fHzpCOkf
Home network VPN connection with AirVPN exit (Remote)
Is it possible to connect to my home network via AirVPN and then exit with an AirVPN connection.
I have managed to use AirVPNs port forwarding to connect back to my network but I would like to exit again to the internet, however, I am not able to get this to work.
Is this a feasible thing to do or would this never work?
Sure this is possible. Which Router-OS are you using?
With OpenWrt, you would create an OpenVPN-Client to connect to AirVPN and an OpenVPN-Server listening on your forwarded Port. The firewall must be configured to allow forwarding from the OpenVPN-Server-Zone to the OpenVPN-Client-Zone.
Hi I have already tried this and it did work, but I would like to know if you can get back through and out of the AIRVPN tunnel. The solution above requites you connect back to your home clear IP I would like to keep everything within AIRVPN.
Any ideas?
