floki1
DNS problems
Hello dear people,
I used Airvpn for almost a year now. Never had ANY problems with it. So I wanted to say thank you for that. On the other hand I face some weird error since a few days. I'm leaking dns as hell as I checked it on numerous dns check sites. At first I thought it might me something wrong with Eddie. I use Eddie on my Windows 10 machine. So I quicky bought another VPN to test it and faced the same error.
Error description: I coudn't get any dns for example on ipleak.net and coud only browse a google search. If i wanted to go on youtube or what/ever it woudnt load the site. I still could ping those sites via cmd. What I found from the forum here was to uncheck "Check if the tunnels works" and "Check AirVpn DNS". After that i somehow worked again so I could browse again with VPN on. I went checking my dns on ipleak: still nothing. So i went to another similar site to check my dns and the first entry for my dns was airs dns and every after was my isp dns.
I dont know what happenend, maybe some of you faced the same error and could solve something like that already.
What I have done already:
Deinstall Eddie.
Deinstall Tapdriver.
Update normal network driver
Restart PC
Installed everything again.
Tried another VPN to verifiy where the problem lays.
As I had it on the other VPN too, it must be my system or?
But I didnt change anythign at all and i can handle computer and networking somewhat.
If anyone has read all that text, thank you! : - D
Another Edit: I have set my network interfaces on automatic dns and stuff. I tried to change the metric to 1. I tried under protocol in Eddie TCP Port 443 IP 3. Nothing helped.
Edited ... by floki1
typos and added sth
Im not having any address issues but, I just checked at ipleak and yep, the DNS result was 0 servers, 99 problems and says Im leaking DNS..
I wonder if this is somehow related to Eddie turning into an almost unusable wreck on MacOS the last couple months?
Ive been on Air a little over a year and its been 110% awesome up until recently, when Im having weird connection errors, and just having trouble connecting to the VPN period (its always hanging at the Checking IPv4 status).
