Not connected, Your IP: 216.73.216.117
edobrez
issues in China, rhel 6.6
Hi
on my rhel 6.6 system I can't install mono for corporate compliance.
I have installed openvpn and was trying to use it from the console or via NetworkManager.
at the moment, I am connected from China via the corporate VPN but was looking at some independent solution.
when I disconnect the corporate VPN, and triy to connect using openvpn
udp 443 fails to connect (timeout)
ssh tunnel port 22 and ssl tunnel on 443 both connect
I get a tun0 device with a 10.... IP.
note that I had the openvpn config files imported in NetworkManager else resolv.conf did not get updated.
however if I try to ping the 10.*  dns server that appears in resolv.conf
I never get a reply.
I can't even ping google's own DNS servers
so after I connect via openvpn I am effectively isolated although with a 10.* IP address.
I even tried flushing my iptables but no change
(and anyway the tun0 device created by my corporate VPN dialler works fine)
suggestions welcome
I have made progress ! I am posting here connected through airvpn ...
- used the ssh port 22 alt.ip  configuration
- connecting to the America region
- not dialling openvpn with NetwrokManager
but launched on the command line
with Networkmanager though I had modified the connection to the hotel wireless not to use its dns servers
but to use Google's (8.8.8.8 and 8.8.4.4).
I can't yet use Airvpn 's DNS servers
after further testing, the ssh tunnel solution works with the following limitation
- using the chinese hotel wifi, asia servers do not seem reachable
europe and america are ok
-due to my platform (rhel 6.6)
I can't use mono so the airvpn packages can't be run (also the 'portable one' seem to require mono)
- if I import the opvn in Networkmanager, vpn connection succeeds and a 10.*** nameserver entry is added to resolv.conf
BUT
the connection is useless, cannot ping anything
if I use openvpn from the command line, resolv.conf is not updated
-even including the suggested line
up /etc/openvpn/update-resolv-conf
in the ovpn file is irrelevant as the platform does not include a  /sbin/resolvconf
so to use the Airvpn DNS I need to edit resolv.conf myself
