SpencerUk 0 Posted ... Hi all, Wondering if some of you folks can help me here. I've got a Dual Wan load balance setup and I'm wondering if Air VPN supports this. Setup is Virgin Media - Cable Zen Internet - ADSL Both these are in modem mode going into my Asus RT-AC3200...I'm wondering if I configure the OpenVPN in my Asus Router (Running latest Merlin 380.63_2 // 12-Nov-2016) to work with this dual wan setup. I've ran the airvpn client on a windows 10 machine and I mainly get good speeds (180Mb via the single VM connection), but when i try to run it through the Asus router, I get no more than about 20Mb Quote Share this post Link to post
go558a83nk 383 Posted ... probably better to ask these questions at the asus-merlin forums http://www.snbforums.com/forums/asuswrt-merlin.42/ since they are technical questions about your router and not really AirVPN specific. I think your router should be able to do better than 20mbit/s (60mbit/s is my guess at max possible) but first make sure there's not another bottleneck in the path from you to the server. Have you tried testing from a PC using Eddie? Quote Share this post Link to post
SpencerUk 0 Posted ... Hi, I'll be sure to ask there too. As I mentioned above, I've tried the software direct to the computer and speeds....most of the time are ok...Do seem to fluctuate very wildly though over numerous servers. Quote Share this post Link to post
