yayaca 0 Posted ... Hello 1. I have Eddie installed and configured (it's working) 2. I have Open VPN Gui installed and working (it's working) When I use connect to a server from Eddie it's working fine When I Use Connect from Open VPN it works fine as well but How can I connect a VPN and use a networklock simultaneously? IN eddie I can either choose to connect or to lock network - it confuses me a lot. Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... Opening your own threads for your own issues is encouraged, don't just answer in an old thread with a seemingly similar question. Instead, link to other threads if needed. On 5/19/2024 at 9:14 AM, yayaca said: How can I connect a VPN and use a networklock simultaneously? IN eddie I can either choose to connect or to lock network - it confuses me a lot. Network Lock can be used with other VPN software, it's just not recommended. Or rather, there are little test cases. So use Eddie. Having written that, Network Lock is engaged automatically upon connection when using Eddie. You can engage it manually by clicking the appropriate button and then connect manually after that. Not quite sure what you mean with "either this or that", you can connect with or without NetLock. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
yayaca 0 Posted ... Thank you! I did all wrong then. I have installed OpenVPN, following some guides I found useful... first I used to run the open VPN from the tray and then lock in Eddie So, to be exact, what I need is EDDIE only! Lock, and after that connect, and that's it. Right? No open VPN is involved. Can I uninstall it then? Runs smoothly right now and the kill switch is active. Fantastic. Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... On 5/20/2024 at 5:59 PM, yayaca said: Lock, and after that connect, and that's it. Right? No open VPN is involved. Can I uninstall it then? Yes, you can. Eddie ships its own OpenVPN build. On 5/20/2024 at 5:59 PM, yayaca said: Runs smoothly right now and the kill switch is active. Fantastic. Though, NetLock is engaged automatically before connection, so no need to do this manually. :) Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
