Good morning to all, was wondering if anyone else is experiencing "port closed" on the transmission client? below are pics of how i have my asus ac68u set up as well as my macbook running osx sierra. am i missing something?? any help is greatly appreciated and thank you in advance.
attachicon.gifScreen Shot 2016-10-07 at 3.56.30 AM.pngattachicon.gifScreen Shot 2016-10-07 at 4.01.29 AM.pngattachicon.gifScreen Shot 2016-10-07 at 4.08.12 AM.png
You're doing it all wrong.
First, what device is running the openvpn client?  That'll determine what step is next.
However, either way, you need to disable automatic port mapping in your torrent client (nat-pmp, upnp) and disable the port forwards you created via your router GUI.
hello go55!! thanks for the reply, im actually running the airvpn on my asus ac68u router, so im currently not using the openvpn client. not sure if that helps?
