alancheng814
Very Slow connection when connected to vpn
I am currently in a boarding school and the vast majority of people use vpn to bypass all the blocked websites and play online games. For some reason, my mates can play online games with a low ping but my ping is always very high. I have been looking this up and almost all websites suggested that to disable the Use Default Gateway on Remote Network.  However, there is not an option as I am currently using windows 8.
Is there any ways that I can fix this problem?
Thx a lot
If you have reasonably fast connection speed than try resetting the buffers in the AirVPN client from 128KB to 256KB.
(in "AirVPN" -> "Preferences" -> "Advanced" -> "General"). Click "Save" and start a new VPN connection.
If that method doesn't work try doing a connection through SSL.
Hi !
look at this poor connection...Down: 0.650 Mbit/s Out, 1.145 Mbit/s In (176%), 1MB - Up: 5.352 Mbit/s Out, 5.274 Mbit/s In (98%), 10MB - Date: Sun, 31 Jan 2016 09:51:58 GMT - Buffers: 1MB/10MB - Laps: 3, Time: 202.61 secs
Up 5 times speed than DL ! ???
and 176% out/in tube.. strange ?
Hi !
The speedtest here is not reliable. You probably want to use Ookla's test or, even better, download something and see what speeds you get.
