ma001ta
AirVPN Using Merlin 378.55_beta1
Can anyone tell me what I'm doing wrong here? I've uploaded the config file once it was generated yet I can't access the WAN once started. System log follows:
Jul 11 00:37:13 rc_service: httpd 475:notify_rc start_vpnclient1
Jul 11 00:37:13 kernel: tun: Universal TUN/TAP device driver, 1.6
Jul 11 00:37:13 kernel: tun: © 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Jul 11 00:37:13 openvpn[1132]: OpenVPN 2.3.7 arm-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Jul  3 2015
Jul 11 00:37:13 openvpn[1132]: library versions: OpenSSL 1.0.2c 12 Jun 2015, LZO 2.08
Jul 11 00:37:13 openvpn[1133]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Jul 11 00:37:13 openvpn[1133]: Control Channel Authentication: using 'static.key' as a OpenVPN static key file
Jul 11 00:37:13 openvpn[1133]: Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Jul 11 00:37:13 openvpn[1133]: Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Jul 11 00:37:13 openvpn[1133]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Jul 11 00:37:13 openvpn[1133]: UDPv4 link local: [undef]
Jul 11 00:37:13 openvpn[1133]: UDPv4 link remote: [AF_INET]46.29.125.13:443
Jul 11 00:37:14 openvpn[1133]: TLS: Initial packet from [AF_INET]46.29.125.13:443, sid=58fd4adc ca787124
Jul 11 00:37:14 openvpn[1133]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Jul 11 00:37:14 openvpn[1133]: Validating certificate key usage
Jul 11 00:37:14 openvpn[1133]: ++ Certificate has key usage  00a0, expects 00a0
Jul 11 00:37:14 openvpn[1133]: VERIFY KU OK
Jul 11 00:37:14 openvpn[1133]: Validating certificate extended key usage
Jul 11 00:37:14 openvpn[1133]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jul 11 00:37:14 openvpn[1133]: VERIFY EKU OK
Jul 11 00:37:14 openvpn[1133]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Jul 11 00:37:18 openvpn[1133]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Jul 11 00:37:18 openvpn[1133]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jul 11 00:37:18 openvpn[1133]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Jul 11 00:37:18 openvpn[1133]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jul 11 00:37:18 openvpn[1133]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
Jul 11 00:37:18 openvpn[1133]: [server] Peer Connection Initiated with [AF_INET]46.29.125.13:443
Jul 11 00:37:20 openvpn[1133]: SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Jul 11 00:37:21 openvpn[1133]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.101 255.255.0.0'
Jul 11 00:37:21 openvpn[1133]: OPTIONS IMPORT: timers and/or timeouts modified
Jul 11 00:37:21 openvpn[1133]: OPTIONS IMPORT: LZO parms modified
Jul 11 00:37:21 openvpn[1133]: OPTIONS IMPORT: --ifconfig/up options modified
Jul 11 00:37:21 openvpn[1133]: OPTIONS IMPORT: route options modified
Jul 11 00:37:21 openvpn[1133]: OPTIONS IMPORT: route-related options modified
Jul 11 00:37:21 openvpn[1133]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Jul 11 00:37:21 openvpn[1133]: TUN/TAP device tun11 opened
Jul 11 00:37:21 openvpn[1133]: TUN/TAP TX queue length set to 100
Jul 11 00:37:21 openvpn[1133]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Jul 11 00:37:21 openvpn[1133]: /usr/sbin/ip link set dev tun11 up mtu 1500
Jul 11 00:37:21 openvpn[1133]: /usr/sbin/ip addr add dev tun11 10.4.0.101/16 broadcast 10.4.255.255
Jul 11 00:37:26 openvpn[1133]: Ignore conflicted routing rule: 46.29.125.13 255.255.255.255
Jul 11 00:37:26 openvpn[1133]: /usr/sbin/ip route add 0.0.0.0/1 via 10.4.0.1
Jul 11 00:37:26 openvpn[1133]: /usr/sbin/ip route add 128.0.0.0/1 via 10.4.0.1
Jul 11 00:37:26 openvpn-routing: Skipping, client 1 not in routing policy mode
Jul 11 00:37:26 openvpn[1133]: Initialization Sequence Completed
Jul 11 00:38:12 openvpn[1133]: event_wait : Interrupted system call (code=4)
Jul 11 00:38:12 openvpn[1133]: OpenVPN STATISTICS
Jul 11 00:38:12 openvpn[1133]: Updated,Sat Jul 11 00:38:12 2015
Jul 11 00:38:12 openvpn[1133]: TUN/TAP read bytes,6665
Jul 11 00:38:12 openvpn[1133]: TUN/TAP write bytes,5302
Jul 11 00:38:12 openvpn[1133]: TCP/UDP read bytes,18229
Jul 11 00:38:12 openvpn[1133]: TCP/UDP write bytes,20310
Jul 11 00:38:12 openvpn[1133]: Auth read bytes,5334
Jul 11 00:38:12 openvpn[1133]: pre-compress bytes,0
Jul 11 00:38:12 openvpn[1133]: post-compress bytes,0
Jul 11 00:38:12 openvpn[1133]: pre-decompress bytes,0
Jul 11 00:38:12 openvpn[1133]: post-decompress bytes,0
Jul 11 00:38:12 openvpn[1133]: END
Jul 11 00:38:18 rc_service: httpd 475:notify_rc stop_vpnclient1
Jul 11 00:38:18 openvpn[1133]: event_wait : Interrupted system call (code=4)
Jul 11 00:38:18 openvpn[1133]: SIGTERM received, sending exit notification to peer
Jul 11 00:38:19 dnsmasq[1115]: exiting on receipt of SIGTERM
Jul 11 00:38:20 dnsmasq[1191]: started, version 2.73rc8 cachesize 1500
Jul 11 00:38:20 dnsmasq[1191]: warning: interface ppp1* does not currently exist
Jul 11 00:38:20 dnsmasq[1191]: asynchronous logging enabled, queue limit is 5 messages
Jul 11 00:38:20 dnsmasq-dhcp[1191]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Jul 11 00:38:20 dnsmasq[1191]: read /etc/hosts - 5 addresses
Jul 11 00:38:20 dnsmasq[1191]: using nameserver 75.75.76.76#53 for domain local
Jul 11 00:38:20 dnsmasq[1191]: using nameserver 75.75.76.76#53 for domain hsd1.ct.comcast.net
Jul 11 00:38:20 dnsmasq[1191]: using nameserver 75.75.75.75#53 for domain local
Jul 11 00:38:20 dnsmasq[1191]: using nameserver 75.75.75.75#53 for domain hsd1.ct.comcast.net
can't access the WAN literally or do you mean that nothing "works"?  I would imagine it's your use of comcast DNS while connected to VPN.  comcast probably rejects any DNS queries from IP other than their own network.  In this case it would be coming from the VPN exit IP.
you should certainly set your DNS to something other than ISP DNS to avoid their logging.  In the openvpn client page set "accept DNS configuration" to exclusive.  That way you'll be sure to use AirVPN DNS.
