umiq88
DD-WRT Settings
Was wondering if its possible to do the following
Setup DD-WRT flashed router with AirVPN to connect to best available server in the UK.
however I only want 2 or maybe 3 of the devices on my network to use this connection and the rest to access the internet normally.
Yes possible Policy based Routing
You give the Devices which should use VPN a static ip add this ip in Policy based Routing Save, apply and reboot Router
If you use Standard ddwrt Settings
DHCP Start with .100
static ip Must be in this Range 192.168.1.2-192.126.1.99
i'd keep the router doin just that, routing and run each device connecting to it static and on itz own vpn server
I get the gist but I'm a little new to this would someone be willing to break it into step by step instruction.
I'm fine with the general networking and setting up the AirVPN client I need help to do the below.
Set Plex Server 192.168.1.X to access internet through AirVPN
Set AppleTV 192.168.1.X to access internet through AirVPN
Other hosts like laptop and phone should not be affected and assigned IPs from DCHP and connect through WAN interface. There should be no change to the settings.
However all other hosts on the 192.168.1.X network need to be able to communicate with the Plex Server and Apple TV e.g. laptop or iPhone which will be assigned IP from the DCHP server.
Add the 2 ips in Policy based Routing Field under openvpn Client 1ip per line
192.168.1.x
192.168.1.x
Save and apply done
Maybe you Need a reboot
192.168.1.x
192.168.1.x
Save and apply done
I just setup my router and was wondering this as well except I needed specify a range.  Was able to use 192.168.11.96/27 and it worked like a champ.
Thanks!
