chubsbox
AirVPN Eddie client for tvOS 17+
VPNs are now compatible with tvOS, are there plans to bring Eddie to Apple TV? I did a search here beforehand and couldn't find anything in the forums, apologize if that post exists. Thanks for all the great work, btw, including hummingbird.
Just tried VPN Client Bee tvOS app https://appsliced.co/app?n=vpn-client-plan-bee-any-vpn&l=home and was able to make it work with a Airvpn wireguard conf. Not sure if you have to pay for the app though (free trial 3 days) or if the purchase is only for using their own VPN (FlowVPN).
Update: to verify and test for location I then used https://www.speedtest.net tvOS app (you have to force quit the app each time you change location).
