tinysprings
DNS trouble while unconnected
I have some troubles with my internet connection while disconnected from the VPN.
As soon as I disconnect from the VPN, every access to any URL gives an adress naming error after a quite long time out.
Windows connectivity diagnosis reports a problem with DNS server.
Network lock is not activated, I'm using this VPN for one month without problem up to now. I restarted/reseted the box, disabled temporarilly the firewall, no success. I can only access internet from the VPN.
There has been no update of any software from the working to not working state.
Is there anybody that could drive me to do some test to try to locate where the problem comes from ?
Thanks for your help.
Laurent
