Anonymous_13 33 Posted ... Is it somehow possible to connect to a computer at home with RDP?Both the current and the home computer are inside the VPN (different servers though). If so which ports do I have to open and which IP i take to connect? Quote Share this post Link to post
go558a83nk 383 Posted ... It may be better to ask a windows forum about what port RDP uses. It's easy to create a forwarded port with AirVPN that redirects to a different local port (RDP port). However, can you tell your remote machine to connect to a port other than the usual RDP port? It will need to connect to the port AirVPN has opened externally. Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... Well, RDP by Microsoft uses TCP & UDP 3389. Check your config if it's really the port RDP uses in your case.Software like TeamViewer which also count as RDP software in some circumstances doesn't need a port, however, in their FAQs they talk about outbound port TCP/5938 "for mobile connections". which IP i take to connect AirVPN.exit.IP:AirVPNforwardedportFor Phoenicis it'd be 109.163.226.153:3389. 3389 is taken, though, so you'd use some other free port but forward it to local 3389. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
