I checked for MTU after connecting to one of the airvpn servers.
ping www.google.com -f -l 1472
1472 + 28
1500 turned out to be my MTU when I was connected to the VPN when I am not connected to the VPN the MTU is lower ?
Should I use 1500 in my router MTU setting or the usual MTU when I am not connected to the VPN.
Disconnect from the VPN and do the tests again. TCP Optimizer for Windows has got a nice feature to determine the max MTU for you. Assuming it will show you 1500, it means for UDP:
Max size - IP header = 1472 bytes.
Max size - (IP header + OpenVPN header) = 1392 bytes.
If you lower the MTU, say, by 28 bytes, you get a lower size in both scenarios which wouldn't be your max:
(Max size - 28 bytes) - IP header = 1444 bytes
(Max size - 28 bytes) - (IP header + OpenVPN header) = 1364 bytes
Ergo, don't worry about MTU, just use your max. If you use Windows, I recommend starting the program above with admin rights and do the TCP optimizations for your download speed. Windows' defaults are not the best.
