Bo5cT4Pp
ANSWERED VPN Disconnection Issues on Synology NAS: Port Forwarding Loss and Unstable Connection
Hello everyone,
I’m facing an issue with my current setup and would appreciate your help.
Here’s my configuration:
    •    NAS Synology, DSM 7.2.2
    •    OpenVPN profile set up in the network interface
    •    I followed this tutorial for the setup: (How-to: AirVPN on Synology DSM6 and DSM7 complete guide)
    •    Port forwarding works fine with Download Station
For several weeks now, I’ve been experiencing frequent VPN disconnections without any clear explanation. For over a year, I didn’t have any issues—my sessions were stable for weeks or even months. However, recently, my connections keep dropping, and I lose port forwarding. Oddly, on the AirVPN “Session” page, the connection still appears active. On the port forwarding page, I get the error “Connection timed out 110.”
In DSM, the default gateway switches to LAN when the connection drops, even though the network interface shows that I’m still connected.
I’ve tried changing servers and updating everything, but the problem persists. This is quite frustrating because when the connection drops, port forwarding with Download Station becomes ineffective, leaving me unprotected.
If anyone has any ideas or solutions, I’d greatly appreciate your input.
Thanks in advance for your help!
Same here. I'm getting crazy, dunno what's going on, I'm facing your same experience.
The VPN gateway literally disappears after a while connection is running.
Edited ... by silxx
I'm relieved to know that I'm not the only one with the same problem. I've tried everything, but I don't know where it could be coming from, AirVPN or DSM7.
On 10/16/2024 at 6:01 PM, Bo5cT4Pp said:
Hello everyone,
I'm having the exact same issue with my VPN setup using NordVPN.  Started right after DSM 7.2.2 update.  Contacted Synology support, sent them my logs and they said they saw errors relating to the 7.2.2 update.  They want to remote into my server to investigate further.
Not finding a solution, I decided to change the configuration. I switched to Container Manager with WireGuard. I no longer have any issues.
Thank you anyway for your response.
Hi
Someone give me an answer, there is a probleme with the update
you have to edit /usr/syno/etc.defaults/synovpnclient/scripts/ovpnc.sh
and change with this
Quote
#!/bin/sh
# Startup script for openvpn client
CONF_DIR="/usr/syno/etc/synovpnclient/openvpn"
OPENVPN_CONF="$2"
IPTABLES_MODULE_LIST="/usr/syno/etc.defaults/iptables_modules_list"
OVPNC_MODULES="tun.ko"
SERVICE="ovpnc"
BIN_IPTABLESTOOL="/usr/syno/bin/iptablestool"
BIN_SYNOMODULETOOL="/usr/syno/bin/synomoduletool"
SYNONETD_TOOL="/usr/syno/sbin/synonetdtool"
VPNC_CURRENT="/tmp/vpnc_current"
. ${IPTABLES_MODULE_LIST}
Ovpnc_Mod=""
for mod in $KERNEL_MODULES_CORE; do
	if [ -e "/lib/modules/$mod" ]; then
		Ovpnc_Mod="${Ovpnc_Mod} ${mod}"
	fi
done
for mod in $KERNEL_MODULES_COMMON; do
	fi
done
for mod in $KERNEL_MODULES_NAT; do
	fi
done
for mod in $IPV6_MODULES; do
	fi
done
for mod in $OPENVPN_MODULES; do
	fi
done
reverse_modules() {
	local modules=$1
	local mod
	local ret=""
	for mod in $modules; do
	    ret="$mod $ret"
	done
	echo $ret
load_module() {
	local service=$1
	if [ -x ${BIN_SYNOMODULETOOL} ]; then
		${BIN_SYNOMODULETOOL} --insmod ${service} ${Ovpnc_Mod}
	elif [ -x ${BIN_IPTABLESTOOL} ]; then
		${BIN_IPTABLESTOOL} --insmod ${service} ${Ovpnc_Mod}
	fi
unload_module() {
	local service=$1
	local modules=`reverse_modules "${Ovpnc_Mod}"`
		${BIN_SYNOMODULETOOL} --rmmod ${service} $modules
		${BIN_IPTABLESTOOL} --rmmod ${service} $modules
	fi
del_gateway_info() {
	local ifname=`/usr/syno/bin/get_section_key_value ${VPNC_CURRENT} curr_info if`
	logger -p user.err -t "ovpnc.sh" "${ifname} is down"
	${SYNONETD_TOOL} --del-gateway-info -4 ${ifname}
	${SYNONETD_TOOL} --del-gateway-info -6 ${ifname}
	${SYNONETD_TOOL} --refresh-gateway all
	local enable_multi_gateway=`/bin/get_key_value /etc/synoinfo.conf multi_gateway`
	if [ "xyes" = "x${enable_multi_gateway}" ]; then
		${SYNONETD_TOOL} --del-policy-route-rule -4 multi-gateway ${ifname}
		${SYNONETD_TOOL} --disable-route-table -4 ${ifname}
		${SYNONETD_TOOL} --del-policy-route-rule -6 multi-gateway ${ifname}
		${SYNONETD_TOOL} --disable-route-table -6 ${ifname}
	fi
case "$1" in
  start)
	echo 1 > /proc/sys/net/ipv4/ip_forward
	# Make device if not present (not devfs)
	if [ ! -c /dev/net/tun ]; then
  		# Make /dev/net directory if needed
  		if [ ! -d /dev/net ]; then
        		mkdir -m 755 /dev/net
  		fi
  		mknod /dev/net/tun c 10 200
	fi
	load_module ${SERVICE}
        echo "Starting openvpn client..."
	/usr/sbin/openvpn --daemon --cd ${CONF_DIR} --config ${OPENVPN_CONF} --writepid /var/run/ovpn_client.pid
  stop)
        echo "Stopping openvpn client..."
        /bin/kill `cat /var/run/ovpn_client.pid` 2>/dev/null
		del_gateway_info
	#sleep 2
	#unload_module ${SERVICE}
	unload)
		service=${SERVICE}
		if [ -n "$2" ]; then
			service=$2
		fi
		#unload_module ${service}
  load)
	service=${SERVICE}
		service=$2
	fi
        echo "Usage: $0 {start conf|stop}"
        exit 1
esac
exit 0
# [EOF]
KingKong32 you're my saviour! Thank you so much!!!! It works!
Gonna block dsm updates for loooooong time!!!
Edited ... by silxx
With pleasure !
Hi, What configuration is this "I switched to Container Manager with WireGuard"? Do you use Docker containers? I tried some with Gluetun and a aMule docker container. Did work but has many manual work. Please share.
On 11/23/2024 at 5:51 PM, kingkong32 said:
Hi
this sounds like exactly the problem I am facing too… can someone please explain how to edit ovpnc.sh?
