Is there something to be set in the desktop client after creating a port forward online? I can't seem to get it to open (for torrents)
Thanks in advance
In the torrent client, yes – the actual port you forwarded, and probably the interface the clients should listen on.
Oh... oh! That's weird, the client has a green light, but when I try canyouseeme.org it says it's not open. So, I should disregard that and consider it ok then?
Does the torrent client give you a green light? Do peers appear with an I flag in the peer list?
