Thebrynn 1 Posted ... Dear all, I am trying to get the new DE server Adhara to work with my DD-WRT router. Every other server works fine (as well as the DE server group IP), but for some reason I can't seem to connect to this 185.104.184.42 IP address. Is there something special to the new servers that we need to set up differently? I use the default UDP 443 port, have AES-256 CBC as the encryption cypher, have the Hash algorithm as SHA1 and have the TLS Cypher as TLS-DHE-RSA-WITH-AES-256-GCM-SHA384This seems to work for everything but this one server. I have tried changing some of the settings, but without any success at the moment. Does anyone have any ideas? thanks in advance! reason for changing was that Menkib was given me some website browsing issues (some websites can't be resolved, but it does work with other servers). Quote Share this post Link to post
Thebrynn 1 Posted ... I tried it now again and below you can find the log. it never sends the TLS packet to initiate the connection apparently. When I try to ping / pathping / trace the route to this server I can't seem to reach it.The other servers in Germany I can reach fine. so not sure what is going on here to be honest. Clientlog: 20170509 21:36:53 I OpenVPN 2.3.12 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Sep 9 2016 20170509 21:36:53 I library versions: OpenSSL 1.0.2h 3 May 2016 LZO 2.09 20170509 21:36:53 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:16 20170509 21:36:53 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts 20170509 21:36:53 W WARNING: file '/tmp/openvpncl/client.key' is group or others accessible 20170509 21:36:53 W WARNING: file '/tmp/openvpncl/ta.key' is group or others accessible 20170509 21:36:53 I Control Channel Authentication: using '/tmp/openvpncl/ta.key' as a OpenVPN static key file 20170509 21:36:53 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 20170509 21:36:53 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication 20170509 21:36:53 Socket Buffers: R=[180224->180224] S=[180224->180224] 20170509 21:36:53 I UDPv4 link local: [undef] 20170509 21:36:53 I UDPv4 link remote: [AF_INET]182.104.184.42:443 20170509 21:37:36 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 20170509 21:37:36 D MANAGEMENT: CMD 'state' 20170509 21:37:36 MANAGEMENT: Client disconnected 20170509 21:37:36 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 20170509 21:37:36 D MANAGEMENT: CMD 'state' 20170509 21:37:36 MANAGEMENT: Client disconnected 20170509 21:37:36 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 20170509 21:37:36 D MANAGEMENT: CMD 'state' 20170509 21:37:36 MANAGEMENT: Client disconnected 20170509 21:37:36 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 20170509 21:37:36 D MANAGEMENT: CMD 'status 2' 20170509 21:37:36 MANAGEMENT: Client disconnected 20170509 21:37:36 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16 20170509 21:37:36 D MANAGEMENT: CMD 'log 500' 19700101 01:00:00 ca /tmp/openvpncl/ca.crt cert /tmp/openvpncl/client.crt key /tmp/openvpncl/client.key management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto udp cipher aes-256-cbc auth sha1 remote 182.104.184.42 443 comp-lzo yes tls-client tun-mtu 1500 mtu-disc yes ns-cert-type server fast-io tun-ipv6 tls-auth /tmp/openvpncl/ta.key 1 tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384 Quote Share this post Link to post
go558a83nk 389 Posted ... Looks like your ISP is blocking your access to that server. Quote Share this post Link to post
Thebrynn 1 Posted ... Looks like your ISP is blocking your access to that server. That would be interesting that Deutsche Telekom blocks that server in particular. It's the last one that was installed in Germany to my understanding. Luckily they don't block all the DE AirVPN servers yet :-) I guess smarter to leave it at that, and not reach out to them to ask why I can't reach this IP. Quote Share this post Link to post
go558a83nk 389 Posted ... Looks like your ISP is blocking your access to that server. That would be interesting that Deutsche Telekom blocks that server in particular. It's the last one that was installed in Germany to my understanding. Luckily they don't block all the DE AirVPN servers yet :-) I guess smarter to leave it at that, and not reach out to them to ask why I can't reach this IP. If you can reach other servers using the same protocol and port then it seems they're blocking that IP address. It may stem from that IP address' previous history - before it belonged to AirVPN. Quote Share this post Link to post
Doesi 3 Posted ... You have the wrong ip in your setup: 182.104.184.42 <> 185.104.184.42 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
Thebrynn 1 Posted ... You have the wrong ip in your setup: 182.104.184.42 <> 185.104.184.42 Thanks! Well spotted for the original post (edited this one now), but as you can see in my config log I was using the correct IP. Quote Share this post Link to post
Doesi 3 Posted ... No, you did use the wrong IP. 185.104.184.42 is the correct one and works. Quote Share this post Link to post
Thebrynn 1 Posted ... No, you did use the wrong IP. 185.104.184.42 is the correct one and works. OMG, I am so sorry about that; What a silly copy paste error :/ Good news it is indeed working. Not sure where my brain was during these tests. Thanks again for spotting this silly error of mine! Quote Share this post Link to post
Tech Jedi Alex 1584 Posted ... It's amazing how fast people come to the conclusion that an ISP is blocking IPs when they run into an issue... If something ever does not work and you suspect your ISP, drop me a note. I'm with Deutsche Telekom, too. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
