Not connected, Your IP: 216.73.217.138
wheels83
Eddie cli questions
I've been testing Eddie-Cli 2.24.0.0  It's very cool!  I'm able to connect just fine and everything sees to work perfectly.  I did have a few questions about it, even after reading the eddie.website guides.
  1. Does --netlock=true use the WFP by default? I ask because I'm not seeing the difference between --netlock.mode=Windows Filtering Platform and  --windows.wfp.enable=true, and I wondered if I even need both of them.
  2. What is the CLI switch that forces all adapters to use the given DNS?  Is it windows.dns.lock?
  3. I'm pretty sure this is a Windows issue and not so much and Eddie-Cli issue, but I thought I'd ask anyway.  Is there a way to minimize the command line to the system tray, so that the windows command line doesn't need to be open all the time?  I've added "if not DEFINED IS_MINIMIZED set IS_MINIMIZED=1 && start "" /min "%~dpnx0" %* && exit" to the beginning of my .bat file, but that just minimizes it the taskbar.  Better than nothing I suppose, but still.
  4. Lastly, is there a way to identify what device you're using, so DNS filtering purposed.  I know you can in the GUI version, I just don't see that in the cli switches.
  5. Why does the CLI version have icons in its \Resources\icons folder if it doesn't use them?3
Thanks!
