bar3
teltonika rut500 openvpn problem
hi guys,
my  modem router is teltonika rut500
i can connect servers with eddie
im trying to connect server only using modem router interface
but im beginner in openvpn world .
as you can see in attached file
 what are these values ?
remote host/ip address
remote network ip adress
remote network ip netmask
and how can i create client certificates and keys ?
 sorry for my bad english .
hi guys,
all the info will be in the openvpn config files that you can create in your configuration generator.  I suggest you select advanced settings, click resolved hosts in ovpn, and separate certs and keys.
hi guys,
thak you for reply. i will try it asap
last question
i found server ip and port numbers in (.ovpn) file
exp(frankurt-adhara ip 185.104.184.42  port 443)
but remote network ip adress and netmask is missing.
what are these values?
hi guys,
last question
The remote host/IP Address will be the IP address of the server you want to connect to.
Leave remote network IP address and netmask blank as those are passed by DHCP.
