Not connected, Your IP: 216.73.216.85
bujuwolla
Eddie-UI won't connect successfully.
Eddie-UI won't connect successfully. Below is the cycle dialogue:-
Restart n 3 sec, 2 sec, 1 sec, checking authorisation, Connecting to ..., Disconnecting, Restart in 3 sec (The cycles continues and not ending)
I'm having the same problem.
Though it was unresponsive for a long time with a couple of reboots before I even got that far
Log below
. 2024.06.18 19:05:54 - Eddie version: 2.21.8 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.19045.0, Mono/.Net: v4.0.30319
. 2024.06.18 19:05:55 - Reading options from C:\Users\Peter\AppData\Local\Eddie\default.profile
. 2024.06.18 19:05:59 - OpenVPN - Version: 2.5.5 - OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10 (C:\My Program Files\Internet\AirVPN\openvpn.exe)
. 2024.06.18 19:05:59 - SSH - Version: plink 0.73 (C:\My Program Files\Internet\AirVPN\plink.exe)
. 2024.06.18 19:05:59 - SSL - Version: stunnel 5.56 (C:\My Program Files\Internet\AirVPN\stunnel.exe)
. 2024.06.18 19:05:59 - Recovery. Unexpected crash?
! 2024.06.18 19:05:59 - Deactivation of Network Lock
! 2024.06.18 19:05:59 - Activation of Network Lock - Windows Filtering Platform
I 2024.06.18 19:06:00 - Ready
. 2024.06.18 19:07:01 - Collect information about AirVPN completed
I 2024.06.18 19:07:02 - Session starting.
I 2024.06.18 19:07:02 - Checking authorization ...
! 2024.06.18 19:07:03 - Logged out.
. 2024.06.18 19:07:23 - Checking authorization ..., 1° try failed (Fetch url error:Timeout was reached)
. 2024.06.18 19:07:26 - Added new network interface "VM", Wintun version 0.12
. 2024.06.18 19:07:26 - Using WinTun network interface "VM (Eddie Tunnel #2)"
! 2024.06.18 19:07:26 - Connecting to Sham (Canada, Vancouver)
. 2024.06.18 19:07:26 - Routes, add 192.30.89.77/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)".
. 2024.06.18 19:07:26 - Routes, add 192.30.89.77/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)", already exists.
W 2024.06.18 19:07:27 - OpenVPN > Options error: You must define CA file (--ca) or CA path (--capath)
! 2024.06.18 19:07:27 - Disconnecting
. 2024.06.18 19:07:27 - Routes, delete 192.30.89.77/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)".
. 2024.06.18 19:07:27 - Routes, delete 192.30.89.77/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)", not exists.
. 2024.06.18 19:07:27 - Connection terminated.
I 2024.06.18 19:07:30 - Checking authorization ...
. 2024.06.18 19:07:52 - Using WinTun network interface "VM (Eddie Tunnel #2)"
! 2024.06.18 19:07:52 - Connecting to Agena (Canada, Toronto, Ontario)
. 2024.06.18 19:07:53 - Routes, add 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)".
. 2024.06.18 19:07:53 - Routes, add 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)", already exists.
W 2024.06.18 19:07:53 - OpenVPN > Options error: You must define CA file (--ca) or CA path (--capath)
! 2024.06.18 19:07:53 - Disconnecting
. 2024.06.18 19:07:53 - Routes, delete 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)".
. 2024.06.18 19:07:53 - Routes, delete 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)", not exists.
. 2024.06.18 19:07:53 - Connection terminated.
I 2024.06.18 19:07:56 - Checking authorization ...
. 2024.06.18 19:07:58 - Using WinTun network interface "VM (Eddie Tunnel #2)"
! 2024.06.18 19:07:58 - Connecting to Agena (Canada, Toronto, Ontario)
. 2024.06.18 19:07:58 - Routes, add 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)".
. 2024.06.18 19:07:58 - Routes, add 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)", already exists.
W 2024.06.18 19:07:58 - OpenVPN > Options error: You must define CA file (--ca) or CA path (--capath)
! 2024.06.18 19:07:58 - Disconnecting
. 2024.06.18 19:07:59 - Routes, delete 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)".
. 2024.06.18 19:07:59 - Routes, delete 184.75.223.213/32 for interface "Local Area Connection (Intel(R) 82574L Gigabit Network Connection)", not exists.
. 2024.06.18 19:07:59 - Connection terminated.
I 2024.06.18 19:08:02 - Checking authorization ...
You don't have the same problem, seeing as you don't even know whether OP gets the same error message. Open your own threads for your own problems, people.
Mr. bujuwolla, please try a connection, then provide a system report..
