Torry 0 Posted ... I selected the option "Network Lock" and then activated the Eddie client and I'll show you all the rest: Every five minutes, it give me an "inactivity timeout (ping restart) restarting. So damn frustrating to have to go through this. Is there a way to remove that part of the equation from the client because this is SERIOUSLY frustrating. Eddie Client Report.txt Share this post Link to post
Tech Jedi Alex 1586 Posted ... Well, first of all I think you're misusing your distribution (quoted DistroWatch): Quote BackBox Linux is an Ubuntu-based distribution developed to perform penetration tests and security assessments. It fits into the reputation Kali Linux has and Kali is not even intended to be installed, let alone a daily driver. Unless you absolutely know what you are doing, of course, but most of them "Kali installers" are not. Next thing: There's a 2.18 beta (doesn't feel like a beta) which fixes a plethora of issues and problems with the current stable. Might also fix it for you. Look in the Announcement section for links and How-Tos. Third, in the Logs tab, click the lifebelt icon and paste the output here. Gives more info about your setup like library versions and interface configuration, and seeing that you're having a networking-related problem it might come in handy. Fourth.. are you asking to remove the inactivity timeout (as in, this "bug"), or just the message? Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Torry 0 Posted ... Thanx for the reply: It doesn't matter what Linux distro I use. The output would still be the same - I used Mint, Fedora Gnome and KDE versions, and KDE Neon. Still had a constant timing out of connection due to "inactivity" which of course, wasn't true at all. I downloaded and installed the experimental version and so far so good. Here's the output : It seems that the timeout and/or timers have been modified. Hopefully for the best. The inactivity timeout I was asking for to be removed was for the non-experimental version because I believe that it was a bug. I'm not for sure if it even was a bug. Eddie_20200301_170541.txt Share this post Link to post
