What the hell is going on?!??!
Since a few days, my Twitch Stream is constantly buffering. And not only that, as soon as I open a stream, I get disconnected.
Never had problems with this before, only started a few days ago.
Check your system, I don't have problems with Twitch. Did you install something? Did Windows install updates? Some logs could help as well, post them into spoiler tags to maximize time effectiveness for the viewers.
No, I didn't install or change anything, that's what's funny. As soon as I open a stream, my connection drops.
Okay, what about logs? I asked for them.
(Sent via Tapatalk - this generally means I'm not sitting in front of my PC)
logs from where? The client software does not show anything. It doesn't even "disconnect". But I know it disconnected, because every other application I have running loses connection as soon as the twitch stream starts.
After disconnecting and reconnecting, it seems to be working. Besides the annoying rebuffering issue it always had.
It shouldn't disturb playback if everything was alright.
Now, I assume you use the AirVPN client. The last tab of the client's windows is Logs, that's where you can view, copy and save them.
Connect and watch some stream. Let it run for 30 seconds or so. Then disconnect and go to the Logs tab. Save it as a .log file and upload it here, for this you need to click on More Reply Options, below the editor you will see Attach Files.
Help us helping you.
Until now it didn't happen again. So no logs. I tried to "force" it, but everything seems to work fine.
I will wait untill tomorrorw, as I will have my usual setup and see if it happens again. If it does, I will post the logs.
Always the same thing. It fails every single time, but when you want it to fail, all of a sudden, it works flawlessly. Making me look like a fool
Then always want it to fail. Pray. Scream at it. Do some ritual, I don't know.
I use Twitch every single day. No problems whatsoever. Sorry if this is not helpful, but I wanted everyone to know that the problem is not with AirVPN nor the Eddie client.
