user84773662 0 Posted ... Hi Staff, can you please tell me why this happens? SSL peer certificate or SSH remote key was not OK . 2021.02.28 14:12:38 - Flushing DNS I 2021.02.28 14:12:38 - Checking route IPv4 . 2021.02.28 14:12:56 - Fetch url error:SSL peer certificate or SSH remote key was not OK . 2021.02.28 14:12:56 - Checking route (2° try) . 2021.02.28 14:12:59 - Fetch url error:SSL peer certificate or SSH remote key was not OK . 2021.02.28 14:12:59 - Checking route (3° try) . 2021.02.28 14:13:04 - Fetch url error:SSL peer certificate or SSH remote key was not OK E 2021.02.28 14:13:04 - Checking route IPv4 failed. . 2021.02.28 14:13:04 - OpenVPN > Initialization Sequence Completed ! 2021.02.28 14:13:04 - Disconnecting Just looking for possible reasons that the SSL peer certificate may not be fetchable (as it seems). Thanks Quote Share this post Link to post
astralmind 0 Posted ... Hum. Same issue here - stuck on IPV4 testing. Disabling the checks as mentioned by madrat works but.. that's not great. Been using Airvpn with great success for a month now and this just suddenly came up following a windows update (KB4023057 update for Windows 10, version 20H2). Attaching my log as well. AirvpnIpv4issue.txt Quote Share this post Link to post
pfolk 6 Posted ... Reporting this issue as this started today, I get this on three different machines, 2x running 2.20.0, 1x running 2.19.7: AirVPN goes into an endless connect/cancel/re-connect loop, logs state: "Fetch url error:SSL peer certificate or SSH remote key was not OK" Already rebooted modem and router, flushed DNS on all machines, re-installed Eddie, reset Win firewall....did not help. The only way to get AirVPN to connect is to uncheck "Check if the VPN tunnel works" and "Check Air VPN DNS" (and still use Network lock)... Is this a known issue ? Thanks. 4 rosewellzz, NL99, alswell and 1 other reacted to this Quote Share this post Link to post
betacat 14 Posted ... Eddie V2.20.0 suddenly won't connect using Windows 10, 20H2. It starts to connect, then disconnects, then restarts again - all in a continuous loop. Any ideas on a solution? Thanks. 5 Hutchinman, potatoislife, Suarez and 2 others reacted to this Quote Share this post Link to post
ev0ishere 0 Posted ... I am having issues exactly like you and i thought i was the only one. Ended up not connecting through the VPN to see if it was and issue with Air and came here. I am going to quickly try your solution and be right back. Quote Share this post Link to post
Paralite 0 Posted ... I'm having the exact same issue. I've already opened a support ticket. Your workaround fixed it for me too! Hopefully the devs fix this quickly. It's the only issue I've found in years of using this service. Quote Share this post Link to post
ev0ishere 0 Posted ... I'm back! I did what you mentioned and it worked with me as well. Hoping the mods will see this soon and follow up on it! Quote Share this post Link to post
DeadPooly 0 Posted ... Same issue here, every server I've tried gets stuck on "Checking route IPv4" with the error "Fetch url error: SSL peer certificate or SSH remote key was not OK". Might be a server sided error, since I've tried uninstalling and reinstalling older versions of eddie and the error persists. Quote Share this post Link to post
panamarock 0 Posted ... Same issue, was connected for 5 days, did a reboot about 6pm and the looping started Quote Quote Share this post Link to post
Equityc 6 Posted ... I am getting the exact same error. Probably everyone else does as well as the SSL certificate seems to be invalid. 6 Hutchinman, NL99, Suarez and 3 others reacted to this Quote Share this post Link to post
Hutchinman 2 Posted ... This is also occurring for me as well. Is this a network level issue? Just saw another thread that says that the SSL certificate expired which is why this is happening. No clue whether this is what is actually causing it, however a certificate expiring would affect a lot of people. Quote Share this post Link to post
_Bob_ 0 Posted ... Have the same problem, also since today (Win 10, Eddie 2.20.0.) One system is connected 24/7 and it keeps working (I'll not try to change servers right now). On other system (on same hardware router) I tried to change servers and it won't connect anymore to any of them, showing the "SSL" error as in O.P. I 2021.05.01 00:28:29 - Session starting. I 2021.05.01 00:28:29 - Checking authorization ... ! 2021.05.01 00:28:30 - Connecting to Merga (Netherlands, Alblasserdam) . 2021.05.01 00:28:30 - OpenVPN > OpenVPN 2.5.1 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Feb 24 2021 . 2021.05.01 00:28:30 - OpenVPN > Windows version 10.0 (Windows 10 or greater) 64bit . 2021.05.01 00:28:30 - OpenVPN > library versions: OpenSSL 1.1.1j 16 Feb 2021, LZO 2.10 . 2021.05.01 00:28:30 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.01 00:28:30 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.01 00:28:30 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2021.05.01 00:28:30 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2021.05.01 00:28:30 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.32:443 . 2021.05.01 00:28:30 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2021.05.01 00:28:30 - OpenVPN > UDP link local: (not bound) . 2021.05.01 00:28:30 - OpenVPN > UDP link remote: [AF_INET]213.152.161.32:443 . 2021.05.01 00:28:30 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.32:443, sid=320615e6 2de3e3ac . 2021.05.01 00:28:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2021.05.01 00:28:30 - OpenVPN > VERIFY KU OK . 2021.05.01 00:28:30 - OpenVPN > Validating certificate extended key usage . 2021.05.01 00:28:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2021.05.01 00:28:30 - OpenVPN > VERIFY EKU OK . 2021.05.01 00:28:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Merga, emailAddress=info@airvpn.org . 2021.05.01 00:28:30 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, 4096 bit RSA . 2021.05.01 00:28:30 - OpenVPN > [Merga] Peer Connection Initiated with [AF_INET]213.152.161.32:443 . 2021.05.01 00:28:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.42.1,dhcp-option DNS6 fde6:7a:7d20:122a::1,tun-ipv6,route-gateway 10.22.42.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:122a::10f9/64 fde6:7a:7d20:122a::1,ifconfig 10.22.42.251 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2021.05.01 00:28:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: peer-id set . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2021.05.01 00:28:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2021.05.01 00:28:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2021.05.01 00:28:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.01 00:28:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2021.05.01 00:28:30 - OpenVPN > interactive service msg_channel=0 . 2021.05.01 00:28:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=2 HWADDR=bc:ae:c5:0b:f7:9d . 2021.05.01 00:28:30 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2021.05.01 00:28:30 - OpenVPN > GetBestInterfaceEx() returned if=2 . 2021.05.01 00:28:30 - OpenVPN > GDG6: II=2 DP=::/0 NH=fe80::c2c1:c0ff:feaf:866d . 2021.05.01 00:28:30 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2021.05.01 00:28:30 - OpenVPN > ROUTE6_GATEWAY fe80::c2c1:c0ff:feaf:866d I=2 . 2021.05.01 00:28:30 - OpenVPN > open_tun . 2021.05.01 00:28:30 - OpenVPN > tap-windows6 device [Local Area Connection] opened . 2021.05.01 00:28:30 - OpenVPN > TAP-Windows Driver Version 9.24 . 2021.05.01 00:28:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.22.42.0/10.22.42.251/255.255.255.0 [SUCCEEDED] . 2021.05.01 00:28:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.22.42.251/255.255.255.0 on interface {31350E47-E2C0-49BD-B20F-0B75386C1AE3} [DHCP-serv: 10.22.42.254, lease-time: 31536000] . 2021.05.01 00:28:30 - OpenVPN > Successful ARP Flush on interface [5] {31350E47-E2C0-49BD-B20F-0B75386C1AE3} . 2021.05.01 00:28:31 - OpenVPN > IPv4 MTU set to 1500 on interface 5 using SetIpInterfaceEntry() . 2021.05.01 00:28:31 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set address 5 fde6:7a:7d20:122a::10f9/128 store=active . 2021.05.01 00:28:31 - OpenVPN > add_route_ipv6(fde6:7a:7d20:122a::/64 -> fde6:7a:7d20:122a::10f9 metric 0) dev Local Area Connection . 2021.05.01 00:28:31 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:122a::/64 5 fe80::8 store=active . 2021.05.01 00:28:31 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:31 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 5 all . 2021.05.01 00:28:31 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 set dns 5 static fde6:7a:7d20:122a::1 validate=no . 2021.05.01 00:28:31 - OpenVPN > IPv6 MTU set to 1500 on interface 5 using SetIpInterfaceEntry() . 2021.05.01 00:28:36 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.32 MASK 255.255.255.255 192.168.1.1 . 2021.05.01 00:28:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.01 00:28:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.42.1 . 2021.05.01 00:28:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.01 00:28:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.42.1 . 2021.05.01 00:28:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2021.05.01 00:28:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2021.05.01 00:28:36 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:122a::1 metric -1) dev Local Area Connection . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route ::/3 5 fe80::8 store=active . 2021.05.01 00:28:36 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:36 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:122a::1 metric -1) dev Local Area Connection . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 2000::/4 5 fe80::8 store=active . 2021.05.01 00:28:36 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:36 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:122a::1 metric -1) dev Local Area Connection . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route 3000::/4 5 fe80::8 store=active . 2021.05.01 00:28:36 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:36 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:122a::1 metric -1) dev Local Area Connection . 2021.05.01 00:28:36 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 add route fc00::/7 5 fe80::8 store=active . 2021.05.01 00:28:36 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:36 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv4 . 2021.05.01 00:28:36 - Interface Local Area Connection metric changed from Automatic to 3, layer IPv6 . 2021.05.01 00:28:36 - DNS leak protection with packet filtering enabled. . 2021.05.01 00:28:37 - DNS IPv4 of a network adapter forced (Local Area Connection, from manual (10.17.34.1) to 10.22.42.1) . 2021.05.01 00:28:37 - DNS IPv6 of a network adapter forced (Local Area Connection, from automatic to fde6:7a:7d20:122a::1) . 2021.05.01 00:28:37 - DNS IPv4 of a network adapter forced (Ethernet, from manual (10.17.34.1) to 10.22.42.1) . 2021.05.01 00:28:37 - DNS IPv6 of a network adapter forced (Ethernet, from automatic to fde6:7a:7d20:122a::1) . 2021.05.01 00:28:37 - Routes, added a new route, 213.152.161.30 for gateway 10.22.42.1 . 2021.05.01 00:28:37 - Routes, added a new route, 2a00:1678:2470:42:e8d8:5e4e:65f3:5e89 for gateway fde6:7a:7d20:122a::1 . 2021.05.01 00:28:37 - Flushing DNS I 2021.05.01 00:28:37 - Checking route IPv4 . 2021.05.01 00:28:41 - Fetch url error:SSL peer certificate or SSH remote key was not OK . 2021.05.01 00:28:41 - Checking route (2° try) . 2021.05.01 00:28:42 - Fetch url error:SSL peer certificate or SSH remote key was not OK . 2021.05.01 00:28:42 - Checking route (3° try) . 2021.05.01 00:28:44 - Fetch url error:SSL peer certificate or SSH remote key was not OK E 2021.05.01 00:28:44 - Checking route IPv4 failed. . 2021.05.01 00:28:44 - OpenVPN > Initialization Sequence Completed ! 2021.05.01 00:28:44 - Disconnecting . 2021.05.01 00:28:44 - Routes, removed a route previously added, 213.152.161.30 for gateway 10.22.42.1 . 2021.05.01 00:28:44 - Routes, removed a route previously added, 2a00:1678:2470:42:e8d8:5e4e:65f3:5e89 for gateway fde6:7a:7d20:122a::1 . 2021.05.01 00:28:44 - Sending soft termination signal . 2021.05.01 00:28:47 - OpenVPN > SIGTERM received, sending exit notification to peer . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.32 MASK 255.255.255.255 192.168.1.1 . 2021.05.01 00:28:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.42.1 . 2021.05.01 00:28:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.42.1 . 2021.05.01 00:28:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2021.05.01 00:28:49 - OpenVPN > delete_route_ipv6(::/3) . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route ::/3 5 fe80::8 store=active . 2021.05.01 00:28:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:49 - OpenVPN > delete_route_ipv6(2000::/4) . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 2000::/4 5 fe80::8 store=active . 2021.05.01 00:28:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:49 - OpenVPN > delete_route_ipv6(3000::/4) . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route 3000::/4 5 fe80::8 store=active . 2021.05.01 00:28:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:49 - OpenVPN > delete_route_ipv6(fc00::/7) . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fc00::/7 5 fe80::8 store=active . 2021.05.01 00:28:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2021.05.01 00:28:49 - OpenVPN > Closing TUN/TAP interface . 2021.05.01 00:28:49 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete dns 5 all . 2021.05.01 00:28:49 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:122a::/64) . 2021.05.01 00:28:49 - OpenVPN > C:\WINDOWS\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:122a::/64 5 fe80::8 store=active . 2021.05.01 00:28:49 - OpenVPN > NETSH: C:\WINDOWS\system32\netsh.exe interface ipv6 delete address 5 fde6:7a:7d20:122a::10f9 store=active . 2021.05.01 00:28:49 - OpenVPN > TAP: DHCP address released . 2021.05.01 00:28:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2021.05.01 00:28:49 - Connection terminated. . 2021.05.01 00:28:51 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection, to 10.17.34.1) . 2021.05.01 00:28:51 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection, to automatic) . 2021.05.01 00:28:51 - DNS IPv4 of a network adapter restored to original settings (Ethernet, to 10.17.34.1) . 2021.05.01 00:28:52 - DNS IPv6 of a network adapter restored to original settings (Ethernet, to automatic) . 2021.05.01 00:28:52 - DNS leak protection with packet filtering disabled. . 2021.05.01 00:28:52 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv4 . 2021.05.01 00:28:52 - Interface Local Area Connection metric restored from 3 to Automatic, layer IPv6 I 2021.05.01 00:28:55 - Checking authorization ... I 2021.05.01 00:28:55 - Cancel requested. ! 2021.05.01 00:28:55 - Session terminated. Quote Share this post Link to post
nonperson60 0 Posted ... Same thing here. Endless loop trying to connect to any server. Quote Hide nonperson60's signature Hide all signatures Everything in moderation. Share this post Link to post
sanction9 3 Posted ... Ayep, this is happening to me, too. I'll assume that they're aware of it at this point, and hope there's a fix soon. 1 potatoislife reacted to this Quote Share this post Link to post
xxlastrites 0 Posted ... So today out of nowhere my Eddie client started failing at Checking Route IPV4 whenever I tried to connect to a server. I've used AIRVPN for what must be coming up on several years now and never had this problem crop up before. I've never changed any settings either. I followed the suggestions on here and it fixed the problem, disabling the checks etc. And that's great. But I'd really love to know why it just suddenly started failing when I've changed nothing over the years and it has worked perfectly fine. What exactly caused it to now have a problem and need me to uncheck boxes? Any answers? It does make me wonder. Quote Share this post Link to post
coolawacs 0 Posted ... I, as well am having the same issue. I have tried US, Canada and Netherlands servers, all have this issue... I 2021.04.30 17:29:16 - Checking route IPv4 . 2021.04.30 17:29:16 - Fetch url error:SSL peer certificate or SSH remote key was not OK . 2021.04.30 17:29:16 - Checking route (2° try) . 2021.04.30 17:29:18 - Fetch url error:SSL peer certificate or SSH remote key was not OK . 2021.04.30 17:29:18 - Checking route (3° try) . 2021.04.30 17:29:20 - Fetch url error:SSL peer certificate or SSH remote key was not OK E 2021.04.30 17:29:20 - Checking route IPv4 failed. . 2021.04.30 17:29:20 - OpenVPN > Initialization Sequence Completed ! 2021.04.30 17:29:20 - Disconnecting airvpnfail2.txt Quote Share this post Link to post
rosewellzz 0 Posted ... Getting the same issue, only way I got it to work was to [DNS Panel] unitick "Check AirVPN DNS" ; untick "Ensure DNS Lock" on the [Advanced Panel] untick "Check if the tunnel works". Quote Share this post Link to post
WoofWoof 0 Posted ... (edited) Same here - started ok today then for no reason just dropped and won't reconnect. Have uninstalled / reinstalled everything twice - removed last 4 windows updates - no luck. Other clients on Linux working fine across same network hardware. Help !!! Edited ... by WoofWoof Quote Share this post Link to post
Clifford Brown 0 Posted ... I cannot connect to any servers and im paid up for 2 yearS... HELP ME Quote Share this post Link to post
wedge 0 Posted ... I am using Win10 and have the same problem with Eddie Version 2.20, but my other machine doesn't with v. 2.18.9, so I downgraded versions and it's currently working. Quote Share this post Link to post
alswell 0 Posted ... (edited) Just checked and I am now able to connect to all servers. Same issue here. The errors in my logs, Quote Fetch url error:SSL peer certificate or SSH remote key was not OK Hopefully it's recognized and resolved soon. Edited ... by alswell Issue resolved Quote Share this post Link to post
