stepas 0 Posted ... (edited) It's important for me to download some code snippets from raw.githubusercontent.com. I'm able to resolve the IP address correctly using the 1.1.1.1 DNS server, but can't access the actual content. See https://airvpn.org/routes/?q=https%3A%2F%2Fraw.githubusercontent.com My command line query stalls like this: wget https://raw.githubusercontent.com/DioxusLabs/dioxus/master/LICENSE-MIT --2023-08-06 20:32:06-- https://raw.githubusercontent.com/DioxusLabs/dioxus/master/LICENSE-MIT Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.111.133, 185.199.110.133, ... Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected. Edited ... by stepas Quote Share this post Link to post
benfitita 39 Posted ... Could it be that you are using Wireguard and need to set smaller MTU, like 1280? Works for me. Routes tool shows 301 (redirection), because https://raw.githubusercontent.com without path to any file, always redirects to https://github.com. Routes tool unfortunately only requests the / instead of full path, so no way to do a proper check. Maybe @Staff could improve it to perform HTTP checks using full supplied path. wget https://raw.githubusercontent.com/DioxusLabs/dioxus/master/LICENSE-MIT --2023-08-07 10:24:11-- https://raw.githubusercontent.com/DioxusLabs/dioxus/master/LICENSE-MIT Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.109.133, 185.199.111.133, 185.199.108.133, ... Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.109.133|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 1023 [text/plain] Saving to: ‘LICENSE-MIT’ LICENSE-MIT 100%[======================================================================================================>] 1023 --.-KB/s in 0s 2023-08-07 10:24:11 (38.1 MB/s) - ‘LICENSE-MIT’ saved [1023/1023] Quote Share this post Link to post
Tech Jedi Alex 1586 Posted ... You should tell from which server you tried to do so, so that others can check as well. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
stepas 0 Posted ... (edited) Yes, it's possible that it's related to MTU, meaning some config on my end. Just realized the problem is intermittent, sometimes works, sometimes doesn't. I am not a fan of this, since it may come back at some point. I am using Wireguard, and it's set up on my OPNsense router with clients connecting to AirVPN through the router. The MTU of the Wireguard config was set to 1320. Other ones were left to be default. I tried updating MTU values in a few additional places: - MTU on the LAN interface in OPNsense now set 1320 - MTU on the client computer interface is now set 1320 - MTU on the docker bridge network on the client computer set to 1320 After this everything broke down, and I reverted all of these. Edited ... by stepas Quote Share this post Link to post
