upload 70Mbps on a 200Mbps fiberspeed, downloadspeed is ok.
The vpn client runs on a NAS, a TS-253D, equiped with 16Gb memory.
Fiberspeed is 200Mbps up/down
WITH vpn i get 190Mbps down and 70Mbps upload speed
WITHOUT vpn i get 199Mbps down and 46Mbps upload speed.
Why is the upload speed behind a vpn less than i expected
It's usually vice versa, upload throughput stays about the same, download throughput goes down. It's a matter of server, port and protocol choice, in that order of preference. Try different servers in different times of day, you will surely discover a config giving you good upload and download throughput. :)
