Hello
For several months I have been using AirVPN on my Windows 10 machine.
Before the PC started and AirVPN launched without problem.
Since a Windows update some time ago (https://www.it-connect.fr/microsoft-windows-vpn-ne-fonctionne-plus-mise-a-jour-avril-2024/) most of the time AirVPN blocks. I have to launch the task manager and stop the "OpenVPN Daemon" process so that it continues to start.
I have of course done all the Windows updates since then but that did not solve the problem. I also tried to follow the procedure indicated in the article above but I cannot find the offending KB. I also tried to uninstall and reinstall AirVPN but that did not solve anything.
Has anyone found the solution?
Thank you very much! 😉
