hey guys , i recently bought airvpn and so far im happy with it , my only concern is the android app , im from iran and internet is very restricted , especially mobile data , while using mobile data you cant use the vpn without using tcp ssh or tcp ssl , but these protocols are not available on the mobile app.
does that mean i cant do anything about the restriction , or is there a setting or a way to use the vpn while using mobile data with the phone.
please note that i dont have any problem while using wifi , i connect to internet with udp and normall tcp and its very reliable , i just want to know if there is anything i can do about the mobile data when im using the android ( like i said , i can use tcp ssh on windows and use the mobile data , but i cant do that with the android app)
sorry for my bad english , thanks for reading
Edited ... by braxton12311
