rawdan43_43
"OpenVPN not found" Error in Eddie (OS X)
Hi everyone
A friend of mine that is also a AirVPN user and in China at the moment cannot connect. There are two problems:
- He cannot select SSL Tunnel in the Protocols (is deactivated, grey) --> he uses ssh port 80 at the moment
- When he tries to connect to a server, he get the error "OpenVPN not found"
He's on OS X Yosemite and uses the latest Eddie version.
This is his log:
I 2014.11.07 23:07:19 - AirVPN client version: 2.7, System: OSX, Architecture: x64
. 2014.11.07 23:07:19 - Reading options from /Users/../.airvpn/AirVPN.xml
. 2014.11.07 23:07:19 - Data Path: /Users/…/.airvpn
. 2014.11.07 23:07:19 - App Path: /Users/…/Desktop/AirVPN 2.app/Contents/MacOS
. 2014.11.07 23:07:19 - Executable Path: /Users/…/Desktop/AirVPN 2.app/Contents/MacOS/AirVPN
. 2014.11.07 23:07:19 - Command line arguments:
W 2014.11.07 23:07:20 - Cannot be negative, and should not exceed length of string.
W 2014.11.07 23:07:20 - Parameter name: startIndex
. 2014.11.07 23:07:20 - Operating System: Unix 11.4.2.0 - Darwin VideoMac-4.local 11.4.2 Darwin Kernel Version 11.4.2: Thu Aug 23 16:25:48 PDT 2012; root:xnu-1699.32.7~1/RELEASE_X86_64 x86_64
I 2014.11.07 23:07:20 - OpenVPN Driver - Expected
I 2014.11.07 23:07:20 - OpenVPN - Version:  (/Users/…/Desktop/AirVPN 2.app/Contents/MacOS/openvpn)
W 2014.11.07 23:07:20 - SSH - Not available
I 2014.11.07 23:07:20 - SSL - Version:  (/Users/…/Desktop/AirVPN 2.app/Contents/MacOS/stunnel)
I 2014.11.07 23:07:20 - IPV6: Available
! 2014.11.07 23:07:20 - Ready
I 2014.11.07 23:07:50 - Session starting.
! 2014.11.07 23:07:50 - Checking environment
F 2014.11.07 23:07:50 - OpenVPN Not found
I 2014.11.07 23:07:58 - Session starting.
! 2014.11.07 23:07:58 - Checking environment
F 2014.11.07 23:07:58 - OpenVPN Not found
. 2014.11.07 23:10:22 - Updating systems & servers data ...
. 2014.11.07 23:10:32 - Updating systems & servers data ..., 1° try failed (The request timed out)
. 2014.11.07 23:10:34 - Systems & servers data update completed
thx for your help.
