Not connected, Your IP: 3.135.198.49
milkaca
Get current IP address of ISP
probably it is not possible but anyway I will ask one quick question. Is it possible to get current IP address outside of VPN connection, in other words IP from telecom provider network, which you normally get when you are not connected to VPN? I am using Eddie with network lock on my Linux machine.
My current workaround is to get IP address on another machine which is not connected to VPN. However would be handy to get this on same machine running VPN, if possible.
Regards,
amilino
