Not connected, Your IP: 216.73.217.74
Y0W4N
Routing transmission-daemon through wireguard interface on Debian
Hello, I'm reaching out to the forum because I recently subscribed to the service, and I'm having issues getting Transmission to work through the VPN. I'm using the WireGuard protocol on a Debian PC (headless without GUI).
The WireGuard interface (wg0) is working fine; I can ping external addresses through it, use curl, and perform speed tests :
The transmission-daemon also works perfectly when not going through the WireGuard interface but using my physical interface eth0.
When I bind Transmission to the wg0 interface (specifying its IP in "bind-address-ipv4"), no traffic goes through the VPN. The trackers are unreachable, and the error "announce error: could not connect to tracker" appears.
Running a netstat, I can see that Transmission is trying to connect to the tracker using various ports (why ?) through the WireGuard interface but never receives any traffic in return (SYN_SENT):
However, these addresses are pingable through the wg0 interface:
I've tried approaching the problem from different angles, and after several hours without any solution, I'd like to know if any of you have encountered a similar issue? (I should mention that my firewall is completely disabled for the tests).
Thank you !
Is the VPN the default gateway? Or have you left eth0 as the default gateway? Otherwise, there would be no reason to bind transmission-daemon to the VPN IP address.
If you want to use the VPN with transmission-daemon without the VPN as default gateway, you need to set up source address routing.
For examples see:
https://github.com/tool-maker/VPN_just_for_torrents/wiki/Running-Non-Specific-VPN-on-Linux-without-VPN-as-Default-Gateway
or
https://github.com/tool-maker/VPN_just_for_torrents/wiki/Running-OpenVPN-on-Linux-without-VPN-as-Default-Gateway
The relevant bits are commands like this:
sudo ip -4 route add default $GATEWAY_VIA4 dev $GATEWAY_IF table $IP_TABLE
sudo ip -4 rule add from $GATEWAY_LOCAL4 table $IP_TABLE
