aLittleSnowy 0 Posted ... . 2023.07.19 19:20:10 - Above log line repeated 16 times more I 2023.07.19 19:20:10 - Session starting. I 2023.07.19 19:20:10 - Checking authorization ... . 2023.07.19 19:20:11 - Added new network interface "eddie", Wintun version 0.12 . 2023.07.19 19:20:11 - Using WinTun network interface "eddie (Wintun Userspace Tunnel)" ! 2023.07.19 19:20:11 - Connecting to Kajam (Netherlands, Alblasserdam) . 2023.07.19 19:20:11 - Routes, add 213.152.161.87/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)". . 2023.07.19 19:20:11 - Routes, add 213.152.161.87/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)", already exists. . 2023.07.19 19:20:12 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2023.07.19 19:20:12 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2023.07.19 19:20:12 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2023.07.19 19:20:12 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.07.19 19:20:12 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.07.19 19:20:12 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.07.19 19:20:12 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.07.19 19:20:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.87:443 . 2023.07.19 19:20:12 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2023.07.19 19:20:12 - OpenVPN > UDP link local: (not bound) . 2023.07.19 19:20:12 - OpenVPN > UDP link remote: [AF_INET]213.152.161.87:443 . 2023.07.19 19:20:43 - OpenVPN > [UNDEF] Inactivity timeout (--ping-exit), exiting . 2023.07.19 19:20:43 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.07.19 19:20:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting ! 2023.07.19 19:20:49 - Disconnecting . 2023.07.19 19:20:49 - Routes, delete 213.152.161.87/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)". . 2023.07.19 19:20:50 - Routes, delete 213.152.161.87/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)", not exists. . 2023.07.19 19:20:50 - Connection terminated. I 2023.07.19 19:20:53 - Checking authorization ... . 2023.07.19 19:20:53 - Using WinTun network interface "eddie (Wintun Userspace Tunnel)" ! 2023.07.19 19:20:53 - Connecting to Situla (Netherlands, Alblasserdam) . 2023.07.19 19:20:53 - Routes, add 213.152.161.17/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)". . 2023.07.19 19:20:53 - Routes, add 213.152.161.17/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)", already exists. . 2023.07.19 19:20:53 - OpenVPN > OpenVPN 2.5.5 Windows-MSVC [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Dec 15 2021 . 2023.07.19 19:20:53 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2023.07.19 19:20:53 - OpenVPN > library versions: OpenSSL 1.1.1l 24 Aug 2021, LZO 2.10 . 2023.07.19 19:20:53 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.07.19 19:20:53 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.07.19 19:20:53 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2023.07.19 19:20:53 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2023.07.19 19:20:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.17:443 . 2023.07.19 19:20:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2023.07.19 19:20:53 - OpenVPN > UDP link local: (not bound) . 2023.07.19 19:20:53 - OpenVPN > UDP link remote: [AF_INET]213.152.161.17:443 ! 2023.07.19 19:20:58 - Disconnecting . 2023.07.19 19:20:58 - Sending soft termination signal . 2023.07.19 19:21:01 - OpenVPN > SIGTERM received, sending exit notification to peer . 2023.07.19 19:21:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2023.07.19 19:21:03 - Routes, delete 213.152.161.17/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)". . 2023.07.19 19:21:03 - Routes, delete 213.152.161.17/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)", not exists. . 2023.07.19 19:21:03 - Connection terminated. I 2023.07.19 19:21:03 - Cancel requested. ! 2023.07.19 19:21:03 - Session terminated. Quote Share this post Link to post
Tech Jedi Alex 1578 Posted ... 22 hours ago, aLittleSnowy said: . 2023.07.19 19:20:11 - Routes, add 213.152.161.87/32 for interface "Radmin VPN (Famatech Radmin VPN Ethernet Adapter)". Are you trying to VPN over another VPN? In any case, restart Eddie, try a connection, then: . Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
