kityafnsd 3 Posted ... Hello there! If this doesn't belong here, please delete and I'll get the idea lol I'm new to AirVPN and Eddie -- but running into some issues with getting connected for the first time. Ultimately I'll be looking to take advantage of some of the more advanced features and will likely be using the CLI anyways depending on what docs / help I'm able to find, but I've been having issues with eddie's UI being too small, the cli running indefinitely, and i'm just not sure if this is picture or description are as expected? maybe I just need to adjust a few things on my screen/mybrain Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... Erm, what's your resolution and DPI settings? Or, you know, just inxi the info. $ inxi -Sxxx -Gxx -I --za . Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
kityafnsd 3 Posted ... (edited) Hi, Thanks for the response, @OpenSourcerer - I've come across your name many times in these forums so far. This has mostly been resolved! The bulk of my issue was that I was 1, using moonlight to view the desktop, and 2, I have not so great vision... and 3, I am using a slightly lower quality HDMI to my ubuntu machine cause I mostly am using it as a server. I use moonlight/sunshine instead of RDP because I find it easier to use with pretty much any OS. Since all my pc's are all on an eth connection I can get super low latency, high fps when I want it. Normally there is close to no difference between the physically connected monitor but when I checked on the same monitor to be sure it was mostly larger. Here is my output on the resolution : Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43") s-diag: 804mm (31.65") Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 140 size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A The long version: System: Kernel: 6.8.0-48-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0 clocksource: tsc Desktop: GNOME v: 46.0 tk: GTK v: 3.24.41 wm: gnome-shell tools: gsd-screensaver-proxy dm: GDM3 v: 46.0 Distro: Ubuntu 24.04.1 LTS (Noble Numbat) Graphics: Device-1: NVIDIA GA104 [GeForce RTX 3070 Lite Hash Rate] vendor: Gigabyte driver: nvidia v: 550.120 arch: Ampere pcie: speed: 8 GT/s lanes: 16 ports: active: none off: HDMI-A-1 empty: DP-1,DP-2,HDMI-A-2 bus-ID: 09:00.0 chip-ID: 10de:2488 class-ID: 0300 Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1 Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43") s-diag: 804mm (31.65") Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 140 size: 697x392mm (27.44x15.43") diag: 800mm (31.48") modes: N/A API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1 API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120 glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 Info: Memory: total: 32 GiB available: 31.22 GiB used: 6.1 GiB (19.5%) Processes: 563 Power: uptime: 2d 4h 15m states: freeze,mem,disk suspend: deep wakeups: 0 hibernate: platform Init: systemd v: 255 default: graphical Packages: 2787 pm: dpkg pkgs: 2754 pm: snap pkgs: 33 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 running-in: gnome-terminal inxi: 3.3.34 gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1 Edited ... by kityafnsd added an image of the screenshot from the hdmi connection Quote Share this post Link to post
kityafnsd 3 Posted ... Just wanted to follow up that I'm pretty sure that the reason for the small UI was mostly due to the resolution that was set on the client computer, not necessarily the host computer. The moonlight app lets you set a resolution in addition to the resolution that you can change on the host computer. This is useful for doing weird "picture in picture" things I like to spend way too much time configuring! Quote Share this post Link to post
