ssiva
network connection issue
Seemingly I can't visit websites normally after I turn on VPN connection. The Chrome redirects me to outbrain com which I'm not familiar with at all. What's going on?
Try resetting your home page to airvpn.org, and if that fails, then you probably have one or more trojans messing things up for you.
Consider a reinstall of Chrome, or even better a replacement of Firefox instead of Chrome. Go here to make a profile for Firefox that will get rid of all the privacy and security junk you do not want.
Firefox Profilemaker
If you stick with Chrome, I cannot really help you since I have never tried it.
