you could try renewing device key:
- Go to https://airvpn.org/devices/
- Click on 'Details'
- Then click 'Renew'
- Inside Eddie go to the main tab 'Overview', click 'Logout' and 'Login' (this step is really important for Eddie to download the renewed cert)
I will give these a shot, thank you so much!
