Melimelo
Timed out with a tracker url
It's impossible to connect to a specific tracker url, there is a "timed out".
When I try with a web brower without VPN the tracker respond correctly.
I changed AirVPN server several time, always "timed out".
All was fine few days ago
"Certain tracker url" is no basis for getting help, you know. :) You must name it, then people can check on their side.
Hmm,
If you don't want to share the tracker URL try pinging the  hostname/ip (without 'udp://' 'http://' etc, port number, and anything after it).
You can check it on all AirVPN servers by pasting the hostname here:
https://airvpn.org/routes/ (wait about a minute and refresh to get the results)
1 hour ago, matts9 said:
Hmm,
Most pings are ok.
All HTTP are "Fail (no connect)"
On 6/23/2024 at 5:50 PM, Melimelo said:
When I tried to open the link in browser while connected to AirVPN (NL server) it returned this:
d14:failure reason18:Malformed announce12:min intervali5400e8:intervali5400ee
which indicates that it's not a hard block 🤔. It looks to be a private tracker so that's dead end for me. Maybe someone else here has account with that tracker and can confirm
You can try with the website https://*********
It doesn't work as soon Airvpn is used.
I asked to the site's sysop there is no blacklist for any NL airvpn server ip.
I'm facing the same exact problem.
All other trackers seems fine with .torrents in green.
But only with the HDF tracker the error message remains the same: " Tracker: [Timed out] ". All .torrents in red.
