onurduran
Can't Connect While Being Connected!(?)
While Eddie says I'm connected my computer thinks otherwise. Can someone help me with this?
Here's my log!
Eddie System/Environment Report - 25.04.2020 - 17:48 UTC
Eddie version: 2.18.9
Eddie OS build: windows_x64
Eddie architecture: x64
OS type: Windows
OS name: Windows 10 Home
OS version: Microsoft Windows NT 10.0.18363.0
OS architecture: x64
Mono /.Net Framework: v4.0.30319
TUN driver: 0901: 9.24.2; wintun: Not found
OpenVPN: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
Hummingbird:  ()
SSH: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
SSL: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
curl: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
Profile path: C:\Users\onurd\AppData\Local\Eddie\default.profile
Data path: C:\Users\onurd\AppData\Local\Eddie
Application path: C:\Program Files\AirVPN
Executable path: C:\Program Files\AirVPN\Eddie-UI.exe
Command line arguments: (1 args) path="home"
Network Lock Active: No
Connected to VPN: No
Detected DNS: 10.106.4.20
Test DNS IPv4: Ok
Test DNS IPv6: Failed
Test Ping IPv4: 83 ms
Test Ping IPv6: -1 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Error:curl: (7) Failed to connect to 2a03:b0c0:2:d0::11b4:6001 port 80: Network unreachable
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
netlock: True
dns.check: False
network.ipv6.mode: in-out
windows.workarounds: True
Logs:
. 2020.04.25 20:16:01 - Eddie version: 2.18.9 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.18363.0, Mono/.Net: v4.0.30319
. 2020.04.25 20:16:01 - Command line arguments (1): path="home"
. 2020.04.25 20:16:01 - Profile path: C:\Users\onurd\AppData\Local\Eddie\default.profile
. 2020.04.25 20:16:02 - Reading options from C:\Users\onurd\AppData\Local\Eddie\default.profile
. 2020.04.25 20:16:03 - Tun Driver - 0901: 9.24.2; wintun: Not found
. 2020.04.25 20:16:03 - OpenVPN - Version: 2.4.8 - OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2020.04.25 20:16:03 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2020.04.25 20:16:03 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2020.04.25 20:16:03 - curl - Version: 7.68.0 (C:\Program Files\AirVPN\curl.exe)
! 2020.04.25 20:16:03 - Activation of Network Lock - Windows Filtering Platform
I 2020.04.25 20:16:03 - Ready
. 2020.04.25 20:16:04 - Collect information about AirVPN completed
I 2020.04.25 20:16:09 - Session starting.
. 2020.04.25 20:16:09 - Waiting for latency tests (71 to go)
. 2020.04.25 20:16:10 - Waiting for latency tests (70 to go)
. 2020.04.25 20:16:11 - Waiting for latency tests (46 to go)
. 2020.04.25 20:16:14 - Waiting for latency tests (21 to go)
I 2020.04.25 20:16:17 - Checking authorization ...
! 2020.04.25 20:16:18 - Connecting to Sheliak (Netherlands, Alblasserdam)
. 2020.04.25 20:16:18 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.04.25 20:16:18 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.04.25 20:16:18 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.04.25 20:16:18 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.04.25 20:16:18 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.04.25 20:16:18 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.04.25 20:16:18 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.04.25 20:16:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.116:443
. 2020.04.25 20:16:18 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.04.25 20:16:18 - OpenVPN > UDP link local: (not bound)
. 2020.04.25 20:16:18 - OpenVPN > UDP link remote: [AF_INET]213.152.162.116:443
. 2020.04.25 20:16:18 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.116:443, sid=ba873f7d b3c1ab7d
. 2020.04.25 20:16:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.04.25 20:16:18 - OpenVPN > VERIFY KU OK
. 2020.04.25 20:16:18 - OpenVPN > Validating certificate extended key usage
. 2020.04.25 20:16:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.04.25 20:16:18 - OpenVPN > VERIFY EKU OK
. 2020.04.25 20:16:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Sheliak, emailAddress=info@airvpn.org
. 2020.04.25 20:16:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.04.25 20:16:19 - OpenVPN > [Sheliak] Peer Connection Initiated with [AF_INET]213.152.162.116:443
. 2020.04.25 20:16:20 - OpenVPN > SENT CONTROL [Sheliak]: 'PUSH_REQUEST' (status=1)
. 2020.04.25 20:16:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.58.1,dhcp-option DNS6 fde6:7a:7d20:1a3a::1,tun-ipv6,route-gateway 10.30.58.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1a3a::1063/64 fde6:7a:7d20:1a3a::1,ifconfig 10.30.58.101 255.255.255.0,peer-id 4,cipher AES-256-GCM'
. 2020.04.25 20:16:20 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.04.25 20:16:20 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.04.25 20:16:20 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.04.25 20:16:20 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.25 20:16:20 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.25 20:16:20 - OpenVPN > interactive service msg_channel=0
. 2020.04.25 20:16:20 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 I=11 HWADDR=1e:35:05:6d:58:7b
. 2020.04.25 20:16:20 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.04.25 20:16:20 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Eleman bulunamad�.   (code=1168)
. 2020.04.25 20:16:20 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2020.04.25 20:16:20 - OpenVPN > open_tun
. 2020.04.25 20:16:20 - OpenVPN > TAP-WIN32 device [Yerel Ağ Bağlantısı] opened: \\.\Global\{81E4C43A-3C71-4A1C-8A2B-DC30665D40CF}.tap
. 2020.04.25 20:16:20 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.04.25 20:16:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.58.0/10.30.58.101/255.255.255.0 [SUCCEEDED]
. 2020.04.25 20:16:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.58.101/255.255.255.0 on interface {81E4C43A-3C71-4A1C-8A2B-DC30665D40CF} [DHCP-serv: 10.30.58.254, lease-time: 31536000]
. 2020.04.25 20:16:20 - OpenVPN > Successful ARP Flush on interface [16] {81E4C43A-3C71-4A1C-8A2B-DC30665D40CF}
. 2020.04.25 20:16:21 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=16 fde6:7a:7d20:1a3a::1063 store=active
. 2020.04.25 20:16:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Yerel Ağ Bağlantısı static fde6:7a:7d20:1a3a::1 validate=no
. 2020.04.25 20:16:23 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1a3a::/64 -> fde6:7a:7d20:1a3a::1063 metric 0) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:16:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1a3a::/64 interface=16 fe80::8 store=active
. 2020.04.25 20:16:23 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:16:28 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.116 MASK 255.255.255.255 192.168.43.1
. 2020.04.25 20:16:28 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2020.04.25 20:16:28 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.58.1
. 2020.04.25 20:16:28 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.58.1
. 2020.04.25 20:16:28 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1a3a::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=16 fe80::8 store=active
. 2020.04.25 20:16:28 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:16:28 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1a3a::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:16:28 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1a3a::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:16:28 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1a3a::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:16:28 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=16 fe80::8 store=active
. 2020.04.25 20:16:28 - Interface Yerel Ağ Bağlantısı metric changed from Automatic to 3, layer IPv4
. 2020.04.25 20:16:28 - Interface Yerel Ağ Bağlantısı metric changed from Automatic to 3, layer IPv6
. 2020.04.25 20:16:28 - DNS leak protection with packet filtering enabled.
. 2020.04.25 20:16:28 - Routes, added a new route, 213.152.162.114 for gateway 10.30.58.1
. 2020.04.25 20:16:28 - Routes, added a new route, 2a00:1678:2470:36:13be:ff37:bd4a:7c35 for gateway fde6:7a:7d20:1a3a::1
. 2020.04.25 20:16:28 - Flushing DNS
I 2020.04.25 20:16:32 - Checking route IPv4
I 2020.04.25 20:16:32 - Checking route IPv6
! 2020.04.25 20:16:36 - Connected.
. 2020.04.25 20:16:36 - OpenVPN > Initialization Sequence Completed
! 2020.04.25 20:24:03 - Disconnecting
. 2020.04.25 20:24:03 - Routes, removed a route previously added, 213.152.162.114 for gateway 10.30.58.1
. 2020.04.25 20:24:03 - Routes, removed a route previously added, 2a00:1678:2470:36:13be:ff37:bd4a:7c35 for gateway fde6:7a:7d20:1a3a::1
. 2020.04.25 20:24:03 - Sending soft termination signal
. 2020.04.25 20:24:06 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.116 MASK 255.255.255.255 192.168.43.1
. 2020.04.25 20:24:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.58.1
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.58.1
. 2020.04.25 20:24:08 - OpenVPN > delete_route_ipv6(::/3)
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=16 fe80::8 store=active
. 2020.04.25 20:24:08 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:24:08 - OpenVPN > delete_route_ipv6(2000::/4)
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:24:08 - OpenVPN > delete_route_ipv6(3000::/4)
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:24:08 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=16 fe80::8 store=active
. 2020.04.25 20:24:08 - OpenVPN > Closing TUN/TAP interface
. 2020.04.25 20:24:08 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1a3a::/64)
. 2020.04.25 20:24:08 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1a3a::/64 interface=16 fe80::8 store=active
. 2020.04.25 20:24:09 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Yerel Ağ Bağlantısı fde6:7a:7d20:1a3a::1063 store=active
. 2020.04.25 20:24:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Yerel Ağ Bağlantısı all
. 2020.04.25 20:24:11 - OpenVPN > TAP: DHCP address released
. 2020.04.25 20:24:11 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.04.25 20:24:11 - Connection terminated.
. 2020.04.25 20:24:11 - DNS leak protection with packet filtering disabled.
. 2020.04.25 20:24:11 - Interface Yerel Ağ Bağlantısı metric restored from 3 to Automatic, layer IPv4
. 2020.04.25 20:24:11 - Interface Yerel Ağ Bağlantısı metric restored from 3 to Automatic, layer IPv6
. 2020.04.25 20:24:11 - Flushing DNS
! 2020.04.25 20:24:14 - Session terminated.
I 2020.04.25 20:24:41 - Session starting.
I 2020.04.25 20:24:42 - Checking authorization ...
I 2020.04.25 20:25:06 - Cancel requested.
! 2020.04.25 20:25:06 - Session terminated.
! 2020.04.25 20:25:08 - Deactivation of Network Lock
! 2020.04.25 20:25:13 - Activation of Network Lock - Windows Filtering Platform
I 2020.04.25 20:25:16 - Session starting.
I 2020.04.25 20:25:16 - Checking authorization ...
! 2020.04.25 20:25:17 - Connecting to Subra (Netherlands, Alblasserdam)
. 2020.04.25 20:25:17 - OpenVPN > OpenVPN 2.4.8 i686-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Oct 31 2019
. 2020.04.25 20:25:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2020.04.25 20:25:17 - OpenVPN > library versions: OpenSSL 1.1.0l  10 Sep 2019, LZO 2.10
. 2020.04.25 20:25:17 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.04.25 20:25:17 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.04.25 20:25:17 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key
. 2020.04.25 20:25:17 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication
. 2020.04.25 20:25:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.101:443
. 2020.04.25 20:25:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2020.04.25 20:25:17 - OpenVPN > UDP link local: (not bound)
. 2020.04.25 20:25:17 - OpenVPN > UDP link remote: [AF_INET]213.152.162.101:443
. 2020.04.25 20:25:17 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.101:443, sid=a481600b 96d8cdc2
. 2020.04.25 20:25:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2020.04.25 20:25:19 - OpenVPN > VERIFY KU OK
. 2020.04.25 20:25:19 - OpenVPN > Validating certificate extended key usage
. 2020.04.25 20:25:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2020.04.25 20:25:19 - OpenVPN > VERIFY EKU OK
. 2020.04.25 20:25:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Subra, emailAddress=info@airvpn.org
. 2020.04.25 20:25:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2020.04.25 20:25:27 - OpenVPN > [Subra] Peer Connection Initiated with [AF_INET]213.152.162.101:443
. 2020.04.25 20:25:28 - OpenVPN > SENT CONTROL [Subra]: 'PUSH_REQUEST' (status=1)
. 2020.04.25 20:25:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.30.226.1,dhcp-option DNS6 fde6:7a:7d20:1ae2::1,tun-ipv6,route-gateway 10.30.226.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1ae2::1097/64 fde6:7a:7d20:1ae2::1,ifconfig 10.30.226.153 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2020.04.25 20:25:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2020.04.25 20:25:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2020.04.25 20:25:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2020.04.25 20:25:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.25 20:25:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2020.04.25 20:25:29 - OpenVPN > interactive service msg_channel=0
. 2020.04.25 20:25:29 - OpenVPN > ROUTE_GATEWAY 10.34.104.1/255.255.252.0 I=11 HWADDR=86:d9:01:ae:34:63
. 2020.04.25 20:25:29 - OpenVPN > ROUTE: bypass_host_route[0]=1.1.1.1
. 2020.04.25 20:25:29 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2020.04.25 20:25:29 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Eleman bulunamad�.   (code=1168)
. 2020.04.25 20:25:29 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2020.04.25 20:25:29 - OpenVPN > open_tun
. 2020.04.25 20:25:29 - OpenVPN > TAP-WIN32 device [Yerel Ağ Bağlantısı] opened: \\.\Global\{81E4C43A-3C71-4A1C-8A2B-DC30665D40CF}.tap
. 2020.04.25 20:25:29 - OpenVPN > TAP-Windows Driver Version 9.24
. 2020.04.25 20:25:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.30.226.0/10.30.226.153/255.255.255.0 [SUCCEEDED]
. 2020.04.25 20:25:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.30.226.153/255.255.255.0 on interface {81E4C43A-3C71-4A1C-8A2B-DC30665D40CF} [DHCP-serv: 10.30.226.254, lease-time: 31536000]
. 2020.04.25 20:25:29 - OpenVPN > Successful ARP Flush on interface [16] {81E4C43A-3C71-4A1C-8A2B-DC30665D40CF}
. 2020.04.25 20:25:30 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=16 fde6:7a:7d20:1ae2::1097 store=active
. 2020.04.25 20:25:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Yerel Ağ Bağlantısı static fde6:7a:7d20:1ae2::1 validate=no
. 2020.04.25 20:25:31 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1ae2::/64 -> fde6:7a:7d20:1ae2::1097 metric 0) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:25:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1ae2::/64 interface=16 fe80::8 store=active
. 2020.04.25 20:25:31 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:25:36 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.101 MASK 255.255.255.255 10.34.104.1
. 2020.04.25 20:25:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2020.04.25 20:25:36 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\route.exe ADD 1.1.1.1 MASK 255.255.255.255 10.34.104.1
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.30.226.1
. 2020.04.25 20:25:36 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.30.226.1
. 2020.04.25 20:25:36 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1ae2::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=16 fe80::8 store=active
. 2020.04.25 20:25:36 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:25:36 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1ae2::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:25:36 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1ae2::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:25:36 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1ae2::1 metric -1) dev Yerel Ağ Bağlantısı
. 2020.04.25 20:25:36 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=16 fe80::8 store=active
. 2020.04.25 20:25:36 - Interface Yerel Ağ Bağlantısı metric changed from Automatic to 3, layer IPv4
. 2020.04.25 20:25:36 - Interface Yerel Ağ Bağlantısı metric changed from Automatic to 3, layer IPv6
. 2020.04.25 20:25:36 - DNS leak protection with packet filtering enabled.
. 2020.04.25 20:25:36 - Routes, added a new route, 213.152.162.99 for gateway 10.30.226.1
. 2020.04.25 20:25:36 - Routes, added a new route, 2a00:1678:2470:33:d3c3:e135:8475:645f for gateway fde6:7a:7d20:1ae2::1
. 2020.04.25 20:25:36 - Flushing DNS
I 2020.04.25 20:25:40 - Checking route IPv4
. 2020.04.25 20:26:00 - curl: (28) Operation timed out after 20001 milliseconds with 0 out of 0 bytes received
. 2020.04.25 20:26:00 - Checking route (2° try)
. 2020.04.25 20:26:21 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2020.04.25 20:26:21 - Checking route (3° try)
I 2020.04.25 20:26:40 - Checking route IPv6
. 2020.04.25 20:27:00 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2020.04.25 20:27:00 - Checking route (2° try)
. 2020.04.25 20:27:21 - curl: (28) Operation timed out after 20014 milliseconds with 0 bytes received
. 2020.04.25 20:27:21 - Checking route (3° try)
E 2020.04.25 20:27:37 - curl: (35) error:1408F10B:SSL routines:ssl3_get_record:wrong version number
! 2020.04.25 20:27:37 - Connected.
. 2020.04.25 20:27:37 - OpenVPN > Initialization Sequence Completed
. 2020.04.25 20:47:33 - Cannot retrieve information about AirVPN: curl: (28) Operation timed out after 20006 milliseconds with 1921 out of 118944 bytes received
! 2020.04.25 20:47:35 - Disconnecting
. 2020.04.25 20:47:35 - Routes, removed a route previously added, 213.152.162.99 for gateway 10.30.226.1
. 2020.04.25 20:47:35 - Routes, removed a route previously added, 2a00:1678:2470:33:d3c3:e135:8475:645f for gateway fde6:7a:7d20:1ae2::1
. 2020.04.25 20:47:35 - Sending soft termination signal
. 2020.04.25 20:47:38 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.162.101 MASK 255.255.255.255 10.34.104.1
. 2020.04.25 20:47:40 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\route.exe DELETE 1.1.1.1 MASK 255.255.255.255 10.34.104.1
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.30.226.1
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.30.226.1
. 2020.04.25 20:47:40 - OpenVPN > delete_route_ipv6(::/3)
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=16 fe80::8 store=active
. 2020.04.25 20:47:40 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:47:40 - OpenVPN > delete_route_ipv6(2000::/4)
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:47:40 - OpenVPN > delete_route_ipv6(3000::/4)
. 2020.04.25 20:47:40 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=16 fe80::8 store=active
. 2020.04.25 20:47:41 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2020.04.25 20:47:41 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=16 fe80::8 store=active
. 2020.04.25 20:47:41 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2020.04.25 20:47:41 - OpenVPN > Closing TUN/TAP interface
. 2020.04.25 20:47:41 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1ae2::/64)
. 2020.04.25 20:47:41 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1ae2::/64 interface=16 fe80::8 store=active
. 2020.04.25 20:47:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Yerel Ağ Bağlantısı fde6:7a:7d20:1ae2::1097 store=active
. 2020.04.25 20:47:43 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Yerel Ağ Bağlantısı all
. 2020.04.25 20:47:43 - OpenVPN > TAP: DHCP address released
. 2020.04.25 20:47:43 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2020.04.25 20:47:43 - Connection terminated.
. 2020.04.25 20:47:43 - DNS leak protection with packet filtering disabled.
. 2020.04.25 20:47:43 - Interface Yerel Ağ Bağlantısı metric restored from 3 to Automatic, layer IPv4
. 2020.04.25 20:47:43 - Interface Yerel Ağ Bağlantısı metric restored from 3 to Automatic, layer IPv6
. 2020.04.25 20:47:43 - Flushing DNS
! 2020.04.25 20:47:46 - Session terminated.
! 2020.04.25 20:47:47 - Deactivation of Network Lock
Network Interfaces and Routes:
    "support_ipv4": true,
    "support_ipv6": true,
    "routes": [
            "address": "0.0.0.0\/0",
            "interface": "{4F4575E6-4C9C-4428-BA18-E33502D21079}",
            "gateway": "10.34.104.1",
            "metric": "50"
            "address": "10.34.104.0\/22",
            "gateway": "link",
            "metric": "306"
            "address": "10.34.104.248",
            "gateway": "link",
            "metric": "306"
            "address": "10.34.107.255",
            "gateway": "link",
            "metric": "306"
            "address": "127.0.0.0\/8",
            "interface": "{9B7F9960-B923-11E9-BB96-806E6F6E6963}",
            "gateway": "link",
            "metric": "331"
            "address": "127.0.0.1",
            "gateway": "link",
            "metric": "331"
            "address": "127.255.255.255",
            "gateway": "link",
            "metric": "331"
            "address": "224.0.0.0\/4",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "306"
            "address": "255.255.255.255",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "306"
            "address": "::1",
            "gateway": "link",
            "metric": "331"
            "address": "fe80::\/64",
            "gateway": "link",
            "metric": "306"
            "address": "fe80::9174:8ed1:3c38:a7c0",
            "gateway": "link",
            "metric": "306"
            "address": "ff00::\/8",
            "gateway": "link",
            "metric": "331"
            "gateway": "link",
            "metric": "306"
    "interfaces": [
            "friendly": "Ethernet",
            "id": "{857EABA8-FD1F-4688-86FF-F43C7A95D1C3}",
            "name": "Ethernet",
            "description": "Killer E3000 2.5 Gigabit Ethernet Controller",
            "type": "Ethernet",
            "status": "Down",
            "bytes_received": "0",
            "bytes_sent": "0",
            "ips": [
                "fe80::284c:23f4:14e8:6d49",
                "169.254.109.73"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Yerel A\u011f Ba\u011flant\u0131s\u0131",
            "id": "{81E4C43A-3C71-4A1C-8A2B-DC30665D40CF}",
            "name": "Yerel A\u011f Ba\u011flant\u0131s\u0131",
            "description": "TAP-Windows Adapter V9",
            "type": "53",
            "status": "Down",
            "bytes_received": "135831270",
            "bytes_sent": "10376388",
            "ips": [
                "fe80::2df1:2144:c24d:6d9a",
                "169.254.109.154"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Yerel A\u011f Ba\u011flant\u0131s\u0131* 1",
            "id": "{D20CE92B-233B-4FE0-8126-326DB434603C}",
            "name": "Yerel A\u011f Ba\u011flant\u0131s\u0131* 1",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter",
            "type": "Wireless80211",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::c464:adac:cf8:fcf0",
                "169.254.252.240"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Yerel A\u011f Ba\u011flant\u0131s\u0131* 10",
            "id": "{0210B37E-28F9-43B7-B2E1-679EE958D1AB}",
            "name": "Yerel A\u011f Ba\u011flant\u0131s\u0131* 10",
            "description": "Microsoft Wi-Fi Direct Virtual Adapter #2",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::3c:7d05:9a91:4078",
                "169.254.64.120"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Wi-Fi",
            "id": "{4F4575E6-4C9C-4428-BA18-E33502D21079}",
            "name": "Wi-Fi",
            "description": "Killer(R) Wireless-AC 1550i Wireless Network Adapter (9560NGW) 160MHz",
            "status": "Up",
            "bytes_received": "927675",
            "bytes_sent": "1905021",
            "ips": [
                "10.34.104.248"
            "gateways": [
                "10.34.104.1"
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Bluetooth A\u011f Ba\u011flant\u0131s\u0131",
            "id": "{3E913861-E120-471D-982E-EF1E115901C7}",
            "name": "Bluetooth A\u011f Ba\u011flant\u0131s\u0131",
            "description": "Bluetooth Device (Personal Area Network)",
            "type": "Ethernet",
            "status": "Down",
            "bytes_sent": "0",
            "ips": [
                "fe80::8d71:78c0:50b4:4e78",
                "169.254.78.120"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
            "friendly": "Loopback Pseudo-Interface 1",
            "id": "{9B7F9960-B923-11E9-BB96-806E6F6E6963}",
            "name": "Loopback Pseudo-Interface 1",
            "description": "Software Loopback Interface 1",
            "type": "Loopback",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "::1",
                "127.0.0.1"
            "gateways": [],
            "bind": true,
            "dns4": "",
            "dns6": null
    "ipv4-default-gateway": "10.34.104.1",
    "ipv4-default-interface": "{4F4575E6-4C9C-4428-BA18-E33502D21079}"
ipconfig /all:
Windows IP Configuration
   Host Name . . . . . . . . . . . . : onurduran
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Mixed
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : kykwifi.com
Ethernet adapter Ethernet:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Killer E3000 2.5 Gigabit Ethernet Controller
   Physical Address. . . . . . . . . : 30-65-EC-C5-72-14
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Unknown adapter Yerel A§ Ba§lants:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-81-E4-C4-3A
Wireless LAN adapter Yerel A§ Ba§lants* 1:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 48-A4-72-52-60-AD
Wireless LAN adapter Yerel A§ Ba§lants* 10:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : 4A-A4-72-52-60-AC
Wireless LAN adapter Wi-Fi:
   Connection-specific DNS Suffix  . : kykwifi.com
   Description . . . . . . . . . . . : Killer(R) Wireless-AC 1550i Wireless Network Adapter (9560NGW) 160MHz
   Physical Address. . . . . . . . . : 86-D9-01-AE-34-63
   Link-local IPv6 Address . . . . . : fe80::9174:8ed1:3c38:a7c0%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.34.104.248(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.252.0
   Lease Obtained. . . . . . . . . . : 25 Nisan 2020 Cumartesi 20:24:27
   Lease Expires . . . . . . . . . . : 26 Nisan 2020 Pazar 08:52:03
   Default Gateway . . . . . . . . . : 10.34.104.1
   DHCP Server . . . . . . . . . . . : 1.1.1.1
   DHCPv6 IAID . . . . . . . . . . . : 193386753
   DHCPv6 Client DUID. . . . . . . . : 00-03-00-01-86-D9-01-AE-34-63
   DNS Servers . . . . . . . . . . . : 10.106.4.20
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth A§ Ba§lants:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 48-A4-72-52-60-B0
