sagex
AirVPN takes 30 minutes to connect
It takes 30 minutes to connect to a server, I turn on network lock, pick a server and connect, after about 15 seconds I get the connection, however the program itself is still saying "connecting" or "checking dns" or wahtever for 30+ minutes, and during that time I can't do anything in the program, if I try to exit the program I'll have to wait 30 minutes until it's connected and only then does it exit, if I close the tasks with taskmanager then my internet doesn't work until I restart, and during the 30 minutes it's connecting I also can't open torrent programs, like I click on utorrent and it just doesn't open, even though I can use the internet in my browser but many other things requiring internet don't work until 30 minutes later when it finally says connected, here is the log
. 2021.05.17 00:15:51 - Eddie version: 2.20.0 / windows_x64, System: Windows, Name: Windows 7 Ultimate, Version: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net: v4.0.30319
. 2021.05.17 00:15:51 - Command line arguments (1): path="home"
. 2021.05.17 00:15:52 - Profile path: C:\Users\Windows\AppData\Local\Eddie\default.profile
. 2021.05.17 00:15:52 - Reading options from C:\Users\Windows\AppData\Local\Eddie\default.profile
. 2021.05.17 00:15:54 - Tun Driver - 0901: 9.9.2; wintun: 0.8
. 2021.05.17 00:15:54 - OpenVPN - Version: 2.5.1 - OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2021.05.17 00:15:54 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2021.05.17 00:15:54 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2021.05.17 00:16:01 - Recovery. Unexpected crash?
. 2021.05.17 00:16:01 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
. 2021.05.17 00:16:01 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 3, to automatic)
! 2021.05.17 00:16:01 - Deactivation of Network Lock
I 2021.05.17 00:16:02 - Ready
. 2021.05.17 00:16:02 - Collect information about AirVPN completed
. 2021.05.17 00:49:41 - Above log line repeated 1 times more
! 2021.05.17 00:49:41 - Activation of Network Lock - Windows Filtering Platform
I 2021.05.17 00:49:54 - Session starting.
I 2021.05.17 00:49:54 - Checking authorization ...
! 2021.05.17 00:49:55 - Connecting to Tucana (Germany, Frankfurt)
. 2021.05.17 00:49:55 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021
. 2021.05.17 00:49:55 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2021.05.17 00:49:55 - OpenVPN > library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.10
. 2021.05.17 00:49:55 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.17 00:49:55 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.17 00:49:55 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2021.05.17 00:49:55 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2021.05.17 00:49:55 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]178.162.212.216:443
. 2021.05.17 00:49:55 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2021.05.17 00:49:55 - OpenVPN > UDP link local: (not bound)
. 2021.05.17 00:49:55 - OpenVPN > UDP link remote: [AF_INET]178.162.212.216:443
. 2021.05.17 00:49:55 - OpenVPN > TLS: Initial packet from [AF_INET]178.162.212.216:443, sid=6ed76fd9 a53b80b4
. 2021.05.17 00:49:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2021.05.17 00:49:55 - OpenVPN > VERIFY KU OK
. 2021.05.17 00:49:55 - OpenVPN > Validating certificate extended key usage
. 2021.05.17 00:49:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2021.05.17 00:49:55 - OpenVPN > VERIFY EKU OK
. 2021.05.17 00:49:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Tucana, emailAddress=info@airvpn.org
. 2021.05.17 00:49:55 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA
. 2021.05.17 00:49:55 - OpenVPN > [Tucana] Peer Connection Initiated with [AF_INET]178.162.212.216:443
. 2021.05.17 00:49:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.13.214.1,dhcp-option DNS6 fde6:7a:7d20:9d6::1,tun-ipv6,route-gateway 10.13.214.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:9d6::1032/64 fde6:7a:7d20:9d6::1,ifconfig 10.13.214.52 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2021.05.17 00:49:55 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2021.05.17 00:49:55 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2021.05.17 00:49:55 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2021.05.17 00:49:55 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.17 00:49:55 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2021.05.17 00:49:55 - OpenVPN > interactive service msg_channel=0
. 2021.05.17 00:49:55 - OpenVPN > ROUTE_GATEWAY 192.168.2.1/255.255.255.0 I=11 HWADDR=64:70:02:50:44:7a
. 2021.05.17 00:49:55 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2021.05.17 00:49:55 - OpenVPN > GetBestInterfaceEx() returned if=11
. 2021.05.17 00:49:55 - OpenVPN > GDG6: II=11 DP=::/0 NH=fe80::1
. 2021.05.17 00:49:55 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0
. 2021.05.17 00:49:55 - OpenVPN > ROUTE6_GATEWAY fe80::1 I=11
. 2021.05.17 00:49:55 - OpenVPN > open_tun
. 2021.05.17 00:49:55 - OpenVPN > tap-windows6 device [Local Area Connection 3] opened
. 2021.05.17 00:49:55 - OpenVPN > TAP-Windows Driver Version 9.9
. 2021.05.17 00:49:55 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.13.214.0/10.13.214.52/255.255.255.0 [SUCCEEDED]
. 2021.05.17 00:49:55 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.13.214.52/255.255.255.0 on interface {0D39F910-21B0-47C5-8BB0-5640834142E9} [DHCP-serv: 10.13.214.254, lease-time: 31536000]
. 2021.05.17 00:49:55 - OpenVPN > Successful ARP Flush on interface [20] {0D39F910-21B0-47C5-8BB0-5640834142E9}
. 2021.05.17 00:49:55 - OpenVPN > IPv4 MTU set to 1500 on interface 20 using SetIpInterfaceEntry()
. 2021.05.17 00:49:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address 20 fde6:7a:7d20:9d6::1032/128 store=active
. 2021.05.17 00:49:55 - OpenVPN > add_route_ipv6(fde6:7a:7d20:9d6::/64 -> fde6:7a:7d20:9d6::1032 metric 0) dev Local Area Connection 3
. 2021.05.17 00:49:55 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:9d6::/64 20 fe80::8 store=active
. 2021.05.17 00:49:55 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.05.17 00:49:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns 20 all
. 2021.05.17 00:49:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns 20 static fde6:7a:7d20:9d6::1 validate=no
. 2021.05.17 00:49:55 - OpenVPN > IPv6 MTU set to 1500 on interface 20 using SetIpInterfaceEntry()
. 2021.05.17 00:50:00 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\route.exe ADD 178.162.212.216 MASK 255.255.255.255 192.168.2.1
. 2021.05.17 00:50:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2021.05.17 00:50:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.13.214.1
. 2021.05.17 00:50:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.13.214.1
. 2021.05.17 00:50:00 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:9d6::1 metric -1) dev Local Area Connection 3
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 20 fe80::8 store=active
. 2021.05.17 00:50:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2021.05.17 00:50:00 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:9d6::1 metric -1) dev Local Area Connection 3
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 20 fe80::8 store=active
. 2021.05.17 00:50:00 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:9d6::1 metric -1) dev Local Area Connection 3
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 20 fe80::8 store=active
. 2021.05.17 00:50:00 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:9d6::1 metric -1) dev Local Area Connection 3
. 2021.05.17 00:50:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 20 fe80::8 store=active
. 2021.05.17 00:50:00 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv4
. 2021.05.17 00:50:00 - Interface Local Area Connection 3 metric changed from Automatic to 3, layer IPv6
. 2021.05.17 01:16:18 - Collect information about AirVPN completed
. 2021.05.17 01:22:14 - DNS leak protection with packet filtering enabled.
. 2021.05.17 01:22:15 - DNS IPv4 of a network adapter forced (Local Area Connection 3, from automatic to 10.13.214.1)
. 2021.05.17 01:22:15 - DNS IPv6 of a network adapter forced (Local Area Connection 3, from automatic to fde6:7a:7d20:9d6::1)
. 2021.05.17 01:22:15 - Routes, added a new route, 178.162.212.214 for gateway 10.13.214.1
. 2021.05.17 01:22:15 - Routes, added a new route, 2a00:c98:2050:a02f:dc0e:3cc1:46f0:5eae for gateway fde6:7a:7d20:9d6::1
. 2021.05.17 01:22:15 - Flushing DNS
I 2021.05.17 01:22:15 - Checking route IPv4
I 2021.05.17 01:22:15 - Checking route IPv6
I 2021.05.17 01:22:19 - Checking DNS
! 2021.05.17 01:22:30 - Connected.
. 2021.05.17 01:22:31 - OpenVPN > Initialization Sequence Completed
Keep in mind that I opened the program at 00:16 but I didn't connect until 00:49, this has nothing to do with the program itself I just forgot to connect when I opened the program, from 00:49 on is when I started connecting to a server and it didn't finish until 01:22
During the last 10 minutes of connecting my computer also slows down quite a bit, this only ever happens when connecting on airvpn.
I know my version of tap driver is quite old but the only reason I'm using it is because every time I tried using the newest version in the past, airvpn would work fine for about a minute after connecting and then go down to unusable speeds and only installing the older version of tap fixed it, earlier today I completely uninstalled tap/airvpn and everything related and then updated tap to the latest version and airvpn wouldn't even connect at all, not even after 30 minutes, I got some error but I didn't save the log, so even with the newest version of tap it still takes 30+ mins and then doesn't even connect
Edited ... by sagex
