AnonSyn
Trying to connect continuously but fail
Hi, my airvpn client sometimes work and sometimes no.
im using it on  Windows 8.1  64 Bit,
it try always to connect, but than it fail and try again, continuously.... than maybe after 4-5 try, sometimes is able to connect.
. 2015.02.12 09:29:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.02.12 09:29:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.02.12 09:29:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.02.12 09:29:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.02.12 09:29:12 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2015.02.12 09:29:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]178.248.30.131:443
. 2015.02.12 09:29:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.02.12 09:29:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.137.206 10.4.137.205'
. 2015.02.12 09:29:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.02.12 09:29:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.02.12 09:29:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.02.12 09:29:14 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.02.12 09:29:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.02.12 09:29:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.02.12 09:29:14 - OpenVPN > open_tun, tt->ipv6=0
. 2015.02.12 09:29:14 - OpenVPN > TAP-WIN32 device [Local Area Connection] opened: \\.\Global\{F6C6F719-811A-4035-9DFE-123D46C5741C}.tap
. 2015.02.12 09:29:14 - OpenVPN > TAP-Windows Driver Version 9.9
. 2015.02.12 09:29:14 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.137.206/255.255.255.252 on interface {F6C6F719-811A-4035-9DFE-123D46C5741C} [DHCP-serv: 10.4.137.205, lease-time: 31536000]
. 2015.02.12 09:29:14 - OpenVPN > Successful ARP Flush on interface [15] {F6C6F719-811A-4035-9DFE-123D46C5741C}
. 2015.02.12 09:29:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:19 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:25 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:26 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:27 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:28 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:29 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:30 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:31 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:32 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:33 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:34 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:35 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:36 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:37 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:38 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:39 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:40 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:41 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:43 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:44 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:45 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:46 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:47 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up...
. 2015.02.12 09:29:48 - AirVPN Windows Interface Hack executed (Local Area Connection)
. 2015.02.12 09:29:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=1 ret=0 a=0 u/d=down
. 2015.02.12 09:29:50 - OpenVPN > C:\Windows\system32\route.exe ADD 178.248.30.131 MASK 255.255.255.255 192.168.1.1
. 2015.02.12 09:29:50 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.02.12 09:29:50 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.02.12 09:29:50 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.137.205
. 2015.02.12 09:29:50 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.137.205
. 2015.02.12 09:29:50 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.02.12 09:29:50 - OpenVPN > Route addition fallback to route.exe
. 2015.02.12 09:29:50 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.02.12 09:29:50 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.137.205
. 2015.02.12 09:29:50 - OpenVPN > C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.137.205
. 2015.02.12 09:29:50 - OpenVPN > SYSTEM ROUTING TABLE
. 2015.02.12 09:29:50 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=3 t=4 pr=3 a=68809 h=0 m=20/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.137.205 p=0 i=3 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 10.4.0.1 255.255.255.255 10.4.137.205 p=0 i=3 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 10.4.181.60 255.255.255.252 10.4.181.62 p=0 i=15 t=3 pr=2 a=27759 h=0 m=286/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 10.4.181.62 255.255.255.255 10.4.181.62 p=0 i=15 t=3 pr=2 a=27759 h=0 m=286/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 10.4.181.63 255.255.255.255 10.4.181.62 p=0 i=15 t=3 pr=2 a=27759 h=0 m=286/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=68817 h=0 m=306/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=68817 h=0 m=306/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=68817 h=0 m=306/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.137.205 p=0 i=3 t=4 pr=3 a=0 h=0 m=21/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 178.248.30.131 255.255.255.255 192.168.1.1 p=0 i=3 t=4 pr=3 a=0 h=0 m=20/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.7 p=0 i=3 t=3 pr=2 a=68809 h=0 m=276/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 192.168.1.7 255.255.255.255 192.168.1.7 p=0 i=3 t=3 pr=2 a=68809 h=0 m=276/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.7 p=0 i=3 t=3 pr=2 a=68809 h=0 m=276/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=68817 h=0 m=306/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.7 p=0 i=3 t=3 pr=2 a=68815 h=0 m=276/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 224.0.0.0 240.0.0.0 10.4.181.62 p=0 i=15 t=3 pr=2 a=28236 h=0 m=286/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=68817 h=0 m=306/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.7 p=0 i=3 t=3 pr=2 a=68815 h=0 m=276/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > 255.255.255.255 255.255.255.255 10.4.181.62 p=0 i=15 t=3 pr=2 a=28236 h=0 m=286/0/0/0/0
. 2015.02.12 09:29:50 - OpenVPN > SYSTEM ADAPTER LIST
. 2015.02.12 09:29:50 - OpenVPN > TAP-Windows Adapter V9
. 2015.02.12 09:29:50 - OpenVPN >   Index = 15
. 2015.02.12 09:29:50 - OpenVPN >   GUID = {F6C6F719-811A-4035-9DFE-123D46C5741C}
. 2015.02.12 09:29:50 - OpenVPN >   IP = 10.4.181.62/255.255.255.252
. 2015.02.12 09:29:50 - OpenVPN >   MAC = 00:ff:f6:c6:f7:19
. 2015.02.12 09:29:50 - OpenVPN >   GATEWAY = 0.0.0.0/255.255.255.255
. 2015.02.12 09:29:50 - OpenVPN >   DHCP SERV = 10.4.181.61/255.255.255.255
. 2015.02.12 09:29:50 - OpenVPN >   DHCP LEASE OBTAINED = Thu Feb 12 01:47:11 2015
. 2015.02.12 09:29:50 - OpenVPN >   DHCP LEASE EXPIRES  = Fri Feb 12 01:47:11 2016
. 2015.02.12 09:29:50 - OpenVPN >   DNS SERV = 10.4.0.1/255.255.255.255
. 2015.02.12 09:29:50 - OpenVPN > Intel(R) 82579V Gigabit Network Connection
. 2015.02.12 09:29:50 - OpenVPN >   Index = 3
. 2015.02.12 09:29:50 - OpenVPN >   GUID = {F304CEDC-CF03-4905-A317-530B2EA07D1E}
. 2015.02.12 09:29:50 - OpenVPN >   IP = 192.168.1.7/255.255.255.0
. 2015.02.12 09:29:50 - OpenVPN >   MAC = e0:3f:49:7d:21:cf
. 2015.02.12 09:29:50 - OpenVPN >   GATEWAY = 192.168.1.1/255.255.255.255
. 2015.02.12 09:29:50 - OpenVPN >   DHCP SERV = 192.168.1.1/255.255.255.255
. 2015.02.12 09:29:50 - OpenVPN >   DHCP LEASE OBTAINED = Thu Feb 12 08:23:01 2015
. 2015.02.12 09:29:50 - OpenVPN >   DHCP LEASE EXPIRES  = Thu Feb 12 14:23:01 2015
. 2015.02.12 09:29:50 - OpenVPN >   DNS SERV = 192.168.1.1/255.255.255.255
. 2015.02.12 09:29:50 - Starting Management Interface
. 2015.02.12 09:29:50 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )
I 2015.02.12 09:29:50 - Flushing DNS
! 2015.02.12 09:29:50 - Disconnecting
. 2015.02.12 09:29:50 - Management - Send 'signal SIGTERM'
. 2015.02.12 09:29:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.02.12 09:29:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2015.02.12 09:29:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2015.02.12 09:29:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2015.02.12 09:29:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.137.205
. 2015.02.12 09:29:55 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.137.205
. 2015.02.12 09:29:55 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2015.02.12 09:29:55 - OpenVPN > Route deletion fallback to route.exe
. 2015.02.12 09:29:55 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.02.12 09:29:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 178.248.30.131 MASK 255.255.255.255 192.168.1.1
. 2015.02.12 09:29:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2015.02.12 09:29:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.137.205
. 2015.02.12 09:29:55 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.137.205
. 2015.02.12 09:29:55 - OpenVPN > Closing TUN/TAP interface
. 2015.02.12 09:29:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2015.02.12 09:29:55 - Connection terminated.
I 2015.02.12 09:29:58 - Cancel requested.
! 2015.02.12 09:29:58 - Session terminated.
