Not connected, Your IP: 216.73.216.73
High speed, but websites loads slowly.
Hello, I recently installed windows 7 after using AirVPN on windows 8.1 for a short period. On windows 8.1 the VPN was working perfectly, but on windows 7 the speeds are the same and are very good, but websites load really really slow for some reason. Without the VPN everything loads quickly again. I've tried different browser and all that. I'm getting around 54/54 Mb/s and I'm paying for 60/60, so the speeds are very good imo.
Thank you.
All websites. Youtube takes like 20 seconds to load with the vpn, and only a couple of seconds without.
you might want to use the route checking feature in the status section to see latency to youtube from all the servers.  It's possible the VPN server you're using is connecting to a youtube server that's far away instead of close.  I've seen it before.
