sableslayer
ANSWERED eddie-cli armhf problems internet connection problems (solved)
Just tried using the portable eddie-cli for arm devices. Once i connected to the vpn and disconnected, i can no longer connect to the internet without vpn. how does one undo this ? I did not have -netlock option enabled.
~/.eddie-cli_2.16.3_linux_armhf_portable/eddie-cli  -login=un -password=pw -connect
Any suggestions to getting it to connect without vpn again ?  Thank you =)
