Casper31 73 Posted ... According Tom,transparency,privacy are very good,less about the avg speed . Humm i find this a very cool conclusion! Tom sparks youtube: https://www.youtube.com/watch?v=-Og0X6HeT3o Quote Share this post Link to post
Tech Jedi Alex 1558 Posted ... The video was embedded as an image. Can you edit your post and just dump the link? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Flx 77 Posted ... (edited) @Casper31 Thank you for the video link. Very entertaining....to say the least How Mr. Tom Spark only got only 100mbps AirVPN connected? Here the latest speed test on speedtest.net(multi) on a TCP-Entry3 side-by-side triple session Native OpenVPN 2.5 wintun adapters scenario:https://www.speedtest.net/result/9862679064 Edited ... by Flx "triple session instead of triple mode" will make more sense Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
go558a83nk 384 Posted ... 46 minutes ago, Flx said: @Casper31 Thank you for the video link. Very entertaining....to say the least How Mr. Tom Spark only got only 100mbps AirVPN connected? Here the latest speed test on speedtest.net(multi) on a TCP-Entry3 side-by-side triple mode Native OpenVPN 2.5 wintun adapters scenario:https://www.speedtest.net/result/9862679064 What is "side-by-side triple mode" ? Quote Share this post Link to post
Flx 77 Posted ... 11 minutes ago, go558a83nk said: What is "side-by-side triple mode" ? Concept not yet created? How do you expect me to define it for you? Let me try: 3 Wintun adapters connected at the same time to different VPN servers.( right now Avior/Lesath/Tyl ) Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 77 Posted ... Any single-mode app(Firefox browser) running will use one tunnel/session. Speedtest.net multi or utorrent/bittorrent etc. will use all interconnected wintun adapters...thus distributing the load in/out over the 3 servers connected. Not sure I explain this very well. Sorry I can't write 20 pages on this or an essay. Why do you even ask anyway? Think it cannot be done? Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
go558a83nk 384 Posted ... 42 minutes ago, Flx said: Any single-mode app(Firefox browser) running will use one tunnel/session. Speedtest.net multi or utorrent/bittorrent etc. will use all interconnected wintun adapters...thus distributing the load in/out over the 3 servers connected. Not sure I explain this very well. Sorry I can't write 20 pages on this or an essay. Why do you even ask anyway? Think it cannot be done? ha! No need to explain. I do the same thing in pfsense. I just have never heard of it being done in windows and I didn't know you could run multiple instances of wintun. Quote Share this post Link to post
Tech Jedi Alex 1558 Posted ... At around 6:00, the reviewer said there was no favorite servers feature which is wrong. It's the green tick (whitelist), red cross (blacklist) and captionless (reset) buttons. Someone tell him to include a note in YouTube. Though it won't change the rating, it is a mistake. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Flx 77 Posted ... On 8/4/2020 at 10:23 PM, go558a83nk said: ha! No need to explain. I do the same thing in pfsense. I just have never heard of it being done in windows and I didn't know you could run multiple instances of wintun. In Windows it gets a bit tricky though. I did look for a way of doing this; and how it can be applied to qbit for example where you cannot achieve it just by simply having it bound or attached to the TAP interface.Blocking any other interface in Comodo Firewall other then the tap/tun interface.(the link below) works splendidly well. If your ISP reboots your main hub; there is No IN/OUT if all VPN sessions do in fact drop. All this has been well enough detailed in "GUIDE-the fix of the tap adapter for Windows". I hope. "Thanks for your answer on the router question where you suggested build your own pfsense" and use the pfsense as the GW(main point). Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
