Dadadadadaa
Can´t connect to NAS webinterface(lan) while connected to AirVPN.
I'm currently using Eddie 2.21.5 beta on Windows 10.(Though this issue has been with older Eddie versions as well.)
While I'm connected to AirVPN, I cannot access my NAS webinterface (https://192.168.x.x), but after I disconnect, I can access it again. Just disconnecting is enough, disabling the Network Lock is not necessary. (Allow lan/private is enabled in the Network Lock settings. I also tried adding the NAS IP to Allowed Outgoing but that doesn't work.)
On 4/28/2022 at 12:59 AM, Flx said:
Read this:
That user has no problem accessing his NAS, only with the wireguard client did he have problems.
Anyway, I tried adding those to Allowed Outgoing in the Network Lock settings in Eddie, but it didn't work.
I entered it both literally as:
0.0.0.0/1, 128.0.0.0/1
And in separate lines:
0.0.0.0/1
128.0.0.0/1
What it did do was allowing me to reach any website while being disconnected, but with network lock still active. Basically it disabled the network lock for me. My NAS webinterface was still unreachable while connected to AirVPN though.
