Not connected, Your IP: 216.73.216.195
batanun
Decent routers for streaming? And possible to disable encryption?
So I was wrong. You definitely have AES-NI enabled. One more thing: have You enabled it in pfSense System > Advanced > Miscellaneous > Cryptographic Hardware Acceleration? and in OpenVPN Client config for AIR (Hardware Crypto - cryptodev in client configuration)?
You may also try to temporarily disable PowerD in System > Advanced > Miscellaneous in Power Savings. Because my N3150 gives 2-4 times better results in openssl speed test (however, even Your result should be enough).
Yes, it's enabled in advanced/misc/crypto and in the OpenVPN client config.  PowerD is disabled on my system as well.
Then You might take a look at this:
https://community.openvpn.net/openvpn/wiki/Gigabit_Networks_Linux
and experiment with mssfix and tun-mtu. Increasing tun-mtu gives some speed advance (take a look at discussion on this forum regarding tun-mtu and mssfix). I plan to setup some local server ant test my router in locally out of curiosity. Will publish results here.
Hi Karznie
I do have aesni.ko loaded and get results from openssl openssl speed -evp aes-256-cbc similar to SirJohn
 kldstat                                            Id Refs Address            Size     Name
 1    4 0xffffffff80200000 22d84c8  kernel
 2    1 0xffffffff82611000 54e5     aesni.ko
type             16 bytes     64 bytes    256 bytes   1024 bytes   8192 bytes
aes-256-cbc      32634.51k   161881.12k   541340.67k  2005316.40k 16224354.30k
However I was confused when I said I couldn't turn hardware encryption off. What I should have said is that download speeds don't get slower when I do. In fact on closer inspection I unexpectedly found that they get faster. Up to 150 Mb/s
openssl is also interesting without aesni.ko loaded I get.
aes-256-cbc     118977.15k   162137.30k   187641.86k   195252.22k   197585.58k
Much lower for 8192 blocks but much higher for 16 byte blocks. With as I said faster real life OpenVPN performance.
Clearly I don't understand what is going on.
