cfinley 3 Posted ... I am running AirVPN on a router running Asuswrt-Merlin version 386.7_2. I have Accept DNS Configuration set to Exclusive and all traffic is routed through the tunnel, with the Kill Switch enabled. Under WAN DNS Setting, I have manually set DNS Server1 to 10.4.0.1 and DNS Server2 to 10.5.0.1. It seems to connect well and IPleak.net shows no leaks. My question is: is there any reason I should not use AirVPN’s private servers, exclusively? Quote Share this post Link to post
go558a83nk 382 Posted ... Only reason I can think of is for DNS resolution when not connected to the VPN or if you decide to have devices not routed through the VPN. Quote Share this post Link to post
