Necronlord666 0 Posted ... Hi, I have tried quite a few things to get Plex remote access to work while AirVPN is running. I have gone into the client area and added 32400 to the forwarded ports and the TCP test comes back green so that worked. Do I need to then port forward 32400 in my router as well? When I do I just get an error and it says "Could not set "Virtual Servers"" If I try to add 32402 to my router that works perfectly fine, but when I add 32402 to the AirVPN Forwarded ports, it doesn't pass the TCP test. In Plex, the public IP is the AirVPN IP. Just at a loss of how to get this to work correctly. Thanks Quote Share this post Link to post
arealcoolhand 0 Posted ... This might sound like a silly question but are you connecting to the same AirVPN server on multiple devices? If so, that will prevent port forwarding from working. Otherwise, the main thing is the Local Port being 32400 as you mentioned. I haven't had to mess with my router and have full outside accessibility on Plex with Eddie running as long as I set my devices to connect to separate servers. Quote Share this post Link to post
go558a83nk 378 Posted ... Hi, I have tried quite a few things to get Plex remote access to work while AirVPN is running. I have gone into the client area and added 32400 to the forwarded ports and the TCP test comes back green so that worked. Do I need to then port forward 32400 in my router as well? When I do I just get an error and it says "Could not set "Virtual Servers"" If I try to add 32402 to my router that works perfectly fine, but when I add 32402 to the AirVPN Forwarded ports, it doesn't pass the TCP test. In Plex, the public IP is the AirVPN IP. Just at a loss of how to get this to work correctly. Thanks If you're using the AirVPN openvpn client (Eddie) then you DO NOT open ports on your router. Plex is giving you the error "could not set virtual servers" ? If so, ask the plex folks. Quote Share this post Link to post
