jsmith2111 0 Posted ... Hello guys, I was wondering if there is a speed limitation while using OpenVPN with Router, technically it's AsusWRT, using Asus AC68. I saw some threads in AirVPN before, but I think they were dragged down to the bottom of the forum, since it's been quite some time. I'm upgrading to get better bandwidth, and I was wondering if this happens. Should it happen, does it have any fixes? Thank you in advance. Best Regards,J.Smith Quote Share this post Link to post
go558a83nk 380 Posted ... Yes, the AC68 will limit you to about 50mbit/s max. The CPU in routers can't encrypt/decrypt super fast. Quote Share this post Link to post
jsmith2111 0 Posted ... Thanks for replying, If that's the case then I have to resort to install per device. Quote Share this post Link to post
flat4 92 Posted ... or build a pfsense box with an intel chip Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
go558a83nk 380 Posted ... or build a pfsense box with an intel chip It doesn't have to be an intel chip. AMD chips have AES-NI too. AES-NI is what's important. For a pfsense box you don't need a huge CPU with 8+ cores. Mine is AMD, has 2 cores, and can do at least 430mbit/s openvpn with AES-256-GCM data channel. I don't know how much faster as that's my ISP max. Quote Share this post Link to post
flat4 92 Posted ... or build a pfsense box with an intel chip It doesn't have to be an intel chip. AMD chips have AES-NI too. AES-NI is what's important. For a pfsense box you don't need a huge CPU with 8+ cores. Mine is AMD, has 2 cores, and can do at least 430mbit/s openvpn with AES-256-GCM data channel. I don't know how much faster as that's my ISP max.** caught** yes i am biased, but he is correct amd can do the same it doesn't have to be a beast, Quote Hide flat4's signature Hide all signatures pFsense it works Share this post Link to post
jsmith2111 0 Posted ... Crap guys, my speed just got dropped from 5mbit/s to 0.2mbit/s. It's just been 1 day, what the hell happened? Quote Share this post Link to post
