jimbobub
ipv6 connectivity no network access when using airvpn
When using airvpn under windows 10 network connections wifi 3 status : ipv6 connectivity no network access. When not using airvpn both ipv4 and ipv6 have internet access. When airvpn is turned on ipv4 has internet access and ipv6 has no network access.
I asked for the client you're using to connect to AirVPN. If you're using Eddie, connect, then:
The log is very long. I'm worried about missing some private info such as passwords and ip addresses  when editing. I would like to proceed but not sure what to do next. Thanks for the help so far.
Passwords aren't shown, and the only addresses you might worry about are IPv6 and MAC. Besides, my link mentions all that.
