Eddie is no longer connecting to servers, but nothing changed with my install, internet connection, or pc to my knowledge. It started happening yesterday, but I wanted to give it time in case it was just an issue with servers or something. I've attempted to uninstall and reinstall, logging out and back in, and attempted to change protocol to both TCP and Wireguard, but none of it worked.
System Report: https://eddie.website/report/23c0c7e1/
Log:
I 2024.05.05 11:07:25 - Session starting.
I 2024.05.05 11:07:27 - Checking authorization ...
. 2024.05.05 11:07:28 - Added new network interface "Eddie", Wintun version 0.14
. 2024.05.05 11:07:28 - Using WinTun network interface "Eddie (Wintun Userspace Tunnel)"
! 2024.05.05 11:07:28 - Connecting to Chort (Canada, Toronto, Ontario)
. 2024.05.05 11:07:29 - Routes, add 104.254.90.237/32 for interface "ZeroTier One [3efa5cb78afd31f7] (ZeroTier Virtual Port)".
. 2024.05.05 11:07:29 - Routes, add 104.254.90.237/32 for interface "ZeroTier One [3efa5cb78afd31f7] (ZeroTier Virtual Port)", already exists.
. 2024.05.05 11:07:29 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021
. 2024.05.05 11:07:29 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit
. 2024.05.05 11:07:29 - OpenVPN > library versions: OpenSSL 1.1.1l  24 Aug 2021, LZO 2.10
. 2024.05.05 11:07:29 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.05.05 11:07:29 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.05.05 11:07:29 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2024.05.05 11:07:29 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2024.05.05 11:07:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.237:443
. 2024.05.05 11:07:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2024.05.05 11:07:29 - OpenVPN > UDP link local: (not bound)
. 2024.05.05 11:07:29 - OpenVPN > UDP link remote: [AF_INET]104.254.90.237:443
. 2024.05.05 11:08:01 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting
. 2024.05.05 11:08:01 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2024.05.05 11:08:06 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2024.05.05 11:08:06 - Disconnecting
. 2024.05.05 11:08:07 - Routes, delete 104.254.90.237/32 for interface "ZeroTier One [3efa5cb78afd31f7] (ZeroTier Virtual Port)".
. 2024.05.05 11:08:07 - Routes, delete 104.254.90.237/32 for interface "ZeroTier One [3efa5cb78afd31f7] (ZeroTier Virtual Port)", not exists.
. 2024.05.05 11:08:07 - Connection terminated.
I 2024.05.05 11:08:09 - Cancel requested.
! 2024.05.05 11:08:09 - Session terminated.
Perhaps install the latest experimental version of Eddie 2.24.2. The latest stable Eddie client is two years old now; try the latest version even if it is a "beta". If Eddie 2.24.2 doesn't doesn't allow you to connect to any servers, then post another log or open a support ticket.
19 minutes ago, monstrocity said:
Perhaps install the latest experimental version of Eddie 2.24.2. One thing that stands out for me in the log (2.21.8) is the use of OpenSSL 1.1.1 which I believe is EOL. The latest stable Eddie client is two years old now; try the latest version even if it is a "beta". If Eddie 2.24.2 doesn't doesn't allow you to connect to any servers, then open a support ticket.
Thanks for the suggestion! I just tried that, however it had no effect. I've made a support ticket now, so hopefully they can help.
I forgot about the obvious. Check here:
https://airvpn.org/forums/topic/58289-openvpn-certificate-has-expired/?tab=comments#comment-231319
