I installed AirVPN with the Eddit Client on my Windows10 machine. Since I retstarted my computer I get following error message when trying to open the EddiUI:
Unable to obtain elevated privileges (required): Unable to start (No socket)
I dont know what to do, could someone help?
I have had this iritating problem for a while now & windows was previously updated. The only way around this problem, is I restart my laptop, which is not ideal. I use Airvpn on a desktop running Linux Mint, and no problems, but I have had nothing but hassel since trying to use it on a new laptop, which has all the latest updates. I followed the advice previously, but this only worked temporarily.
Great advice, it  really helped me, Developer please,  improve this in the next release because very inconvenient when not possible make fast shutdown and also very uncomfortable what need resolve bug after reboot
I should properly have posted this here instead.
3 hours ago, soma11 said:
Hi, I'm running Eddie on Windows 8.1 and are experiencing the same.
Since this only seems to happen in Windows, I think the root of the problem has to do with the way Windows are using hibernation as default when shutting down, which isn't the case when restarting.
It was also a problem in the previous version of Eddie, so after a Windows shutdown the "Start with Windows" hasn't been working during the latest two versions of Eddie (if not manually killing OpenVPN or restarting as mentioned above).
- https://airvpn.org/forums/topic/49313-eddie-ui-unable-to-start-no-socket/
I am encountering this issue even after proper shutdown and reboot. OpenVPN process is not running so it cannot be killed. Have also uninstalled and reinstalled both 2.19.7 and 2.20.0 with the same result.
What else can I try?
I had the same problem and I was ablte to fix it with these instructions sent to me by  AirVPN Support Team:
Quote
Can you please check whether Eddie starts minimized?
After you have launched Eddie, check the system tray. Eddie's tray icon is a small cloud in a circle. Make sure to click the "Up" arrow to see even the hidden icons.
If you find Eddie's tray icon, double-click it and Eddie's main window should pop up.
If you still can't open it, I suggest you add a few exceptions to your firewall for the airvpn program (probably not only one) and try again.
